Rear Suspension Questions Lifted Tundra
Discussion in 'Suspension' started by Str8himalaya, May 23, 2022.
  1. May 23, 2022 at 4:55 AM
    Str8himalaya
    Str8himalaya [OP] Here to learn!
    Ohio
    2017 Tundra SR5 TRD Off Road
    7” Stage I Pro Comp Lift
    Hi All,
    Starting to learn about some upgrades I can make to the rear suspension of my new (to me) Tundra. It has a 7" pro comp stage one lift installed (4" blocks with the added leaf) but has upgraded Fox shocks on the rear. I don't want to add any height to it as it sits, so if I added shackles would that add height? Just curious what shackles I should look into, also looking at getting rid of the blocks all together. Any help I would appreciate!
  2. May 23, 2022 at 7:00 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    The alternative to 4" of blocks would be leaf replacements or a combination of shackles and leaf replacements.
    Many companies make leaf replacements, but I recommend Coachbuilder for shackles:
    https://shop-coachbuilder.myshopify...ilder-3-shackles-provides-1-75-of-actual-lift
    Saltyhero13 likes this.
