Valhalla’s Shield theft deterrent/skid plates info and ordering post
Discussion in 'Valhalla’s Shield' started by Classy63, Mar 8, 2021.
Thread Status:
Not open for further replies.
  1. May 13, 2022 at 10:11 AM
    #4201
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Your welcome! I put a rock dome on every bolt. I also chose to not use the washer between the Rock dome and bolt head. I did use a washer under the nut though.
    rothmigo and HulkSmurf14[QUOTED] like this.
  2. May 13, 2022 at 10:13 AM
    #4202
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Good thinking and I will practice a similar install!
  3. May 13, 2022 at 10:46 AM
    #4203
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Any reason not to weld a metal donut around the bolt holes so a sawzall blade can't get to the bolt? They want 11 bucks each for those protective washers.
    Mike59 likes this.
  4. May 13, 2022 at 10:47 AM
    #4204
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I guess you could..... also think when you need to service certain parts that requires you to drop the plate then would that be more of a hassle to do? I don't know, I just did plain bolts and nothing else....
  5. May 13, 2022 at 11:07 AM
    #4205
    19TurdPro
    2019 Tundra TRD Pro
    The donut would be big enough to fit the bolt and appropriate socket for said bolt head to fit into, but not so big a sawzall blade can get underneath the head of bolt. Basically, I'd just be welding on those bolt protects, only less fancy, and without the taper.
    HulkSmurf14 and 1794TX like this.
  6. May 13, 2022 at 11:37 AM
    #4206
    1794TX
    Steven
    N.TX
    '20 1794
    I think someone with a gas powered hand-held 18" cutoff saw could still get through the bolt.
  7. May 13, 2022 at 11:47 AM
    #4207
    19TurdPro
    2019 Tundra TRD Pro
    With a tool like that it's probably easier to cut the cab off the frame to access the cats.
    jgullace, ATV25, Booney and 1 other person like this.
  8. May 13, 2022 at 11:48 AM
    #4208
    1794TX
    Steven
    N.TX
    '20 1794
    Nah, just flip the truck on its side. Easy peasy.
    ATV25 likes this.
  9. May 13, 2022 at 2:22 PM
    #4209
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    If someone is trying to grind or cut the heads off it will be quite difficult to get to the bolt heads if you use the large rock domes
    (I used the large domes from https://www.northridge4x4.com/part/...t-head-protector-for-skid-plate-systems-large)
    The Pentagon bolt heads are recessed inside and there is just enough room for the Pentagon socket to go in there. I didnt use any washers under the bolt head because the rock dome acts as the washer. I did use some nylon washers between the frame and the plate. Also put nylon washers between the two plates so it would keep any "creaking" down. Got them from HomeDepot. Just take the bolts in and figure out what size you would like. Here are some pics. I have to credit @1lowlife for the pic showing the socket clearance.
    rothmigo, Ray D, Booney and 2 others like this.
  10. May 13, 2022 at 3:21 PM
    #4210
    TBS
    TBS New Member
    I installed my valhalla skid plate and I have a question for the forum.
    How do you attach the bumper valance to the skid plate?
    I guess earlier in the design and in the install guide from @3rdTundra it mentions some 3/16-18x1/2 bolts going into some welded nuts. The design has changed and my plate did not have the welded nuts there. I was wondering what is now the preferred method of attaching the valance? If I wanted to go buy some hardware I noticed I can not get a nut into the channel to attach a bolt. Is there some hack I am not thinking of. Here is a pic.
    Thanks in advance.
    1794TX likes this.
  11. May 13, 2022 at 3:36 PM
    #4211
    1794TX
    Steven
    N.TX
    '20 1794
    I tucked mine under the skid before I cinched it down, and didn't use any fasteners. Several others did the same thing. Works fine. If that's not the route for you, it'll just be a matter of manhandling the thing.
  12. May 13, 2022 at 3:41 PM
    #4212
    TBS
    TBS New Member
    Damn. Now I will have to take the plate off the front tow hooks and reinstall... :annoyed:
    1794TX[QUOTED] likes this.
  13. May 13, 2022 at 10:11 PM
    #4213
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Those nylon washers are a GREAT idea..
    Going to do that when I install mine..
    Thank you
    ATV25 and WBW like this.
