I did a thing. I like the thing I did
Discussion in 'General Tundra Discussion' started by sledbiz, May 21, 2022.
  1. May 21, 2022 at 6:11 PM
    sledbiz
    sledbiz [OP] New Member
    Arizona. USA
    2021 CM 4WD Trail Edition
    Dual TRD exhaust, Katzkin leather. Sway bars FR, TRD PRO grill, headlights and fogs. Full focal audio system. Boost auto power fold tow mirrors
    What a difference. Read posts here. Did front and rear in 30 min. Having access to a lift helped a touch. Anyways. If you’re on the fence, get off. MASSIVE difference.
  2. May 21, 2022 at 6:22 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Did them 4 years ago. Huge mondo ginormous difference.
  3. May 21, 2022 at 7:03 PM
    Dantdodge
    Dantdodge New Member
    Danny
    Tampa
    2018 tundra sr5 crewmax trd 4x4
    Stock trd off road
    Do you notice the big difference even just normal street driving or just big difference off road or noticeable on both?
  4. May 21, 2022 at 8:35 PM
    sledbiz
    Arizona. USA
    Just did it this morning so only street so far but the difference is night and day.
    Dantdodge likes this.
  5. May 21, 2022 at 8:44 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Very noticeable for street driving. Truck handles better with the sway bars installed. Adding the rear bar was about a 75% improvement for me, upgrading to the thicker front bar improved handling by another 25%.
    YardBird likes this.
  6. May 21, 2022 at 8:52 PM
    Dantdodge
    Danny
    Tampa
    Stock trd off road
    Thanks Def going to look into these for the next mod. Where did you end up purchasing yours? @sledbiz
  7. May 21, 2022 at 9:07 PM
    sledbiz
    Arizona. USA
    I got them thru work. I’m in the automotive field so it made it easy.
    Dantdodge[QUOTED] likes this.
  8. May 21, 2022 at 9:09 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Should help with handling and body roll. But will hurt ability to flex and be a hindrance on the rocks
  9. May 21, 2022 at 9:25 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Will not be good for off road.
    Hotwire and sledbiz[OP] like this.
  10. May 22, 2022 at 3:47 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    To bad the tundra sway bars don’t have dis-connects like I had on my 95 jeep. The best of both worlds.
    TheBeast and Saltyhero13 like this.
  11. May 22, 2022 at 4:49 PM
    COTundie
    Trey
    Pretty things
    You're not wrong... wonder if someone makes a kit?
    Not electric/auto, but I would consider a beefy sway bar with manual disconnects.
  12. May 22, 2022 at 4:57 PM
    Saltyhero13
    I think the Land Cruizer has an electronically controlled sway bar system. I cant remember the name of it at the moment.
  13. May 23, 2022 at 2:34 AM
    2014 Black tundra
    2014 tundra sr5
    This is what I had on my 95 YJ. Manual disconnect. But my pipes were straight. It really help with articulation. With the right length pipe, you wouldn’t need to drop the sway bar when lifted.
  14. May 23, 2022 at 4:13 AM
    COTundie
    Trey
    Pretty things
    Kinetic Dynamic suspension
    Uses hydraulic cylinders to stiffen or slack the anti roll bars. You get both flattened cornering on road, and full articulation when you need it off road.
    Cool system
    Saltyhero13[QUOTED] likes this.
  15. May 23, 2022 at 4:47 AM
    Saltyhero13
    Yes thank you.
    The closest I've seen in an aftermarket system is ICONs electronically controlled shock system. Different application but similar effect.
  16. May 24, 2022 at 4:41 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    The rear bar definitely helped make my truck feel more stable and reduce body roll in corners but it didn't eliminate it. I'm not sure I'd call it a night and day difference.
