Rough Country 3” or 3.5” Lift? 2015 2WD
Discussion in 'Suspension' started by MULLI63, May 16, 2022.
  1. May 16, 2022 at 2:33 PM
    MULLI63
    MULLI63 [OP] New Member
    Southern California
    2015 Tundra Platinum, SnugTop Shell, Gray
    Bilstein 5100 all four corners - front at top setting Ready Lift 1” rear block 295/70R18 Falken Wildpeak Method Roost R18 Under Seat Storage Boxes - Rear Seats - see post LED Interior Lights LED Mirror, Back-Up and License Plate Lights Added Auxiliary Fuse Box and Battery Switch Plasti-Dip Chrome Mirror Covers and All Badges to Black WeatherTech Bed/Tailgate Liner Replaced tailgate strut Working On Modifications: Add Oh Sh!t Handle To Driver Side A Pillar LED Head and Fog Lights
    Trying to decide between the Rough Country bolt on spacer/block 3” lift or the 3.5” lift that replaces the control arms and shocks.
    For my reasons to get a lift below, is the simple spacer/block kit OK, or should I spend another $400 for the more expanded kit?
    I have a 2WD, so my reasoning for wanting this lift:
    + Add larger tires
    + Give myself some more clearance for rutty, dirt roads.
    + I want the look of the raised truck and larger tires
    Simple Kit:
    https://www.roughcountry.com/toyota-suspension-lift-kit-872c.html?find=2015-toyota-tundra-2wd-738361
    Expanded Kit:
    https://www.roughcountry.com/toyota...6720c.html?find=2015-toyota-tundra-2wd-738361
  2. May 16, 2022 at 2:39 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
  3. May 19, 2022 at 11:12 AM
    MULLI63
    Southern California
    Any other opinions out there for comparison?
  4. May 19, 2022 at 11:13 AM
    MULLI63
    Southern California
    Thanks Half Assed. I had not even considered this, so will look into that option.
  5. May 19, 2022 at 11:13 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Spindle lift is 100% ideal for you
  6. May 19, 2022 at 11:22 AM
    kallen50162
    kallen50162 New Member
    I have a 2014 2wd. Here is what I did best bang for the buck.
    Bilstein 5100's front and rear. Front on lowest setting.
    Procomp 2.5'' front strut spacer kit. procomp 1" rear block
  7. May 19, 2022 at 11:25 AM
    kallen50162
    I was told to stay away from RC. I could fit a little larger tires but I had these tires from my previous truck.
  8. May 19, 2022 at 12:59 PM
    Half Assed
    Heartland Florida
    A spindle lift will keep the same suspension and steering geometry and ride as stock. That is why i recommend them.
    Hbjeff likes this.
