  1. May 19, 2022 at 12:47 PM
    #571
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    just meguiars gold wash. a mild car wash detergent that indicates good for foam cannons is all you really need. the key is in the foam cannon. a good quality one make a huge difference in foam output. if you're just getting into detailing it yourself, google the '2 bucket wash method'. this is key to prevent swirls. i also use soft water which not everyone has but just try not to wash it in direct sunlight to prevent water spotting. i also do an initial dry with a leaf blower then whatever is left gently pass over it with a new (not used or washed) microfiber towel.
    AMSOFLO likes this.
  2. May 19, 2022 at 2:12 PM
    #572
    Prescott87
    Prescott87 New Member
    Jonah
    Brentwood, Ca
    2022 Supersonic Red Limited
    TRD Filters, De-Badged, TRD Pro Grille
    Swapped out the chrome handle for black and added the letter inserts
    Henry1jg, Burns, Troa and 6 others like this.
  3. May 19, 2022 at 2:48 PM
    #573
    mdre
    mdre New Member
    Matthew
    Livermore, CA
    2022 Tundra Limited Crew Max TRD OR 4x4
    Nice, what is the black handle part number? It’s probably somewhere in this thread….!
  4. May 19, 2022 at 3:22 PM
    #574
    FALQN
    FALQN New Member
    Midnight Black, 4x4 Crew, TRD Sport
    OEM Running Boards, Wheel Locks, Hard Cover, Home-made Kicker Sub
    Great…thanks for the info!
  5. May 19, 2022 at 4:10 PM
    #575
    Laffingas
    Laffingas New Member
    '22 Tundra Limited - Army Green
    Was swapping out the chrome handle as complicated and time consuming as the door handles?
  6. May 19, 2022 at 4:29 PM
    #576
    wayoflife
    wayoflife Exploring Cascadia and beyond
    Seattle-ish, WA, USA
    '22 1794 6.5' TRD Offroad Blueprint/Cream
    Westcott 3/1 Method 705 18x9 18mm Maxxis RAZR 295/70R18
  7. May 19, 2022 at 4:54 PM
    #577
    MRQZTNDR93
    MRQZTNDR93 New Member
    San Diego CA
    2022 TUNDRA SR5 TRD OFF ROAD
    WELP I WAS DRIVING ON THE FREEWAY AND SOMEONES PLYWOOD FELL AND SMACK ME RIGHT IN FRONT AND THE TRUCK ONLY BEING A WEEK OLD :(:(:(:(
    PapaDave418 likes this.
  8. May 19, 2022 at 4:57 PM
    #578
    hivetyrant
    hivetyrant New Member
    2022 Limited Tundra
    On the bright side you're now ready to install a covert winch bumper :)
  9. May 19, 2022 at 5:19 PM
    #579
    wayoflife
    Dechromed the mirror caps with my mancub/mechanic
    Henry1jg, FI460, oxlsu40 and 2 others like this.
  10. May 19, 2022 at 5:35 PM
    #580
    Prescott87
    Jonah
    Brentwood, Ca
  11. May 19, 2022 at 6:29 PM
    #581
    offshore2005
    offshore2005 New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    TweakedMang0, FI460 and JPD like this.
  12. May 19, 2022 at 10:13 PM
    #582
    elgreco
    elgreco New Member
    I had mine done. Paint matched perfectly to the midnight black metallic. $185 including tax and ready in 24hrs. Didnt even have to disassemble anything, im pretty sure they just bagged the truck.
  13. May 19, 2022 at 10:14 PM
    #583
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    How do you like the console liners?
  14. May 19, 2022 at 10:22 PM
    #584
    Troyboy84
    Troyboy84 New Member
    BC Canada
    2022 SR5 TRD Offroad
    How do you like the center foam inserts? Do they raise the level much? I can lay my phone in the lower portion and still slide the drawer, is that possible with the inserts?
  15. May 19, 2022 at 10:23 PM
    #585
    Troyboy84
    BC Canada
    I just used some cheap drawer liner to keep stuff from sliding around, wasn’t thick so the phone still fits.
  16. May 20, 2022 at 4:20 AM
    #586
    99ways2die
    99ways2die New Member
    Bummer, but hey, now you can mount those tow hooks w/o any interference!
    -99
    MRQZTNDR93[QUOTED] likes this.
