Conversion from center console to center seat
Discussion in '2.5 Gen Tundras (2014-2021)' started by Snoozer, Jan 22, 2018.
  1. Jul 4, 2020 at 4:17 AM
    #91
    RPKEAN
    RPKEAN New Member
    I would guess if we were to fill swap an upper trim back to a bench, either you leave the console shift or you switch to column but loose the telescoping function of the steering wheel.
  2. Jul 4, 2020 at 6:11 AM
    #92
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Yeah I have thought about doing that and installing a 38 gal tank myself. Then having Katzkin installed.
  3. Jul 4, 2020 at 10:46 AM
    #93
    Gdry06
    Gdry06 New Member
    15" on 40s and charged
    Yup. That's next on the list. 38gal or the 43gal transferflow tank. Can't complain at mpg's. .so just getting a bigger tank to solve the problem.
  4. Dec 22, 2020 at 5:19 PM
    #94
    14srAKH
    14srAKH New Member
    2014 tundra sr white
    Wheels, center console swap, tinted windows,
    Is there anyone local to southern VT looking to go from console shift to column shift?
    I already have console and shifter assembly I just need the harness and cable.
    I could give the center cloth seat and column shifter assembly with cable and harness.
  5. Jan 1, 2021 at 1:20 PM
    #95
    14srAKH
    14srAKH New Member
    Can one of you guys do something with this
  6. Jan 1, 2021 at 1:21 PM
    #96
    14srAKH
    14srAKH New Member
  7. May 27, 2022 at 11:36 AM
    #97
    Ls1sdgto
    Ls1sdgto New Member
    Rudy
    do you have pics of final install?
    Poppy likes this.
  8. May 27, 2022 at 3:04 PM
    #98
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    Pretty much just the same as you see there.
    I did add another pocket in front to carry a few nig water bottles,Sanitizer and Wipes but this is a work truck and not too interested in the way it looks in the end though I am OK with how it looks too!
