5100 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by pvn.beluga, May 22, 2022.
  1. May 22, 2022 at 2:21 PM
    pvn.beluga
    pvn.beluga [OP] New Member
    Phuc (Phooc)
    Connecticut
    Hey, since the 6112/5160 guys have a thread of their own, why not start one with the members running specifically 5100s? :bananadance::rofl::cheers:
    My setup:
    Bilstein 5100 fronts @ top setting
    Bilstein 5100 rears w/ Total Chaos Fabrication 3/4" shackles
    ProComp 41 Series Phaser - 18x9, 12mm offset
    Toyo Open Country R/T - 37x12.50r18
    joonbug, The Dude, Glocker23 and 11 others like this.
  2. May 22, 2022 at 2:26 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    KIMG0107.jpg5100 front and rear, middle clip, Icon Rebounds 18x9, 25 offset, 275-70-18 Maxxis
    2020SR5tundra, The Dude, MER and 2 others like this.
  3. May 22, 2022 at 2:27 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Hell yeah! Looking good bro!
  4. May 22, 2022 at 3:09 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    5100s front/rear. Front at mid setting and 2 shims each side. Boss 4x4 rear shackles at 1-3/4” Super bumps front and rear.
  5. May 22, 2022 at 3:19 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    One of the best Blue Ribbon Tundra out there... :yes:
  6. May 22, 2022 at 3:25 PM
    BlueRibbon4x4
    Geno
    Thank you sir!! It’s dirty as hell in that pic.
  7. May 22, 2022 at 3:37 PM
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    THANKS, your's too !!!
  8. May 24, 2022 at 9:24 AM
    MER
    MER New Member
    18' Limited CM 4x4 Off Road
    5100’s (front only) at middle setting with one .25” Coachbuilder shim on each side, stock rears, SCS Ray10’s +25mm offset, 275/70/18 Toyo AT3’s
  9. May 24, 2022 at 9:46 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    5100’s all the way around with the front in the top setting. Plan is to order and install +1 Coachbuilder shackles in the rear at some point.
    Sitting in TRD Pro wheels with 275/70s.
  10. May 24, 2022 at 10:23 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Definitely install the CB+1 for that .625" lift or you can do TC 3/4" shackles too!
    I was running with 0 lift in the rear and once I loaded up some stuff, it started squatting the truck.
  11. May 24, 2022 at 11:04 AM
    RustyShackle323
    Stewart
    NC
    Thanks bud. I too noticed on our beach trip last weekend with all the junk in the back, she was squatting a little bit.
  12. May 24, 2022 at 4:03 PM
    Blueknights75
    Ron
    Clayton, NC
    5100s all around with front at top setting. Don’t want to have to add a carrier drop so leaving the rear alone.
  13. May 24, 2022 at 6:05 PM
    gegs310314
    gegs310314 New Member
    St. Louis
    2019 Platinum
    Got the new stance all set…
    2.3 Level with 5100’s upfront
    275/60/R20 Terra Grapplers (No Rubbing)
    RB20 boards.
    parts and install by Top Tier Suspension and Hellbent Off-road. Could not be happier
  14. May 26, 2022 at 8:27 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    I haven’t installed mine yet as I’m still waiting for some parts to arrive, but everything is on order
    Fronts at top clip
    2 CB .25 shims on the driver side
    1 CB .25 shim on the passenger side
    CB diff drop
    CB carrier drop
    CB brake line relocation brackets
    CB 2” rear shackles with poly bushings
    CB bump stop spacers
    CB bumper shims
    I’ll be running RRW RR7’s 17x8.5 with Falken wildpeaks 35x12.5
    Depending on clearance a possible CMC if needed.
  15. May 30, 2022 at 1:59 PM
    PapaGrizz
    PapaGrizz MGM CRÜE
    Derek
    Spokane Valley, WA
    2016 MGM Tundra TRD Off Road Crewmax
    Question for yall. If I throw 5100s in the front what setting would I set it at to get it level while not touching the rear?
  16. May 30, 2022 at 5:08 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Most likely middle clip. Are you going to be hauling anything heavy?
  17. May 30, 2022 at 6:53 PM
    PapaGrizz
    PapaGrizz MGM CRÜE
    Derek
    Spokane Valley, WA
    Awesome! Thank you! Nah, won't be hauling much of anything for a long while. Price of trailers is dumb AF right now.
