Head unit different sound with radio and phone
Discussion in '3rd Gen Tundras (2022+)' started by Mikey1793, Feb 27, 2022.
  1. Feb 27, 2022 at 11:54 PM
    Mikey1793
    Mikey1793 [OP] New Member
    Does anyone have noticed playing radio/Sirius music is louder than playing music from your phone?
  2. Feb 28, 2022 at 12:25 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Sometimes having your EQ on your phone set to custom or something other than normal will cause the volume to sound low. Not sure if you have android or iPhone but I had that issue with my android (in an aftermarket radio in another vehicle). Make sure your phone volume is turned all the way up, if it'll even let you control it.
    Don't have a 3rd gen just something I've experienced before.
    GODZILLA likes this.
  3. Mar 1, 2022 at 1:36 PM
    21CGtundra
    21CGtundra New Member
    Robbie
    SLC, UT
    2022 Midnight Black Tundra SR5
    2" front level, 1" Cornfed rear spacer, Rally Armor flaps, Method Con-6 wheels, 285/75 Duratrac
    My 2021 was this same way. On the freeway streaming music from my phone with Spotify I'd have the volume between 35-40 but the radio only needed to be 28-32ish. My 2022 is the same way. Doesn't bother me I just know the volume limits for each source.
  4. May 25, 2022 at 9:40 PM
    omglas3r
    omglas3r Member
    Definitely normal. Has to do with source volume just like on a tv between a show and commercials. Audio over bluetooth will also sound different compared to even via usb due to compression.
  5. May 26, 2022 at 12:07 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    same on earlier models, each sound input/source has and keeps its own sound settings.
  6. May 26, 2022 at 12:30 PM
    Some phone apps have volume adjustments built in. DCBB2D6B-B9F6-4AEB-B378-544E362F251D.jpg
  7. May 26, 2022 at 4:39 PM
    Breathing Borla
    Northern Illinois
    This has been around forever in stock systems mainly.
    most good aftermarket systems you can really adjust each input , my pioneer has all that. Had to trim up the Bluetooth compared to others , etc
