Blue Ribbon 4x4 Build Thread
Discussion in '2.5 Gen Builds (2014-2021)' started by BlueRibbon4x4, Jul 25, 2020.
  1. May 17, 2022 at 10:25 AM
    #601
    Aqualoon
    Aqualoon New Member
    2019 Tacoma Off-Road DCSB Cavalry Blue
    I still have many more mods and a couple miles to put on my Tacoma yet before I look at something else seriously. And yet another forum to get ideas from isn't the best idea, TW hasn't helped my credit card except on the cash back rewards.
  2. May 17, 2022 at 6:19 PM
    #602
    BlueRibbon4x4
    BlueRibbon4x4 [OP] Let’s color match it
    Geno
    2015 Blue Ribbon 4x4
    Finished up the rears. Gonna get a rock light pic later tonight.
    I got a rivnut tool and rivnuts for the fronts. For the longest I used just the plastic body pins. Mammoth suggests them as a mounting option, but they’re not the greatest. Once the rivnuts go in, they’ll be super secure. 2FE67E64-3B6A-4405-BC31-3A8C1CB2B530.jpg D55AF05F-EE6A-4C5E-8E04-8E987FA54583.jpg
    GODZILLA, GAknight, Aqualoon and 7 others like this.
  3. May 17, 2022 at 7:38 PM
    #603
    BlueRibbon4x4
    Geno
    Forgot this came in today! Gonna get rid of the oiled TRD filter. I never could tell how much oil to use. I was paranoid of over oiling and letting that crap in the motor. I think I’ll clean up the throttle body while I’m at it. ACE152A0-A377-4BEC-8DE1-D9636C4FB636.jpg
  4. May 17, 2022 at 8:29 PM
    #604
    BlueRibbon4x4
    Geno
    When the wife’s away, the dining table becomes a drying station.
    And a little rock light action. I rarely use them. They’re flickering on the blues. Hmm.
    B0537B6B-2962-4E6E-BE3C-AA79AAA8FEC6.jpg 29268824-857A-41B8-95E0-4CB68077CE5B.jpg 439C3E82-87DD-44DB-8857-17A84053665B.jpg
  5. May 18, 2022 at 1:45 PM
    #605
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    Fits like a glove
    BlueRibbon4x4[OP] likes this.
  6. May 18, 2022 at 4:21 PM
    #606
    BlueRibbon4x4
    Geno
    Thank you!
  7. May 18, 2022 at 6:54 PM
    #607
    BlueRibbon4x4
    Geno
    AFE dry filter installed, throttle body cleaned up. I cleaned it about 5 years ago, it was about as dirty as it was now. I installed the AFR dry filter because I didn’t like not knowing if the TRD was oiled enough or too much.
    The new filter sound is a little different than the TRD oil filter. When I installed the TRD instake from stock, the sound was immediately noticeable, and I recorded a 1 MPG increase overall. It had a deeper tone and was definitely louder. It complemented the TRD exhaust perfectly. When stomping on the pedal, deep tone came from the front and rear, making a nice balanced sound.
    This AFE filter is definitely louder than the TRD filter, but not as deep of a tone, I noticed. I don’t mean to be misleading, because I like it a lot. I switched between Tow Haul and normal, mashing the pedal and accelerating normally. It sounds great. If you’re stock now, the AFE filter will give a huge sound increase. MPGs will tell after time, but I doubt I’ll see any improvement over the TRD.
    Before:
    DEFAC977-0C24-4792-9E22-61905A2E7B4E.jpg F36E3681-4D5B-469F-9E06-6E2BD95E574A.jpg AEA51A74-325D-40F8-849E-97A847C1DAFB.jpg
    After:
    BCF58BEE-7948-435A-B932-0E222E559D9E.jpg 789FEA7C-9389-4F49-8E99-633F6B4310ED.jpg 73BE6D69-7816-4B3A-BB3B-03584C5C8711.jpg
    bulldog93, GODZILLA, GAknight and 4 others like this.
  8. May 19, 2022 at 11:54 AM
    #608
    rocsteady
    Dave
    New Jersey
    which part number, for the afe air filter, did you end up ordering? Little weird when I went to the site as they all look blue, not like the one you're showing above.
  9. May 19, 2022 at 11:58 AM
    #609
    RobertD
    Robert
    DFW, Texas
    https://www.amazon.com/gp/aw/d/B00I6ZBG22?ref=ppx_pop_mob_b_asin_title
    It defaults to showing the blue which is the oiled filter. Should have 4 options (oiled and flexible, oiled and rigid, dry and flexible, and dry and rigid)
  10. May 19, 2022 at 12:46 PM
    #610
    BlueRibbon4x4
    Geno
    As usual, @RobertD is correct.