  18. May 30, 2022 at 7:01 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Best thing to do is get prior measurements though front and rear. I think I was sitting level on top setting, but it'll definitely vary from truck to truck.
    PapaGrizz[QUOTED] likes this.
  19. May 30, 2022 at 9:19 PM
    AJTundy
    AJTundy New Member
    2020 Tundra Crewmax SR5
    Leer 100XR truck cap, 5100's on the middle setting. Ikon Add A leaf, Cooper Discover ATX3 275/70/18, Genuine Cooling Systems transmission cooler, chrome delete.
    I originally had mine stock in the rear, front was set at the middle setting. It was pretty much perfectly level like that. I recently added the Ikon AAL, which raised the back almost 1.5 inches. So now I have a similar rake to stock, but about a 1.5 inch lift all the way around. Very happy with my setup and it drives similar to a stock setup.
  20. Jun 6, 2022 at 7:03 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    wow 37’s??
    nice!!
  21. Jun 7, 2022 at 10:37 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Lots of trimming and cutting, but we're there!!!
    Toe404[QUOTED] likes this.
  22. Jun 7, 2022 at 12:27 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    It looks fantastic. I was thinking about going with 37s myself. I have done the BMC and the pinch weld already. Also trimmed the fender liner and front splash shields. Running 5100s on the top spot currently.
    Did you use bumper spacers to help clearance. Do you still have parts of the plastic inner fender liner?
  23. Jun 7, 2022 at 1:29 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Nice, hopefully you haven't plated the BMC yet (depending on how aggressive you went with your cut).
    I'm using the (2) CB bumper shims on each side so that gives me another 0.5" clearance. However, I also trimmed my bumper caps and relocated one of the 12mm that was holding the bumper caps to the bumper cap sub frame.
    Toe404 and Shanet421[QUOTED] like this.
  24. Jun 7, 2022 at 2:07 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    @Shanet421
    Here's what my fender liner looks like after PWC.
    And here's what my bumper caps look like now.
  25. Jun 7, 2022 at 3:27 PM
    biebs96
    PA
    5100s middle setting
    1” lift in rear
    Stock TRD off road wheels, refinished surface in gloss black
    Yokohama geolander x-at 285/75/18
  26. Aug 13, 2022 at 11:45 AM
    Kalyan123
    Kalyan123 New Member
    Kalyan
    2007 Tundra Sr5 TRD off road
    So I was thinking to put in 2 inch levelling kit on the front of my 07 tundra Sr5. But after doing some research i found out about the 5100. I’m pretty sure the stock ones are 4600 (but here’s the part number 48510-0C030)
    Anyways I have few questions I needed to know before i buy it.
    1. Which ones better 4600 or 5100s ? I do city highway driving mostly but once in a while do
    Some light off-roading aswell.
    2. If I choose to go with 5100 front and rear do I have to put in lift kit aswell ? I read on toyotec site that only for “lifted trucks”.
    Here in Canada my local tire shop quote me $800 for 2” levelling kit. So I’m not sure what should I do.
    Sorry for the noob questions.
  27. Aug 13, 2022 at 12:08 PM
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    5100s are a great choice, 3 way height adjustable. I have mine set in the center and love them.
  28. Aug 13, 2022 at 2:14 PM
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
    5100s on middle setting for the fronts
    TRD reds for the rear shocks
    275/60/20 Cooper Discoverer AT3 on stock TSS wheels
    ATV25, GWill, RustyShackle323 and 2 others like this.
  29. Aug 13, 2022 at 2:18 PM
    Kalyan123
    Kalyan
  30. Sep 7, 2022 at 7:58 AM
    Stant1dm
    Stant1dm New Member
    Dave
    Michigan
    2019 Limited TRD Off-road
    Adding the 5100's in the next couple of weeks along with the RAS in the rear. I can't decide whether to do the middle setting w/ 0.5" shim, top setting, or top with shim. I see all sorts of opinions. I'd like it pretty close to level. I pull a TT quite a bit so I'm leaning towards the middle+shim to be right at 2" the front, and around 1" in the rear.
    Anyone add a diff drop? I figure because its not that expensive, why not?
