*ACHIEVED YES!!* I am trying to get 23 mpg to no avail
Discussion in '2nd Gen Tundras (2007-2013)' started by EmergencyMaximum, May 28, 2022.
  1. May 28, 2022 at 4:01 PM
    EmergencyMaximum
    EmergencyMaximum [OP] Synthetic member
    2010 tundra, 4.6 v8, rwd, d.cab, long bed, 128k mi, stock(werk pkg), 87gas(10% eth), blue or grey. Bluegrey.(color)
    I'm trying to get 23mpg avg, but no matter what I do, it's always 22.8, 22.2, 22.6. The only thing that I could do, which is rather drastic, is to stop warming up the engine, but I've been doing it all my life and definitely don't want to stop.
    Any tips or pointers? Thank you.
    Slim Gym likes this.
  2. May 28, 2022 at 4:07 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    While going up hill blow on the windshield. If you have a passenger have them blow on it also. :yay:
  3. May 28, 2022 at 5:01 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Air your tires up more, assuming they're not maxed out already.
  4. May 28, 2022 at 5:02 PM
    Ericsopa
    Ericsopa Old man and the sea
    If you're "warming up" the engine by idling it, don't. Just drive easy until you're close to normal operating temp. It's actually better for the engine than idling to warm it up. It warms up faster and you won't cause any more wear, in fact, if anything, will cause less wear. So just start it up, sit for 10-15 seconds, put 'er in gear and go easy.
  5. May 28, 2022 at 5:06 PM
    After reading the post again, no way in hell it's getting 22 mpg. Just sayin'......
  6. May 28, 2022 at 5:08 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Pop the tranny into neutral and coast.
    What other like hacks can you use tonight?
  7. May 28, 2022 at 5:53 PM
    snivilous
    SW UT
    That'd probably burn more fuel, when you let off the gas the engine usually stops injecting fuel and tries to coast, if it's in neutral it'll have to keep itself running since it won't be engaged with the transmission anymore.
  8. May 28, 2022 at 6:11 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Lose a 100 Lbs.
  9. May 28, 2022 at 6:41 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    More cowbell.
    And a good team of oxen to pull the truck around.
    Seriously though, the numbers you’re getting are already in the class of “too good to be true.” More is never enough, if you reach 23 you’ll just want 24. :cool:
  10. May 28, 2022 at 7:01 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Drive downhill more.
  11. May 28, 2022 at 7:05 PM
    EmergencyMaximum
    @Booney , newton's law about action-reaction says it will be futile if I'm blowing on it from inside my own vehicle. I'll need a sign that says "blow at me" from fellow passing cars; not someone already riding in the vehicle.
    @snivilous , I'm at 35psi front and back. Don't want to air them higher because I hit potholes often. (Wandering eyes, lack of attention). Tires are regular highway ones.
    @Ericsopa , thank you friend. I only warm up a little bit; about 5 mins. If the engine just started up and I go, even easy - everything is cold(relatively speaking) and hot inside cams, uneven expansion causes increased wear. (Sorry if that doesn't make a lot of sense. English is my second language)
    @Tundra234 , please elaborate? Isn't that what I typed in OP?
    @TundraMcGov. , thank you, see @snivilous next post.
    @Roborob70 , I did; sort of. My rear seat is in the shed, but I do haul a microwave and some other tools often.
    Thank you, all! I do realize it is good enough, but this magnesium 23mpg is bugging me a little. I'm so close, yet so far away. This time I was doing work with mostly highway driving and I was really 'genteling' it. As I was pulling into the gas station, I'm thinking: "well, surely this time is extra special!" As I filled up, got my receipt, punched in the numbers into calculator, and...to my demise, 22.2mpg.
    Please don't get me wrong, I understand this is good mileage, but it's like a hobby to me. How much i can squeeze out of her.:) perhaps the culprit is, this time I did another squirt into her when she was full. It was about half a dollar worth, but I am not sure if it would have tipped the scales towards 23, with gas being 3.95, it was likely less than a cup worth.
    There is one other thing I could do. Drop the spare? It's a full size tire under her behind, but the constant thought of me needing it at the most wrong moment makes me hesitant to leave that 'dead' weight at home.
    Ps- you all get likes!
    Edit: @landphil , if you drove with me, you'd be upset how slow I go. 54avg, down to 50 uphill, no more than 58(okay, 60) downhill.
    @JLS in WA , road conditions don't always allow it.
  12. May 28, 2022 at 7:14 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Lower it
    caboj, rruff, Tripleconpanna and 3 others like this.
  13. May 28, 2022 at 7:18 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    A tonneau cover maybe? Also an air dam would probably get you there.