    GODZILLA, HulkSmurf14 and RobertD like this.
  11. May 19, 2022 at 12:47 PM
    #611
    RobertD
    Robert
    DFW, Texas
    I only chime in on your thread when I know the answer!
    Like in this case we had already discussed the aFe filter via pm's but that is because I bought it first! Finally you are copying me hahaha
    GODZILLA likes this.
  12. May 19, 2022 at 12:57 PM
    #612
    BlueRibbon4x4
    Geno
    Haha! Yep, thanks for the heads up and giving me a reason to drop some cash. :thumbsup:
    RobertD likes this.
  13. May 19, 2022 at 6:33 PM
    #613
    BlueRibbon4x4
    Geno
    Front Mammoth guards installed.
    They are three pieces each side, and I had to make the top pieces from plexiglass as they were missing; I got the originals as a gift. I drilled out each mounting point to the correct size and installed a rivnut. This is my first time using this tool. I purchased it to mount relays and the like, and it’s freakin awesome. This may be something many people are familiar with, but I had never seen one till a few weeks ago. Short rundown: if you need to mount something to a flat piece of metal, you choose the correct size screw that will mount your product (relay). Then choose the rivnut that fits the screw. Drill a hole in the metal piece that corresponds to the rivnut. Drop the rivnut on the rivnut tool and clamp it in the metal. Screw your relay into the metal.
    My tool came with an assortment of zinc(?) rivnuts so I ordered some stainless ones along with the stainless screws. They’re from Amazon so hopefully they actually are stainless. It was so fast and easy, and the handles were short enough that I didn’t have to pull the wheels. These aren’t going anywhere.
    There’s gonna have to be a day when I grind all the paint of these. They’re rusting from under the paint, ugh. They had a horrible powder coat on them, and I didn’t get all of it off before painting the first time. Live and learn.
    BC106C61-8D8B-433A-85F4-44437D899C64.jpg FE207A8F-4F96-4A87-AF1D-A910518FC3BA.jpg CC488EE2-6729-4481-B876-44497EFD5EEE.jpg A2500F75-3441-447C-A662-D75AF3618944.jpg
  14. May 19, 2022 at 7:52 PM
    #614
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Tools are awesome! Way to use 'em!!
    RobertD and BlueRibbon4x4[OP] like this.
  15. May 19, 2022 at 8:07 PM
    #615
    BlueRibbon4x4
    Geno
    Yessir!!!
    HulkSmurf14[QUOTED] likes this.
  16. May 19, 2022 at 9:18 PM
    #616
    BlueRibbon4x4
    Geno
    Aaand the night lights. CB3EE62D-739F-4685-AF5D-604D56788032.jpgA6002ADA-DAE7-4C49-B4B0-AB00AE2E9A2B.jpgBEB1DFA6-A196-4983-A0E8-F9A46E3E79D9.jpg
    GODZILLA, GAknight, rocsteady and 2 others like this.
  17. May 25, 2022 at 4:59 PM
    #617
    BlueRibbon4x4
    Geno
    Getting ready for something new. I had thought of a switch controller, but I really wanted something custom that still keeps the sleek stock look as much as possible. These tiny buttons light up blue when pressed on, or can be wired so the lights stay on. B9AD5916-00E2-4C66-8CFA-7FE6FCAC32CD.jpg 53E84F6E-EB7B-41C9-8CBF-1F2BCF8AFD79.jpg BAC8531C-AEEC-4BEF-AB01-AA5DF4290DB2.jpg 9B1DC889-6AE0-4995-9B95-135B3909D4F9.jpg 3FBBCF40-E7D5-4061-AB7E-CF7B6DBA7AAF.jpg 94B8CF87-5DB6-4B31-B1F6-3AD42FD9EDA0.jpg 931A9117-FFA6-4B54-A052-647E0F1C680A.jpg
  18. May 25, 2022 at 5:22 PM
    #618
    Unstable_Trip
    Unstable_Trip New Member
    Tom
    North MS
    '14 Blue Ribbon SR5 DC 4x4
    This is awesome. I have similar buttons in my bed and under my hood to control those respective lights. I don't know why it didn't cross my mind to use it with accessories. I don't run that many accessories, but I'm stealing your idea..........again :rofl:. Just a different location. What size are those buttons if you don't mind me asking?
