  1. May 19, 2022 at 4:15 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    220 400 600
    Wahayes[QUOTED] and KNABORES like this.
  2. May 19, 2022 at 4:21 PM
    Wahayes
    Will
    2017 tundra limited
    Do I need to re prime that area as well?
  3. May 19, 2022 at 4:24 PM
    Jbehredt
    Westminster, CO
    Would be a good idea.
    Wahayes[QUOTED] likes this.
  4. May 19, 2022 at 4:43 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    @Jbehredt is correct. The 220 to smooth out the rough edge from the gash, and 400 to get rid of the sanding scratches. 600 for smoothness. What paint did you use?
    Tundra234 likes this.
  5. May 19, 2022 at 5:08 PM
    Wahayes
    Will
    2017 tundra limited
    Rustoleum professional quart not rattle can , reduced with acetone @BlueRibbon4x4
  6. May 19, 2022 at 6:16 PM
    BlueRibbon4x4
    Geno
    Ok. Sometimes that stuff can be a little rubbery when trying to sand it, like latex. You may have to let it cure for a while before it’s tough enough to sand.
  7. May 19, 2022 at 6:26 PM
    Wahayes
    Will
    2017 tundra limited
    Good to know. I may just go ahead and mount it then, and mask off and spray on the truck like someone suggested. At least that way I can start using it again and spray it when I have time.
    Plus it will give me practice for when I have to do this again from banging into rocks lol
    BlueRibbon4x4[QUOTED] likes this.
  8. May 19, 2022 at 6:35 PM
    Quick test cut with some matte red that I had. I have to increase the height about 1/8 of an inch and the size should be pretty close.
    mgm16trdpro, Yzed608, RegGex and 5 others like this.
  9. May 19, 2022 at 6:46 PM
    BlueRibbon4x4
    Geno
    Exactly. That’s what I would do. :thumbsup:
  10. May 19, 2022 at 7:21 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    Went to Tucson and bought a toy, then went to Apache Lake. 0 to 60 in 2.4 seconds from a dead stop.
  11. May 19, 2022 at 7:32 PM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    Finally got the topper! Love this thing, really happy with how it turned out. Now gotta add a camera to the 3rd brake light. B69752C5-A915-4C92-BCDC-3FCEFE4A328E.jpgD635C7DD-B892-40C7-AC9A-6375AAAADBA3.jpg0FAE68A9-F1F8-400F-BCE1-0AAF316D5CE2.jpg14A5691B-9BD8-4FF9-BFA5-DF37F9967A81.jpg
    Wallygator, GAknight, WFD473 and 4 others like this.
  12. May 19, 2022 at 7:33 PM
    RegGex
    Oregon
    2021 TRD Pro CM
    Also put in the 8600NEX, much better than the 4660 (just too small). Happy with how it is now, planning on taking out the trim and fitting it flush to the dash when I have more time to mess with it. 8095AAC7-0002-4142-92C9-58AB11EAA4BD.jpgA17CBF61-2905-431C-A20F-AA15ABC1190A.jpg
  13. May 19, 2022 at 7:44 PM
    Dantdodge
    Dantdodge New Member
    Danny
    Tampa
    2018 tundra sr5 crewmax trd 4x4
    Stock trd off road
    I believe it man, housing is insane here now.. to buy or rent.. just hunkering down here. I'm glad I bought my home in 2018.
    Taco-Spike and Tundra234[QUOTED] like this.
  14. May 19, 2022 at 8:16 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    :thumbsup::popcorn:
    Taco-Spike likes this.
  15. May 19, 2022 at 9:01 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    It’s a bumper
    :itllbuffout:
    I’d sand, mask, and touch up in place after mounting. Then go :mudding:and give it a couple new scratches and get on with life. But that’s me. :p
    Taco-Spike and HulkSmurf14 like this.
  16. May 19, 2022 at 9:27 PM
    Wahayes
    Will
    2017 tundra limited
    Yea I just wanted to get it on the truck and use it a few times admiring my handy work prior to fucking it up lol
  17. May 20, 2022 at 4:59 AM
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    2021 Tundra CrewMax 4WD Limited Nightshade Special Edition MGM
    Pulled the trigger on a set of the Bushwacker painted fender flares. REALTRUCK has them on sale right now. Was $800.00 now $640.00 with free shipping. These are the paint to match fender flares. I ordered the MGM 1G3 paint code. Ordered the clear installation tape too to protect the paint. Also ordered the hood scoop and the MGM primer/paint/clear. Have a little experience with spraying so I’m going to give it a try and paint it myself. I’ll post a few before and after pics when I get it done.
