Installed 35s with no lift
Discussion in '3rd Gen Tundras (2022+)' started by machiiito, May 20, 2022.
  1. May 20, 2022 at 9:04 PM
    machiiito
    machiiito [OP] New Member
    2022 Lunar LTD OR
    Two days with the Toyo at3s 35x12.5x17 with +20 offset wheels and I haven't had any rub. I will say that I did remove the mud flaps and pushed the carpet liner a little to give some space. It was the first 2022 the shop installed tires on and they warned that it would "probably rip the bumper off", but we were both pleasantly surprised to see them barely touch the carpet liner at full lock. I'll post more picks later on.
    I'll still most likely remove the body mount piece in the front (couple bolts) until I get the Wescott lift to be safe. At least until a true lift and suspension comes out.
  2. May 21, 2022 at 7:28 AM
    aguninc
    aguninc New Member
    WNY
    22 Tundra Platinum MGM, 21 Rav4 Prime
    On a side note. Why does lunar rock always look like seafoam green in photos
  3. May 21, 2022 at 11:09 AM
    machiiito
    2022 Lunar LTD OR
    Definitely would have liked Cement like my old Tacoma!
    Booyashakalaka! likes this.
  4. Jun 3, 2022 at 10:10 PM
    CarlsSenior303
    CarlsSenior303 New Member
    Carl
    2022 Tundra Limited TRD Offroad Army Green (hopefully)
    Thanks for the pic! I’m debating the same move.
  5. Jun 5, 2022 at 7:47 PM
    jgreene
    jgreene New Member
    What kinda fuel mileage are you seeing with the 35s?
  6. Jun 5, 2022 at 7:55 PM
    machiiito
    2022 Lunar LTD OR
    Averaging about 15.5 driving in "Normal" mode. I'm guessing it's a little higher than that if you account for the speedometer adjustment for bigger tires.
  7. Jun 5, 2022 at 9:43 PM
    SDT
    SDT New Member
    B
    2022 Limited Tundra Mesquite
    TRD running boards/skid plate
    That's not bad. How do you adjust the speedo?
  8. Jun 6, 2022 at 3:42 AM
    brucega7x
    brucega7x New Member
    2022 Tundra SR5 CrewMax 4X4
    I think what he’s saying is technically with the bigger tires you’re actually traveling further than what the truck thinks. So if that was factored into the MPG read out, it would actually be better.
  9. Jun 6, 2022 at 3:50 AM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Dealer can do it. I've looked into it but it's not worth the $200 to me. If you know somebody with a Techstream device they can do this and some pretty amazing other stuff too.
  10. Jun 6, 2022 at 9:20 AM
    machiiito
    2022 Lunar LTD OR
    This is what I meant. Thanks!
  11. Jun 6, 2022 at 9:21 AM
    machiiito
    2022 Lunar LTD OR
    Same. For $200 bucks I don't need the exact number!
  12. Jun 6, 2022 at 9:25 AM
    Buellride
    Buellride New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    Running 35"s......I am getting 15.8 MPG on the dash with "city" driving; when I fill up I actually calculate 16.9 MPG with a calculator/pump math. On a recent road trip with 75-80% highway driving I ended up getting 18.1 MPG for a full tank. Mind you the road trips involve driving over the eastern Cascade Mountain ranges or the southern ranges on the borders of WA, OR and CA.....
    Overall I am very happy with the numbers.
  13. Jun 6, 2022 at 9:34 AM
    jgreene
    jgreene New Member
    So I am contemplating selling my 2020 Tacoma for a new tundra. Truck is neat and lot of things I like.
    but with 285/70-17 4.88 gear I manage 16ish on a trip with no head wind and anything over 70 seems. Strong head wind trying to do 70 I have been as low as 13s.
    Then factor in pulling I think I’m gonna have to get back to a full size.
  14. Jun 6, 2022 at 1:04 PM
    mass-hole
    mass-hole New Member
    The Tacos are rough. I test drove one and it wouldn't stay in 6th at 70mph on flat ground because of a head wind. They so lack in the low end torque department that they are having to rev to keep themselves going which I think hurts them.
    My Lexus gx460 with the 4.6L V8 is on 285/70's and is averaging 18.2 mpg on the dash(so more like 19.5 since my speedo is off almost 8%) after two 70mph trips down to Salt Lake City.
    jgreene[QUOTED] likes this.
  15. Jun 6, 2022 at 1:13 PM
    jgreene
    jgreene New Member
    I have to say the gears and tune helped the truck a bunch.
    Blows my mind though.
  16. Jun 6, 2022 at 1:13 PM
    Troa
    Troa I blue it again.......
    Nomad
    2022 Blueprint Limited
    I'm coming out of a 2018 Taco on 31s (265/75r16) and have 34s (275/65r20) on the Tundra. I'm seeing better MPG now than I did in the Taco.....
  17. Jun 6, 2022 at 1:24 PM
    jgreene
    jgreene New Member
    2022 Tundra?
  18. Jun 6, 2022 at 1:26 PM
    Troa
    Nomad
    Yup (Also no lift, no suspension mods, and no modification to the fender liners or factory mud flaps)
  19. Jun 6, 2022 at 1:34 PM
    jgreene
    jgreene New Member
    That the factory aluminum rock guards?
  20. Jun 6, 2022 at 1:36 PM
    Troa
    Nomad
    No. GoRhino D6 Dominators
  21. Jun 17, 2022 at 8:31 PM
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    did you go with the D or F load rated AT3s?
    My thoughts are the F are overkill, but wondering what others are going with…
  22. Jun 18, 2022 at 4:17 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    I hated the color until I had mine in the driveway. The color is amazing in person but very non-photogenic. I would totally buy this color again.
    jmay86 likes this.
  23. Jun 20, 2022 at 10:24 AM
    machiiito
    2022 Lunar LTD OR
    I thought the same. I had been waiting for some backordered Mickey Thompsons and they finally came in. Those are D vs the E load Toyos. I definitely like the road feel of the Mickey Thompsons better than the stiffer Toyos. Not a huge difference, but noticeable enough for me.
  24. Jun 20, 2022 at 10:48 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Wasn't sure if you saw this, but the TRD lift kit looks pretty promising and is more than a simple suspension lift.
    The lift kit announced by Toyota will be available for almost all 4×4 trims of the 2022 Tundra. Customers will be able to lift their truck by 2.6 inches while also leveling the front and rear nicely.
    The factory TRD lift kit is made up of tuned Bilstein front and rear shock absorbers with taller TRD coil springs, TRD front lower knuckles, front extended axle-shafts, front stabilizer links. Front outer tie rods, front tie rod sleeves, and several other upgraded parts.
  25. Jun 20, 2022 at 3:40 PM
    machiiito
    2022 Lunar LTD OR
    If the cost starts getting close to 4K I will probably opt for a full adjustable kit from King or Fox. Solid options coming though!