  19. May 25, 2022 at 5:34 PM
    #619
    BlueRibbon4x4
    Geno
    Thanks!! Steal it! That’s why it’s posted. They use a 1/2” mounting hole. They are listed in mm. They are freakin tiny. I ruined one already while experimenting how to solder and connect them. I just used tiny spade connectors.
    5PCS 12mm Latching Push Button Switch 5A 12V DC Pushbutton Switch 1NO1NC SPST ON/OFF Switch Black Metal Shell with Blue LED Ring Light, Waterproof Self-Locking Pushbutton Switch for 1/2" Mounting Hole https://www.amazon.com/dp/B08HYVFR2R?_encoding=UTF8
  20. May 25, 2022 at 6:02 PM
    #620
    Unstable_Trip
    Tom
    North MS
    Thanks! I believe the ones I have are 16mm, and I thought those were small. They fit perfectly in the holes already in the body though. I will end up buying the ones with wires already. Will be simpler for me :rofl:. Great job! Keep up the awesome work!
  21. May 25, 2022 at 6:06 PM
    #621
    BlueRibbon4x4
    Geno
    Thanks! I wanna see when you get em mounted!
  22. May 27, 2022 at 10:59 PM
    #622
    BlueRibbon4x4
    Geno
    They’re here! Thanks @memario1214
    They’ll have to wait. Currently in Vegas for a little trail time. 4DAEDAA9-2C13-496C-AEEC-DAAAC5A9FBB4.jpg
    GODZILLA, GAknight, Tundra234 and 5 others like this.
  23. May 28, 2022 at 7:56 PM
    #623
    BlueRibbon4x4
    Geno
    Had a kickass time at the Valley of Fire, north of Vegas. Learned that Mammoth Guards, when installed correctly, are not for off-road. We did some heavy shit this time and the mammoth guards pulled the screws right out. I need to figure something different now. C226B7E5-DB11-423D-ABD3-E4130040A473.jpgE7075B8E-2D2B-431F-8472-130B23B39E75.jpg1B99B415-B4BE-4F72-A86E-779B6052FE9C.jpg685FB0B5-F26C-4566-B37E-ED82BEA9FED4.jpg152D7257-7D89-420C-A0B2-7775067B1BF9.jpg
  24. May 28, 2022 at 8:06 PM
    #624
    RobertD
    Robert
    DFW, Texas
    Sucks they aren't for off roading but I'm sure you will make them better. How did the ones you fabricated do?
  25. May 28, 2022 at 8:51 PM
    #625
    BlueRibbon4x4
    Geno
    Still there!
    GODZILLA and RobertD[QUOTED] like this.
  26. May 30, 2022 at 10:07 AM
    #626
    BlueRibbon4x4
    Geno
    Starting work on the new SS3s. Working with @memario1214 was awesome. He answered all my questions so I could make the right decision on which lights would work best for me based on the type of off-road that I like. We went with one pair each of the Stage Series Driving and Floods.
    I made a new cross member from angle iron, and boxed in the sides and welded the seam. This way I could bolt it right to the mounts I made earlier for the old spotlights. The old spots will be on the outside of the new four SS3s. I spread out the six lights evenly and figured the best height. The soft bracket for the A/C lines had to be bent slightly downward, and I only need to move the tiny horn compressor to the same side as the winch controller and the rest should fit.
    I scuffed up the face frames of the new lights, hit them with self etching primer, and then the metallic cobalt blue. After they dry today I’ll mount them up, and then there’s a ton of electrical work to get everything going independently. Hooray!A99E684D-87E5-42F5-AA6B-6773552CA1EF.jpg916E6323-1A5F-4499-922D-382AA128A1BF.jpg992A62BE-0C42-427B-A876-D05381063903.jpg
  27. May 30, 2022 at 12:06 PM
    #627
    HulkSmurf14
    2014 Tundra Limited
    Sharks with laser beams! Badass per usual!
  28. May 30, 2022 at 12:16 PM
    #628
    BlueRibbon4x4
    Geno
    Thanks!!
  29. May 30, 2022 at 2:36 PM
    #629
    Unstable_Trip
    Tom
    North MS
    Looks good. Why does your paint look so much darker than mine lol. Mine looks light, the metallic has a strong silver look to it. It's weird. I'm also terrible at painting, so there's that :rofl:
  30. May 30, 2022 at 5:26 PM
    #630
    BlueRibbon4x4
    Geno
    I use the metallic cobalt blue for these internal mods. It’s lighter than the Blue Ribbon sonit can be seen better. That Blue Ribbon is crazy dark in the shade.