  18. May 20, 2022 at 5:02 AM
    BlueRibbon4x4
    Geno
    Finally made some rear mud guards for the inner fenders. I had some Mammoth guards for the front, and had to make the two pieces from plexiglass, so I decided to make some rears. I used cardboard as a template, and traced it onto plexiglass. Then used a heat gun to bend the plexiglass into place. I used the existing wheel well fasteners. Painted to match the fronts using self etching primer, Rustoleum 2X metallic cobalt blue, and satin clear. They weren’t color matched because the Blue Ribbon color looks very dark under the fender well. 52CCFE0E-9E14-4900-8A27-91134204D56A.jpg44BCDB9C-7DEB-4364-AB41-EFCF07344FB6.jpg672626B7-B473-4F55-BB17-CCB94CA85A2A.jpg89B3E306-52D1-4AA6-BE96-C28848DA0D56.jpg7A0C375F-332B-4615-AA84-60720CB83792.jpg3FF9F3A8-D25B-4EA1-9A4A-655417CD0C51.jpgC44AE6F1-0759-4E75-981D-63350916E49C.jpg45ABF85E-7222-4ABF-908F-A824522B01C9.jpg
    Nickutta, mr0351, GAknight and 17 others like this.
  19. May 20, 2022 at 5:25 AM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Quick question figuring someone has probably had experience here.
    Has anyone replaced a gasket in their exhaust and used a gasket that stays in place by starting the bolts to connect the pipe. If so pls provide a link or part number.
    I have already tried replacing it with a straight circle gasket and even with adding a little product to keep it in place remember it being a bitch to line up. Obviously I didn't do a good job because I now need to replace it again.
  20. May 20, 2022 at 5:32 AM
    The gasket where the tailpipe connects to the muffler? I used the Fel-Pro 60461 without any issues.
  21. May 20, 2022 at 5:42 AM
    PermaFrostTRD
    Northern NY
    Try this:
    https://www.rockauto.com/en/catalog...ust+&+emission,pipe+flange+gasket+/+seal,5836
  22. May 20, 2022 at 6:13 AM
    Kung
    KG, VA
    At least they don't
    - pull you over, yelling, for going *two* miles over the limit
    - tell you that you don't have to show up for court (I was going to be out @ sea on deployment) so long as you pay the fine through the mail
    - and then send out a warrant for your arrest anyways because the cop forgot.
    (Yes, true story.)
  23. May 20, 2022 at 8:56 AM
    Wahayes
    Will
    2017 tundra limited
    Ok so moving past yesterday's mistakes and forging ahead.....I needed a remote winch solenoid mount solution for the x20 winch , so I am fabricating some L brackets I had laying around to mount my solenoid. Should work pretty well and solenoid will mount to the brackets using the hardware and holes that the factory brackets came with. Should get everything mounted up and installed tomorrow, then I can start dealing with fixing the paint. :welder::sawzall:
  24. May 20, 2022 at 9:20 AM
    mgm16trdpro
    Northern NJ
    Yup that's it and that's the one I used. For whatever reason I found it damn near impossible to stay lined up while bolting back together. I was wondering if anyone used a gasket like we do on water meters where you start the bolts and just slide the gasket down to rest on them so you know your lined up. I tried using the one you mentioned and even putting some shit on it I couldn't get it to stay in place.
  25. May 20, 2022 at 9:32 AM
    mgm16trdpro
    Northern NJ
    I know this won't fit but anyone with any experience or know of a gasket seal even something like this?
    If not did you use any tricks to keep it in place while bolting up? Maybe the adhesive I tried was just shit.
  26. May 20, 2022 at 9:40 AM
    @dirtydeeds
  27. May 20, 2022 at 10:24 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    First day of our Outer Banks trip!
  28. May 20, 2022 at 10:45 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Thanks again G for the diff breather! @GNTundra !!
    Finally put it on.
  29. May 20, 2022 at 11:02 AM
    AZBoatHauler
    So.Arizona
    My real home and my home away from home - nice work!! Feel free to come say hello if you see us out there.
    Wallygator, GAknight, Gaston and 16 others like this.
  30. May 20, 2022 at 11:36 AM
    Ranger2005
    Ranger2005 New Member
    Dean
    2021 1794 Crewmax
    Running boards, ceramic coating, sound system
    I love running jet skis - especially when there are big waves to jump
    We rigged ours for fishing
    Wallygator, GAknight, nhw544 and 7 others like this.
