Made a stupid HUGE MISTAKE! Need advice
Discussion in 'General Tundra Discussion' started by Tundy4x4Dude, May 22, 2022.
  1. May 22, 2022 at 2:17 PM
    Tundy4x4Dude
    Tundy4x4Dude [OP] Backroad Bandit Buster
    '14 SR5 TRD 4x4 Double Cab 6.5' bed
    Made a huge mistake this morning :mad: while I was fastening breakaway security nuts onto bolts that come up through the front stakepocket for my backrack. Somehow while torquing one of the nuts it didnt break off early enough ( I was using a normal socket wrench) and pulled/folded the sheet metal. And the security nut broke off before I realized it folded the metal. GRRR! :censored: So basically main question is how structurally sound is it? Only real fix I can think is welding on a nice strong piece of steel right around the bolt (Pre-drilled) And I was not torquing crazy hard. Must have been a weak spot in the metal. Any comments/advice would be appreciated!
  2. May 22, 2022 at 2:35 PM
    Big fender washer grade 8
    alb1k, WAtundra4x4, T-Rex266 and 6 others like this.
  3. May 22, 2022 at 2:49 PM
    Tundy4x4Dude
    @FrenchToasty Thanks! Great idea. I knew there was a simpler solution.
  4. May 22, 2022 at 3:17 PM
    AZBoatHauler
    So.Arizona
    Well sure, if you want to spend 8 cents.
  5. May 22, 2022 at 6:00 PM
    Correction 3cents…….
  6. May 22, 2022 at 6:02 PM
    AZBoatHauler
    So.Arizona
    :annoyed: I need to find a new washer guy.
  7. May 22, 2022 at 6:12 PM
    Yeah you need to find a better Ace hardware
    Booney and T-Rex266 like this.
  8. May 22, 2022 at 8:14 PM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
  9. May 23, 2022 at 10:40 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    Never saw a problem that couldn't be fixed by throwing a ton of pennies at it!
    AZBoatHauler likes this.
