What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. May 31, 2022 at 8:28 AM
    #3271
    K9Lonzo
    K9Lonzo New Member
    Kris
    2019 Silver Sky Platinum
    Towed a new toy home a few weeks back. Super impressed with how it towed with the falcon shocks. 70mph cruise set no sway. Passed everything except the gas stations. Not sure on weight but guessing around 7k for tractor and trailer.
    superdenk, Prostar 190, LukeS and 7 others like this.
  2. May 31, 2022 at 8:53 AM
    #3272
    AZBoatHauler
    So.Arizona
    As pointed out, that trailer is causing a huge issue. Here is my boat that weighs about 1,500 lbs more…
    Prostar 190, junior and JDR76 like this.
  3. May 31, 2022 at 9:08 AM
    #3273
    AZBoatHauler
    So.Arizona
    If you can back up the trailer with the lights disconnected and not hear the trailer brakes screaming it means your brakes are not working at all.
  4. May 31, 2022 at 9:31 AM
    #3274
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    I took it as sarcasm, but... one could go in reverse without being plugged in and the brakes locking up, just put the special key in the tongue to prevent the brakes from engaging.
    KNABORES likes this.
  5. May 31, 2022 at 9:42 AM
    #3275
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    A 43 ft goose neck that hauls fencing supplies, a barbed-wire fencing machine, and a 4-wheeler. Half the time the fencing machine is swapped out for a skid steer with attachments when only a few posts need to be replaced. Fixing fence is not my favorite chore.
  6. May 31, 2022 at 10:06 AM
    #3276
    Johnny B
    Johnny B New Member
    Sault Ste. Marie Ontario
    2017 Tundra CrewMax Limited... white and chrome
    wears optional 20" rubber on chrome 1794 edition rims some performance and suspension tweaks
    Pulling a 2019 Imagine 29RL so just under 34 feet overall, 7400 lbs dry, 800lbs on the pin, never load water and minimal gear in the truck. Tugger is a 2017 limited crewmax, 2nd stage chip, cold air intake, bilstein 5100's in the back added a TRD rear sway bar and roadmaster active suspension. This pic is before the mods but now it sits nice and level and up here in Ontario keep it between 55-60mph. between 9 and 12 mpg depending which way the wind is blowing............. cuz its never calm after I hook up :( former Class A driver in a former life hauling max weight 136000lb in Canada....IMG_1621.jpg
  7. May 31, 2022 at 5:26 PM
    #3277
    WVI
    WVI New Member
    @008 Tundra Limited
    I dig those trailer fenders! Nice touch.
    SnrDisregardo likes this.
  8. Jun 7, 2022 at 4:07 PM
    #3278
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Picture from when I dropped it off at the storage lot the other day.
    Prostar 190, JDR76, WVI and 2 others like this.
  9. Jun 7, 2022 at 4:16 PM
    #3279
    Infernotundra17
    Infernotundra17 2017 Inferno SR5 Crew Max
    Martin
    Las Vegas, Nevada
    2017 Tundra Inferno orange
    Black Rhino 20" Go Rhino RB20 steps Magnaflow muffler
  10. Jun 7, 2022 at 4:17 PM
    #3280
    Infernotundra17
    Martin
    Las Vegas, Nevada
    Sumo springs before the next trip.If you have any experience with these please let me know how you like them.Thanks all
    Retroboy1989 likes this.
  11. Jun 7, 2022 at 4:27 PM
    #3281
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    I put a Wheeler's add-a-leave in my spring pack, a Hellwig EZ-990 on top and the black Sumosprings on ours. Hitch is 935# and only sagged an inch without WDH. I use the Anderson WDH and brought the back up the lost inch and nudged the front back down to within 1/4-inch unloaded. Towed through the state park between Plummer and St Maries Idaho just fine in S4 and Tow/Haul.
    WVI, Rabidllamas and KNABORES like this.
  12. Jun 7, 2022 at 5:31 PM
    #3282
    Infernotundra17
    Martin
    Las Vegas, Nevada
    Great,thanks so much for the info brother .Was going to do the blue but black is probably better for this beast of a trailer.Im averaging 11.6 mpg ,not tooo bad
  13. Jun 8, 2022 at 8:55 AM
    #3283
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
  14. Jun 8, 2022 at 9:14 AM
    #3284
    Wow. Impressive, but that trailer (3 axles) is likely 14,000# or more. Bed looks like its bending down. Not a good setup.
    Cpl_Punishment likes this.
