How many gallons does my SR5 5.7L hold?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Wixo, May 30, 2022.
How many gallons in this truck?
  1. 38 (35 reg, 3 reserve)
    12 vote(s)
    85.7%
  2. 33 (30 regular, 3 reserve)
    1 vote(s)
    7.1%
  3. 41 (38 reg, 3 reserve)
    1 vote(s)
    7.1%
  1. May 30, 2022 at 9:42 AM
    Wixo
    Wixo [OP] The Best Member
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    I refilled when my tank showed 1/4 left and the miles to empty was 50. I only pumped in 27 gallons, $114 worth of gas and it was all the way full. It doesn't make sense that I had another 11 gallons in the tank left before I refilled. Maybe 6 gallons, 3 in the tank and 3 as reserve sounds right, but not a whole ass 11 gallons.
  2. May 30, 2022 at 10:09 AM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    38 gallon tank in mine.
    Wixo[OP] likes this.
  3. May 30, 2022 at 10:13 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I have a 26 gal tank.
    The most I ever put in it was 21 gal and the gauge was on the south side of empty..
  4. May 30, 2022 at 10:15 AM
    DoMoToyota
    DoMoToyota New Member
    Donald
    Monroe, Louisiana
    22 Tundra Limited 4x4 CM Black
    RC 1.75" Leveling Kit Cooper Rugged Trek 275/65r20 Pro Grille Diode Dynamics Grille Lightbar Rave OR Amber Grille Marker Lights GoRhino Dominator DSS Extreme step bars UnderCover Ultraflex bed cover
    If you have the “larger” tank option which I had on my 21, it should be officially 38.5 but it will technically hold a little more.
  5. May 30, 2022 at 10:40 AM
    Wixo
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    Your comment leads me to believe that I have the 38gal tank.
    1lowlife[QUOTED] likes this.
  6. May 30, 2022 at 11:03 AM
    jrquist
    jrquist Canon Shooter
    Carlton, Minnesota
    2020 Tundra Sport Super Bright White
    Sound about right for a 38 gallon tank. from what I have heard that there will be 6 gallons at empty to make sure the fuel pump in the tank stays cool. If mine gets past 1/2 of tank I fill just to keep it under that $100 mark.
  7. May 30, 2022 at 11:04 AM
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    38 gallon tank with 6-8 gallons in reserve.
    Silver17, Wixo[OP] and GODZILLA like this.
  8. May 30, 2022 at 11:09 AM
    easleycrawler
    Travis
    Same here. I fill up at a half or a little above half.
  9. May 30, 2022 at 11:12 AM
    18" TRD Off Road Wheels
    You have a 26 or a 38 gallon tank. Those were the only 2 factory options. If you got 27 in it you have the larger tank, but because the fuel tanks are very long (crawl under and look) they have a very conservative DTE. This keeps you from starving the pump on an incline while low on fuel.
    1lowlife, Cpl_Punishment and Wixo[OP] like this.
  10. May 30, 2022 at 12:06 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    If you bought your truck new, look at the monroney (if you still have it) to see what package you got. Maybe run a VIN search??? It sounds like you have a 38gal tank. At zero DTE, you will have used 32gal and have 6 gal remaining.
    I have a 38gal tank on my Sport.
    Wixo[QUOTED][OP] likes this.
  11. May 30, 2022 at 12:12 PM
    glowblue
    glowblue From time to time
    VA
    I’ve had both 26 and 38 gallon tanks. Most I’ve ever got in the 38 gallon tank was 35 gallons - ran it for a while with the low fuel light.
  12. May 30, 2022 at 12:14 PM
    r1-superstar
    DB
    UTAH
  13. May 30, 2022 at 12:47 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  14. May 30, 2022 at 1:52 PM
    Taco-Spike
    Two Trucks
    38 in mine
    r1-superstar likes this.
  15. May 30, 2022 at 3:06 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    1/2 tank is really 2/3 full, light on is really 1/3 full
    1lowlife and Wixo[OP] like this.
  16. May 30, 2022 at 5:18 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    Simple answer: at current prices it'll hold more than you want to spend to fill it up when DTE = 0.
  17. May 30, 2022 at 8:04 PM
    Wixo
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    I mean I do feel jealous because I saw a video of a guy filling up his Tundra with $45 back when gas was under $2
    Jernik[QUOTED] and Mike59 like this.
  18. May 30, 2022 at 8:39 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    In have an old car that has no gas gauge at all and actually has a “reserve” that requires you to turn a handle to tap the last bit of gas in the tank.
    The car chugging to a stop was the warning that you had about 50 miles before you really ran out of gas.
    In the Tundra, I know that it hits empty and the gas light comes on with about 6 gallons (80-ish miles) left.
    I pushed it once, waiting uncomfortably long to fill up. I squeezed 32 gallons in.
    1lowlife likes this.
  19. May 30, 2022 at 8:43 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I pushed my 26 to the limit..
    Had a full 5-gallon can in the bed.
    1/8" past empty when I finally filled it up and got 21 gallons in it..
