Ceramic coat...self or professional?
Discussion in 'Detailing' started by Robster80, Feb 12, 2022.
  1. Feb 12, 2022 at 8:09 AM
    Robster80
    Robster80 [OP] New Member
    Whos done it themselves? Was quoted $1200-1600 depending on amount of polishing needed. Figured i would figure up what the products cost to do it myself then decide but would hate to buy the stuff, not be satisfied with prep work and end up taking it to a pro. Just curious how many have tackled this themselves and how satisfied are u with results? Ive watched some youtube vids. Doesnt seem too difficult but ive never used a clay bar or polisher either.
    BlueRibbon4x4 likes this.
  2. Feb 12, 2022 at 8:24 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Check out @2020Platinum He’s got a video of his first time ceramic coat. Came out amazing.
  3. Feb 12, 2022 at 8:29 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    If you have the right tools you can do it yourself. But this is an example of where the right tools, knowledge and experience counts. You can screw up your paint quickly with a powerful polisher if you cut too much or use the wrong pads, techniques.
    These may help
    https://www.tundras.com/threads/coating-experiences-multiple-brands.97136/#post-2510269
    https://ceramicpro.com/ceramic-coating-myths-the-truth-about-diy-ceramic-coatings/
    https://adamspolishes.com/collections/ceramic-coating-kits-diy
    https://www.youtube.com/watch?v=pAq6_rl009U
  4. Feb 12, 2022 at 8:43 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    If you’re a detail oriented perfectionist go for it. “Good enough for govt work” doesn’t cut it with paint correction and ceramic coating.
  5. Feb 12, 2022 at 8:58 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I can wrench some yet by the sounds of replies, I'd shell out the bucks for a Pro on this!
  6. Feb 12, 2022 at 9:31 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    There are more the one article out there now that says ceramic is not worth the money. These have came out in the last four months or so if I am remembering correctly?? I don’t know if it is good or bad? I know people that have done it,, I have not. I hope no one has a cow over this if so call the doctor immediately.!!!!:)Just saying.???
  7. Feb 12, 2022 at 10:19 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    just curious why they say its NOT worth it ?
  8. Feb 12, 2022 at 1:07 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    How old is the vehicle? Is the paint well kept? Which coating are you going with?
    You can do it yourself but I'm concerned about you not having experience with polishing paint before. This is where 90% of your shine comes from. It is also an easy step to screw up and will cost money for the proper materials need to perform a paint correction. Depending on what coating you are thinking of applying, this can also be unforgiving. If you misapply it you'll get highspots which typically require a correction to remove. Also depend how much your time is worth too. If you know what you are doing you can bang it out in a day (not counting cure time) but it could take longer as well, really depends on the starting condition of the vehicle.
    I wouldn't recommend attempting it unless it is a passion project.
    Runway likes this.
  9. Feb 12, 2022 at 1:10 PM
    bfunke
    bfunke Tundra Curmudgeon
    Newer cars have thinner clear coats and it's easy to burn through.
  10. Feb 13, 2022 at 7:44 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Do it yourself and save a ton!…did my 2020 Platinum and my wife’s RAV4, came out great…I have this step by step guide, and also just posted a 1 year review on my channel as well…lemme know if I can help ya at all
    Ceramic Coating For Beginners (step by step guide for DIY)
    https://youtu.be/qxcymSqnqco
    Ceezurin, Pipo6007, OhEmmBee and 4 others like this.
  11. Feb 13, 2022 at 7:44 PM
    2020Platinum
    Patrick
    Northeast PA
    Here’s the 1 year review showing how it’s holding up
    Ceramic Coating Follow Up, Was It Worth It and How Is It Lasting???
    https://youtu.be/7vUwpPLJROw
    PermaFrostTRD and bulldog93 like this.
  12. Feb 14, 2022 at 8:16 AM
    Robster80
    My main concern is ive never polished a vehicle or even used a clay bar. Id probably screw something up some kind of way during the whole prep part of it lol. Plus i dont have an inside garage. I might could get access to one tho. Maybe.
  13. Feb 14, 2022 at 9:20 AM
    SnowB0und
    SnowB0und New Member
    2013 SR5
    I have an older truck, I used a clay bar, finishing compounded, and Griots 3in1 Ceramic. Not sure if its anything special, but a year later water is still beading and dirt is easy to wash off. I'm not a detail guy but I think your pretty safe as long as you use a DA.
  14. Feb 14, 2022 at 9:31 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    With your lack of experience with things like clay bar and polish, it has me hesitant to say to go for it.
    I've done 3 vehicles.
