22s max tire size / ideal tire size 22 Platinum
Discussion in '3rd Gen Tundras (2022+)' started by n8banga, May 25, 2022.
  1. May 25, 2022 at 9:03 AM
    n8banga
    n8banga [OP] New Member
    Nate
    Hi group, thank you in advance for any help- right now I‘m running 275/605/r20s, but honestly
    I’m kinda disappointed with the look. I ordered similar wheels in 22s and I’m trying to determine the best size of tire for the 22s, I like the over all size the 20s are (the outside size) but I think it’s too much rubber, so im hoping 22s will look better.
    Current setup is standard suspension with avs/ I have the Wescott 2/1 Avs lift on order. Before the lift comes could I fit 295/55/22 or is there a better size? Will those fit with the lift. Thank you so much for any help I’m clueless about most of this and could use any help
  2. May 25, 2022 at 9:29 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  3. May 25, 2022 at 11:28 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    I like the look with 33's on, it's a good compromise of drivability, looks and mileage. When you lift it they will look small on the truck, I know 35's fit with no lift so with a 2/1 that's probably a good option for you.
  4. May 25, 2022 at 11:55 AM
    Wixo
    Wixo The Best Member
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    I was gonna say, you have too little rubber on there :rofl::rofl:
    Im looking to go down to 18's with 33's.
    I think the ideal '22 Tundra tire is a 37 on 20-22in rims
    JamesAZ and rruff like this.