  14. May 28, 2022 at 7:28 PM
    Ericsopa
    Your English is fine. You're still wrong about the 5 minute warm up. That's been disproven a number of times. Not at all helpful to modern engines.
    But if it gives you more peace of mind, then keep on keepin' on. :)
  15. May 28, 2022 at 8:47 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Wow - you already have a unicorn. I drive pretty conservatively, like you, but I can't break 20 MPG on a tank of gas, and not very often even on single trips. BTW, Welcome from LA (Lower Alabama)!
    eddly and EmergencyMaximum[OP] like this.
  16. May 28, 2022 at 9:25 PM
    RoadtripJim
    RoadtripJim New Member
    Cedar, MN
    2021 Silver SR5 - TRD Double Cab
    ^^^ What he said ^^^
    Less wear & tear in the long run. Welcome and greetings from Minnesota.
    EmergencyMaximum[OP] likes this.
  17. May 28, 2022 at 9:30 PM
    Booney
    Booney New Member
    And your English is just fine.
  18. May 28, 2022 at 9:36 PM
    EmergencyMaximum
    @Hbjeff , thank you, but it will impede function, since I have to get to unconventional places at times.
    @LarryDangerfield , thank you, but I use my rear bed often to haul materials and trash. I do like the looks though! I had to google air dam, and someone said it won't do much unless you go over 80. Since my target speeds are in 50s range, it will be more for looks, rather than for actual aerodynamic benefit.
    @Ericsopa , thank you for compliment and clarification on engine warm-up. I was under the impression that new engine or not, aluminum behaves the same.
    @Bakershack , thank you. Motor and the rest of the metal is all default. I do use synthetic 0w-20 oil; perhaps that helps some. I've noticed, most of the fuel economy comes from driving manners. If I drive like an idiot, mileage does suffer. Gas being over 4 dollars a gallon gives a friendly nudge to take it easy. :)
    @RoadtripJim , thank you.
    @Booney , thank you.
    I'm in s.carolina; home to squatted trucks and mopeds.
    Saltyhero13 and Slim Gym like this.
  19. May 28, 2022 at 9:39 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Instead of bitching about .2 MPG, be glad you're getting 22.
    Problem solved, move on, get a life....:thumbsup:
    I get 14 MPG on a good day..
  20. May 28, 2022 at 10:43 PM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
  21. May 28, 2022 at 11:33 PM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
  22. May 29, 2022 at 2:57 AM
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    You are getting over 22mpg. I wouldn’t worry about that extra 0.2 - 0.8 mpg lol…. This is the best that I get when cruising at highway speeds and I am super grateful to get this while on 33s.
    PermaFrostTRD likes this.
  23. May 29, 2022 at 3:21 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I think the only way I see over 20mpg in the Tundra is by driving off a cliff... I assume it's not worth the savings in fuel.
    In fact, at this point, any changes will probably be too expensive to justify the minimal gains you garner.
    ...wonder if you can still find Z-max
    Black Wolf likes this.
  24. May 29, 2022 at 4:09 AM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    That's great mileage, congratulations! I'd just be happy with that.
    Just to get the magic number, but don't keep doing it, you'll hate driving...a/c off to keep drag on engine down, windows up to keep aerodynamics, and heat on full blast to help with engine temps. I read about someone doing that, like 30-40 years ago, and won a gas mileage contest..she talked about how miserable it was, but she won the car they were driving in the contest!
    If I drive mild, 55-60 max, easy does it, I can get juuuuust over 20, and I'm ecstatic...2020 5.7l.
  25. May 29, 2022 at 4:52 AM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
  26. May 29, 2022 at 4:58 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I'd be thrilled with 15.
  27. May 29, 2022 at 5:20 AM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Buy a corolla
    Cpl_Punishment, TheBrit and MTRock like this.
  28. May 29, 2022 at 5:25 AM
    MTRock
    MTRock 1889
    Montana
  29. May 29, 2022 at 5:41 AM
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    When I had my 21 TRD Sport, I average 17.2 mpg for every gallon pumped into the tank. I was happy. Sometimes that lying dash computer would indicate about 21 mpg for a just completed trip. But, I easily managed to get over 38 mpg when I traded for a 2022 CR-V turbo. Now, I did not make the trade because of MPG, because gas was only $2.19 when I made the trade, but wow, as much as I miss cruising down the highway in that truck, sure glad we made the trade. Full disclosure I only bought the truck because I wanted the truck, not because I needed the truck at all. Highway cruising was great, everything else was just an effort that I just did not want to endure anymore. Shape, weight, engine, gearing, use...there is just nothing efficient about a Tundra.
    Hbjeff likes this.
  30. May 29, 2022 at 7:18 AM
    1lowlife
    DADA
    2014 MGM DC SR5
