2000 Tundra help identify wiring harness connectors
Discussion in 'Electrical' started by 22CKnight, May 24, 2022.
  1. May 24, 2022 at 11:36 AM
    22CKnight
    22CKnight [OP] New Member
    2000 Tundra Limited
    My Vehicle is a 2000 Tundra 4.7L Limited with AT and has a Access Cab and Rear Wheel drive. I recently purchased this truck.
    I would like to see if someone may have an answer to identify a certain “box” that is wrapped with some vinyl tape (like black electrical, but more like heat shrink film). There are two white wire harnesses (connectors) on one side I can see they are not connected to anything, but I can’t see their wires from my view from below the knee kick panel.
    This “box” is located under dash, just above and to the right of the steering wheel shaft. Located behind horizontal AC plenum.
    I call this a “box”, but it is more like a holder for multiple wiring harnesses that are protected by this black tape/film it is wrapped with. This “box” seems to be open on the bottom and not a complete enclosure. Haven’t cut tape/film back to explore.
    I discovered it while I was looking around to see if this truck is equipped with a keyless entry or alarm system, a brake controller or any other modules.
    If any of you have any idea(s), please reply. I did find a wiring diagram for this vehicle to try to identify them before writing this post. The photo posted is a view looking up from the brake pedal with the white connectors to the right because the photo is rotated counter-clockwise 90 degrees. Part of the brake pedal mounting hardware you can see in photo.
    Thank you.
  2. May 25, 2022 at 7:39 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    If I had to guess I would say it could be this "Junction Connector" I think inside the red box is the approx area you are describing.
    The two connectors shown at the bottom almost look like the ones coming out of the side of the box in your photo. Hard to tell.
    If this is it, its just a spot to "tie" harnesses or ciruits together. Not an actualy control module with a circuit board in it on anything.
    MS22 likes this.
  3. May 25, 2022 at 8:19 AM
    22CKnight
    2000 Tundra Limited
    That may be what it is, but I wasn’t sure. I will look into the wiring diagram schematics. Thank you.
