  1. May 23, 2022 at 7:15 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm certain I just heard the unmistakable sound of BRRRTTTT and then some splosions over the hill outside BG.
    https://youtu.be/NvIJvPj_pjE
    One burst. No doubt in my mind.
  2. May 23, 2022 at 8:56 AM
    Not somebody running a welding bead or jake-breaking?
    I mean, I had some burritos for lunch and I'm a little windy, but I doubt you're hearing all this noise over there. Hopefully not smelling it either. Oldest kid is regretting staying home sick today.
    bmf4069 likes this.
  3. May 23, 2022 at 10:21 AM
    Sirfive likes this.
  4. May 23, 2022 at 12:35 PM
    That’s one way to find cheap property to buy. Live next to a live ammo testing site. :rofl:
  5. May 23, 2022 at 12:43 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Yep.
    o_O
  6. May 23, 2022 at 12:55 PM
    It’s ready for pickup, we shall see how they did
    NUDRAT[OP] likes this.
  7. May 23, 2022 at 1:49 PM
    Casper421
    In the woods
    06 DC
  8. May 23, 2022 at 1:59 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
  9. May 23, 2022 at 2:05 PM
    Casper421
    In the woods
    06 DC
    I’m thinking $100 is worth the test.
  10. May 23, 2022 at 2:17 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
  11. May 23, 2022 at 2:26 PM
    Casper421
    In the woods
    06 DC
    Looks like 3 position but my only hang up is the possible lose of adjustability. If I can get +4 caster, oem specs on everything else and have these so I’ll never lose the alignment, I’m sold. But I’m not sure it’ll pan out that way.
    Master alignment guru @assassin10000 any insight or thoughts?
  12. May 23, 2022 at 2:49 PM
    @assassin10000
    Looks like they did pretty good, drives nice.
    The tech seemed real knowledgeable and I talked to him when I picked it up; he said right front adjuster was siezed and the bushing was starting to tare so he didn’t want to force anything.
    So now I guess I’ll be on a slow search to find new lowers to press bushings into maybe…. 0233169A-AAF3-449F-B21A-B0C15B735424.jpg
    bmf4069, alb1k and NUDRAT[OP] like this.
  13. May 23, 2022 at 7:29 PM
    alb1k
    Left Coast
    It's good
    I sent my lowers to a buddy on here. But, just get the moogs and you will be good IMO. No pressing bushings or any of that. Amazon has them.
  14. May 23, 2022 at 7:34 PM
    alb1k
    Left Coast
    It's good
    What really interests me is that if you can run those and get the alignment you are happy with, greasing the Solos should be easier without losing alignment. I'm squeaking on all four corners at the moment.
  15. May 23, 2022 at 7:38 PM
    daveeasa
    @des2mtn ’s alignment guy said to get my ass up before I waste his time. Probably good advice. So I will limp along back to Jason’s and wait for Deaver to re arch.
    NUDRAT[OP] and assassin10000 like this.
  16. May 23, 2022 at 7:40 PM
    alb1k
    Left Coast
    It's good
    Today was pretty productive. Only a third of what I hoped to do - but I got the rear legs of the rack locked down. I ran stainless bolts right trough that track and backed them up under the bed rail with backer plates. Now that I have my method, front legs will be fairly easy.
    NUDRAT[OP], shifty` and FrenchToasty like this.
  17. May 23, 2022 at 7:41 PM
    alb1k
    Left Coast
    It's good
    He's right. and level is so limiting. Ass high for the win.
    Sunnier and FrenchToasty like this.
  18. May 23, 2022 at 7:45 PM
    alb1k
    Left Coast
    It's good
    Backer plates are two piece. That poly whatever and 1/4 aluminum
    NUDRAT[OP] and FrenchToasty like this.
  19. May 23, 2022 at 7:48 PM
    I put these like hidden eye bolts in my bed that thread into a blind socket, almost like a bulkhead, but I didn’t trust the sheet metal, so I did something similar with 1/4 plate 2.5x 6” or so to spread the load. Good thinking. Is the black stuff the hdpe or almost a delrin?
  20. May 23, 2022 at 7:56 PM
    alb1k
    Left Coast
    It's good
    Yeah, I thinks it's HDPE. I bought a sheet when I was going to make bump stop spacers. It is the same material as my Wheeler's spacers and the ones Archive sent me to space my rear u- bolt flip setup. I used it because my bolts are not all-thread and I needed to block the aluminum for fit. But seems like a good marriage.
    https://www.amazon.com/gp/product/B0719QM4B8?ie=UTF8
  21. May 23, 2022 at 8:07 PM
    alb1k
    Left Coast
    It's good
    I also cut pieces to put between my bed side top and the tonneau so when I crank it all down it's solid with no gap anywhere. Hard to explain, but the rack legs are bolted: base, track. tonneau, HDPE spacer, bedside top, HDPE spacer, 1/4 aluminum. For my crazy setup, it's a solid no-gap mount.
  22. May 23, 2022 at 9:34 PM
    alb1k
    Left Coast
    It's good
  23. May 23, 2022 at 9:37 PM
    Yeah you can’t drop bombs like that
    bmf4069 and alb1k[QUOTED] like this.
  24. May 23, 2022 at 9:43 PM
    alb1k
    Left Coast
    It's good
    Apparently not, :rofl: I did pick this weeks theme. I might haver to judge as well, lol
  25. May 23, 2022 at 9:44 PM
    Was that pic of significance to you? Or just another one in the barrel haha
  26. May 23, 2022 at 9:53 PM
    alb1k
    Left Coast
    It's good
    Just one I took of my kid. But my buddy taught me a bit about black and white. I don't do much of that but theres a whole thing about how to do it well. I got lucky, AND SCORED A WEEKLY CHALLENGE!!!! WOOT! YEW! #winning #Imjustherefortheaccolades
    KK6PD and FrenchToasty[QUOTED] like this.
  27. May 23, 2022 at 9:53 PM
    That was awesome.
  28. May 23, 2022 at 9:54 PM
    alb1k
    Left Coast
    It's good
    wasn't it? So F-ing funny.
  29. May 23, 2022 at 9:55 PM
    We now have ammo for if you disappear or take too long to respond on here!
    NUDRAT[OP], KK6PD and alb1k[QUOTED] like this.
  30. May 23, 2022 at 9:57 PM
    alb1k
    Left Coast
    It's good
    Holy crap those guys are prolific memers. Yeah, you got it, lol.