  15. Jun 8, 2022 at 9:28 AM
    #3285
    Retired...finally
  16. Jun 8, 2022 at 9:32 AM
    #3286
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
  17. Jun 8, 2022 at 9:35 AM
    #3287
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    ^^ It's okay. He has a transmission cooler. :D
  18. Jun 8, 2022 at 9:42 AM
    #3288
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    Dang. Sorry. I thought it was a public video. I'm not good with Instagram or Facebook stuff.
  19. Jun 8, 2022 at 11:02 AM
    #3289
    Retired...finally
    You're not good? You're a genius compared to me.
  20. Jun 8, 2022 at 11:09 AM
    #3290
    Retired...finally
    Oh jeeez. Thanks for the picture. Gotta help us old farts out .
  21. Jun 8, 2022 at 3:06 PM
    #3291
    Retired...finally
    That's enough wood to build a space shuttle....and heat Johnson Space Center for the entire mission!
  22. Jun 13, 2022 at 6:13 PM
    #3292
    Retroboy1989
    Northern Utah
    I really like mine. I went with the black ones. I did not notice any decrease in ride quality when unloaded. (I'm never fully unloaded with the cap). I installed them when I was just renting trailers, so I don't have a "before" perspective.
    My trailer is likely not as heavy as yours.
    This was before I finished setting up the wdh.
    This weekend, not hooked up:
    Prostar 190 and KNABORES like this.
  23. Jun 17, 2022 at 6:29 PM
    #3293
    AJTundy
    AJTundy New Member
    2020 Tundra Crewmax SR5
    Leer 100XR truck cap, 5100's on the middle setting. Ikon Add A leaf, Cooper Discover ATX3 275/70/18, Genuine Cooling Systems transmission cooler, chrome delete.
    Spent a week mountain biking with my family. EVO T2360, probably about the largest trailer I would personally want to tow with my truck.
  24. Jun 18, 2022 at 3:44 AM
    #3294
    PermaFrostTRD
    Northern NY
    A8E9CD6F-2054-4F0F-A9F8-D76C45E4D798.jpg BD624DB8-5632-4755-9DAB-46F1E3C86481.jpg
    Not anywhere close to capacity but my buddy bought a 1967 StarCraft with the original ‘68 (yes) 40hp Evinrude and original seats. Thing was absolutely mint. Owner said “it lived a charmed life”. :rofl:
    So we drove a couple of hours into the mountains yesterday to pick it up.
    As expected, the ole shopping cart pulled her fine.
  25. Jun 18, 2022 at 4:02 AM
    #3295
    Retired...finally
    As soon as I saw the bow, Starcraft was the first thought I had. That combo will shit n git. If that motor was well cared for and you use real gas with synthetic oil it will last many more years. The boat? You're never going to kill it. That era Starcraft was the golden era for aluminum boats.
    WVI and PermaFrostTRD[QUOTED] like this.
  26. Jun 18, 2022 at 4:15 AM
    #3296
    PermaFrostTRD
    Northern NY
    @Retired...finally
    yeah it was a great find on his part. Everything was well maintained. I don’t have YouTube but the video the guy sent of the motor running made it sound like a 4 stroke.
    He bought it from the 2nd owner. 1st owner took immaculate care of it obviously. Second owner continued that (for 7 years) and decided that he wanted to find one in rough shape and restore it. Plus had another boat he was working on (in first pic). Gotta pick your mornings to use it as things could get bumpy quick but serendipitous find, fun drive/trip yesterday.
  27. Jun 18, 2022 at 4:26 AM
    #3297
    Retired...finally
    Get bumpy quick? Oh yeah. I have a 5 meter Alumicraft with a Honda 45 and it beats me up in anything but the smoothest water. The Starcraft being a much better hull design will ride better than my Alumicraft but it's still going to slap pretty hard. Good times, those older boats.
  28. Jun 18, 2022 at 7:27 AM
    #3298
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I just tow my two boats. 20220515_133700.jpg 20220507_111227.jpg 20211126_151033.jpg
    Prostar 190, KNABORES, Gaston and 7 others like this.
  29. Jul 9, 2022 at 12:31 PM
    #3299
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Helped my friend tow a mini kubota excavator he was renting for some work in his backyard
  30. Jul 11, 2022 at 7:40 PM
    #3300
    Fugis281
    Fugis281 New Member
    Rufio
    CA
    2021 TRD Sport/PRO
    Suspension: TRD PRO Suspension, Wescott Lift, Coachbuilder +3 Shackles and Tierods, Element UCS's, Wheels/Tires: Method Race Wheels MR312's, Toyo 35" Open Country RT's Engine: Stillen CAI, Pedal Commander, D3 Performance Tune, TRD PRO Dual exhaust.
    How is this possible? I was always told a 30ft was too heavy as far as tongue weight, Whats your setup? Currently in the market for a 25-27ft Airstream.
