Setup advice for a Noob
Discussion in '2nd Gen Tundras (2007-2013)' started by Csmith0250, May 23, 2022.
  1. May 23, 2022 at 7:47 AM
    Csmith0250
    Csmith0250 [OP] New Member
    Con er
    07 black tundra sr5
    Led blue interior lights, toyota puddle lights, 10 in. Sub, aftermarket taillights
    I have just bought an 07 tundra. I'd like to change the set up and look of the truck but I'm a noob when it comes set ups. It's currently stock and I want the look of tires just outside the fender to give it a more aggressive look.
    My understanding is that I need a leveling kit and spacers? Or can I level it and just get wider rims and tires?
  2. May 23, 2022 at 8:01 AM
    Wahayes
    Will
    2017 tundra limited *sold*
    Lower offset wheels or spacers , and generally changing offset further out will cause you to need a leveling kit to not rub. This was my truck with 275/60r20. Had a little poke maybe 3/4 inch or so with a level. Wheels are 20x9 +20 offset. Tires will play a part too, as now I'm on 325/60r20 same wheels with significantly more poke because the tires are so much wider
