Axle relocation plates
Discussion in 'Suspension' started by cctxquicksand, May 25, 2022.
  1. May 25, 2022 at 8:46 PM
    cctxquicksand
    cctxquicksand [OP] IG - TRDistheWrd
    Any have any experience with these? Trying to wrap my head around these, since i installed my rxt leaf pack my rear wheel has always been a bit “pushed back”. Thinking these could help correct the issue, they seem super simple but I’m not sure how these will work honestly. I did notice last time i was changing out my leaf pack there are already what seem to be three center pin locations, are these essentially the same thing could i just set my leafs in the most forward hole and call it a day? I’d rather not have the extra lift these will add if they work so just moving pin location forward would be a better solution for me. Any help is appreciated
    ^^ current rear wheel location
  2. May 25, 2022 at 10:10 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I had the RXTs and was able to place them in the center hole of the stock mount. By placing the center pin in the most forward hole you would actually position the axle further back, towards the rear of the truck. If you’re already in the center hole, then you should try the rear most hole to move the axle forward.
  3. May 26, 2022 at 6:21 AM
    cctxquicksand
    Thanks Cruz,I’ll definitely give that a shot