    2019 White Honday Odyssey after owning for about a year with Armour Shield IX. Still seems to be holding well. I top with beadmaker every 3-4 weeks after a wash for maintenance, but also for gloss and slickness.
    Did it to my 2017 Blazing blue tundra with the same coating and topper bead maker. Did it around 2020 or 2021 though then traded it in. But did well.
    Recently bought a 2021 Lunar Rock Sequoia and coated it within about 3 weeks of owning it I think with Cquartz UK 3.0 then later topped it with carpro hydro2. I've gone 3-4 weeks without a wash on it and the water beaded like it does after weekly washes before I even washed it.
    PREP IS EVERYTHING!
    I'm a weekend warrior and dont' detail for a living. But on the sequoia, it took me around 16 hours i think all together from start to finish. Wash, decon, clay, wash/rinse, polish, ipa wipe down, coated, then reload topped. I enjoy doing detailing though as thats my "nothing box" (as my wife says).
    Watch lots of videos, ask lots of questions, and dont' be too hard on yourself. Everyone starts somewhere. Some just start paying someone first. YOU decide what you're going to do.:thumbsup:
    War Machine likes this.
  15. Feb 14, 2022 at 9:34 AM
    Saltyhero13
    Not having a garage makes it more challenging and increases the risk of something going wrong.
    Oey12 likes this.
  16. Feb 14, 2022 at 9:58 AM
    Robster80
    Yea thats what i figured as well. I know a guy with a shop i MIGHT could use but i dunno. May just fork out the cash so i know its done right
  17. Feb 20, 2022 at 7:51 PM
    Ace96
    Ace96 New Member
    Western KY
    2021 Voodoo Blue TRD Sport
    You have to be a complete moron to burn through paint with a DA polisher.
    marcelo73 and BecauseRacecar like this.
  18. Feb 20, 2022 at 7:58 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Guilty. :anonymous: But I was trying to clear a brillo pad job on paint, lol.
  19. Feb 21, 2022 at 3:07 AM
    1eyedclyde
    1eyedclyde New Member
    Clyde
    NewCastle CO
    21 SC Pearl Platinum
  20. May 22, 2022 at 10:58 PM
    ffdawson
    ffdawson #DBB
    NorCal
    Sandra, Sandy for short
    Rad ass parts, big tires.
    Seems like there’s plenty of step by step instructions out there… give her hell!
  21. May 23, 2022 at 12:46 AM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    You can pick up a fender or trunk lid at a junkyard for dirt cheap and practice on it. Thats how I got confident with a polisher. If you dont want the hassle of the clay you can try this synthetic clay bar, its a little more forgiving to work with but wont give you the same results as real clay.
    https://www.amazon.com/Griots-Garag...t=&hvlocphy=1013462&hvtargid=pla-568784249419
    Saltyhero13 likes this.
  22. May 27, 2022 at 7:58 PM
    Robster80
    I let a pro do it. Turned out great
  23. May 27, 2022 at 8:34 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
  24. May 29, 2022 at 10:01 AM
    Robster80
    Heres a quick pic. Its been 3-4 days since washing and using the quick detailer from shine supply.
    ToyoMafia, War Machine and Fotnot like this.
  25. Jun 8, 2022 at 4:03 AM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    bed liner, diamondback se, level kit, nitto ridge grapplers,tufskinz letters, grab handle
    I paid a professional to do the ceramic coat.
  26. Jun 8, 2022 at 4:46 AM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    I paid $500 to have my crewmax tundra ceramic coated. This included a lot of buffing as the body shop wet sanded a lot of dust nibs out of my paint after I had 2 doors replaced because a deer ran into the side of my tundra. They didn’t know how, or chose not to, properly buff out the wet sanding scratches. So this would have added greatly to the time to ceramic coat my truck. Still $500 and it’s been over 2 years and 2 long winters and it’s still very hydrophobic.
    find a reputable back yard detailer that’ll save you a lot of money. This spot I went to has done a lot of high end vehicles, much more expensive than my tundra, so don’t always judge a book by it’s cover (the shop).
    ToyoMafia likes this.
  27. Jun 10, 2022 at 3:06 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
  28. Jun 10, 2022 at 8:11 AM
    Ace96
    Ace96 New Member
    Western KY
  29. Jun 10, 2022 at 8:29 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    just curious.... why you call him a "scammer"?
  30. Jun 10, 2022 at 9:20 AM
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    I paid a pro to do it. Paint correction and a 9 year warranty on the Gtech ceramic coating. Best thing I ever did for my Black Tundra, my first vehicle with a ceramic coating. No more paint swirls/scratches and washing it is so much easier, I love it. The water beads are gratifying to see.
    Robster80[OP] and Ace96 like this.