  17. May 20, 2022 at 6:13 AM
    #587
    Swarley
    Swarley New Member
    Ouch, glad damage is focused to that center bumper area
  18. May 20, 2022 at 7:41 AM
    #588
    MRQZTNDR93
    San Diego CA
    i was pissed at first but then I called Toyota and the parts weren't that bad in price and available next day so it was okay :}
    akimbo, Swarley[QUOTED] and FLTon like this.
  19. May 20, 2022 at 12:25 PM
    #589
    offshore2005
    TEXAS
    Love em!! Nothing moves around anymore!
  20. May 20, 2022 at 12:26 PM
    #590
    offshore2005
    TEXAS
    I love em. I would say the foam is about a 1/4” thick.
  21. May 20, 2022 at 2:57 PM
    #591
    wayoflife
    Westcott 3/1 installed today. The shop (local dealer) removed the front mudflaps, but didn't make any notes on the sheet as to why. It was definitely rubbing before the lift, but I'd expect to not rub those flaps after the collar lift. I may put them back on and try it out... or look for different, thin, mudflaps - I live in Seattle-ish, so there's often wet roads to fling around goop from.
    Now:
    (scroll up a couple of days for the "new wheels/tires but no lift" view if you want)
    Stock:
    I'm super happy with the look and feel so far. On the freeway, it's pretty much the same ride as stock - but on bumps (like big speed bumps on pavement, or potholes) it's definitely stiff. This'll do for at least the summer and fall until there are more lift options to replace the collar lift.
    ToyoTundra89, Gin05, HMNYC and 2 others like this.
  22. May 20, 2022 at 3:00 PM
    #592
    hivetyrant
    2022 Limited Tundra
    Stock already looked good, but the new tires look great. Nice work!
    wayoflife[QUOTED] likes this.
  23. May 20, 2022 at 3:06 PM
    #593
    wayoflife
    Thanks. I was telling my wife that the truck feels like MINE now. And both son and I were thinking that it doesn't look much different pre-lift and post-lift, but when you open the door and go to step in.. it's definitely taller :). I'm recovering from a hernia surgery and no supposed to be lifting much weight, but I've gotta work a bit to climb into the truck now :rofl:
  24. May 20, 2022 at 3:26 PM
    #594
    hairychestedfrog
    hairychestedfrog New Member
    Idaho
    22 Tundra SS Red Plt CM
    damn. Looks like a clean break though. Hopefully you're not waiting weeks or months for the part.
  25. May 20, 2022 at 5:29 PM
    #595
    mdre
    mdre New Member
    Matthew
    Livermore, CA
  26. May 20, 2022 at 7:23 PM
    #596
    FALQN
    FALQN New Member
    Was so impressed with the look and thought of items not sliding around, I ordered a set this morning.
    offshore2005[QUOTED] likes this.
  27. May 21, 2022 at 1:51 PM
    #597
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    Ordered the black letters for my 1794. I also ordered the all weather floor mats. The 1794 mats that came with the truck didnt fully cover the carpet and they had an annoying carpet insert in the mat. Looked good, but not functional. 20220521_163321.jpg
  28. May 21, 2022 at 9:33 PM
    #598
    wayoflife
    I'm in the passenger seat about halfway through the return leg of a Seattle-Spokane-Seattle day trip up go drop off a treadmill to my mom, and to get my teenaged drivers Ed student some more hours and night driving hours. We'll see a bit over 500 miles today.
    I was rear seat passenger for the first leg. That's pretty comfy back there, except for not being able to recline.
    At freeway speeds and with the lift plus 295/70r18s and early in engine breakin, we are averaging a tad under 16mpg not adjusting for tire size.
    I'll take it.
  29. May 22, 2022 at 8:49 AM
    #599
    Buellride
    Buellride New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    WoL....looks pretty good. Regarding the mudflaps, even with them on my truck I still get the mud "rooster tails" going up the sides of my truck. I really don't mind the dirt tails but it would be nice at some point to get something that covers that 3/4" "poke" that I have with the +18s and reduce the kick up of debris.
    My Westcott (black anodized) should get shipped later next week....looking forward to the stance that I will have with the added 2"s or so; though I foresee a 4" kit in the future once the aftermarket develops something for AVS/Air bag systems.
  30. May 23, 2022 at 7:50 AM
    #600
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    Truck did a good job with 2 bikes this weekend. Minimal squat, and got us to the trails.
    KTM = 240 LBS
    HONDA = 298 LBS
    RAMP + GEAR = 60 LBS
    TOTAL = 600 LBS
    JerryMacBlack, dekeman, =JSG= and 8 others like this.
