Transmission doesn’t freewheel when going down hills?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ronfrohock, May 29, 2022.
  1. May 29, 2022 at 6:31 AM
    ronfrohock
    ronfrohock [OP] New Member
    Ron
    2004 Tundra
    I’ve had my 2020 Tundra since new. Second one and I love it.
    The only thing I think is odd is when I am coasting down a hill, the transmission stays engaged and doesn’t allow me to more or less coast down the hill. Other vehicles seem to go into neutral as you go down a hill. This truck seems to want to stop itself.
    Is this common to all Tundras?
    Thanks
  2. May 29, 2022 at 6:56 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Yes, totally normal. It's there by design to act as an "engine brake" to ease brake wear. I've noticed if you very slightly press the gas pedal while you're going downhill, it doesn't engage and acts like it's coasting. Give it a try.
  3. May 29, 2022 at 6:59 AM
    Retired...finally
    Yep. My 21 does the same thing. It seems to downshift just as my wife takes a sip of coffee.
  4. May 29, 2022 at 9:49 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    If you have a scangauge/ultragauge you can see when it does a deceleration fuel cutoff. That's when it really slows down. If you want it to coast farther, usually just a light touch and release of the throttle will cancel the fuel cut
  5. May 29, 2022 at 9:55 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I've been known to manually drop it down a gear or 2 to slow before ever touching the brake pedal..:cool:
    Although the automatic semis I drive at work do actually go into a netural/coast mode when going downhill.
    CMikeB, WBW and WFD473[QUOTED] like this.
  6. May 30, 2022 at 5:35 AM
    ronfrohock
    Ron
    2004 Tundra
    Thank you all for your remarks.
    WFD473 likes this.