  14. May 13, 2022 at 11:24 PM
    #4214
    WBW
    WBW Resident lurker
    Bruce
    Well shit! If I ever take the shields down for any reason I'll be installing nylon washers as well. Great idea @TBS
    jgullace, 1lowlife[QUOTED] and ATV25 like this.
  15. May 14, 2022 at 10:51 AM
    #4215
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    A 3d printed adapter might work. Anything that impacts that high off the ground and hard enough to break it would probably be bad enough to demolish a stock shield anyway. After my plates come in if I come up with something I can share the file
  16. May 14, 2022 at 11:33 AM
    #4216
    TBS
    TBS New Member
    I was thinking maybe a fastener like this. It is only holding the valance up so maybe....
    https://www.amazon.com/25-Push-Type-Retainers-GM-20664092/dp/B0040CZ7PM
    Just checked the diameter with a drill bit and a 1/4 bit fits.
    I am off to the autoparts store to see what they have.
  17. May 14, 2022 at 2:48 PM
    #4217
    TBS
    TBS New Member
    Could only get a fastener in the center because the holes in the frame and the plate did not align. Here is a pic of the fastener I got from Advance Auto.
    This will have to do until I have time to take the front of the plate down so I can tuck the tabs between the frame and plate like @1794TX suggested.
    1794TX and HulkSmurf14 like this.
  18. May 14, 2022 at 6:22 PM
    #4218
    Classy63
    Classy63 [OP] Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    I experimented with plastic fasteners and I didn’t get any wins, I have attempted some stuff but I have an idea to use a flat fastener you put in from the top and screw a nut from the bottom
    Mike59, 1794TX and ATV25 like this.
  19. May 14, 2022 at 8:05 PM
    #4219
    TBS
    TBS New Member
    We all await the mad science design...:stirthepot:
    :popcorn:
  20. May 15, 2022 at 6:19 PM
    #4220
    engineer
    engineer Drive it 4ever
    Seattle, WA
    '21 Limited Double Cab
    I tucked mine in when I installed the skid plate... looks like the outbd tabs aren't too happy.
  21. May 16, 2022 at 7:40 PM
    #4221
    SwitchThrottle
    2021 Barcelona CrewMax
  22. May 16, 2022 at 8:14 PM
    #4222
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    "The waiting is the hardest part"
    (My laughing emoji won't work, but I got a good laugh after having to play the video for a bit to get it)
  23. May 16, 2022 at 10:17 PM
    #4223
    1lowlife
    DADA
    2014 MGM DC SR5
    I communicated with Tyler today.
    He got back to me tonight after me messaging him this morning.
    He's going to ship my rear plate tomorrow.
    I'm sure he is overwhelmed and I hate to bother him.
    But I've got to have my plates ready for when I get my truck back from the dealership.
    We're going on day 181.
    These plates are going on the truck the same day I get the truck back, even if I have to take a day off work to do it.
    I'm not driving and parking anywhere in DFW without these plates on it.
    So thanks Tyler.
    Looking forward to the 2WD V3 when it gets into production.
    I'd like to be one of the first to order, pay for, and wait for its arrival.
    But there will be no sense of urgency for it like I had for the plates..:thumbsup:
  24. May 16, 2022 at 10:30 PM
    #4224
    WBW
    WBW Resident lurker
    Bruce
    Any word on when your truck will be back?
    1lowlife[QUOTED] likes this.
  25. May 16, 2022 at 10:51 PM
    #4225
    1lowlife
    DADA
    2014 MGM DC SR5
    No, every month they say by the end of the month.
    Been saying that since January.
    I don't think they have a clue.
    It's now 35 Tundras and/or Sequoias waiting for cats on their lot...:eek2:
    Anybody on the fence, I'd order these plates.
    Might take less time to get them from other manufacturers, but I believe @Classy63 has the best coverage with the front, rear, and upcoming V3..
    What is the point of having cat shields if they don't protect the rear cats like Tyler's do??
    Booney and WBW[QUOTED] like this.
  26. May 16, 2022 at 11:13 PM
    #4226
    WBW
    WBW Resident lurker
    Bruce
    Amen!
  27. May 17, 2022 at 2:03 AM
    #4227
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    Got the cat stolen off our '21 Ram 2500 at work, Sat or Sun night. :mad:
  28. May 17, 2022 at 4:05 AM
    #4228
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Glad to hear you're getting you plate. I know you've been waiting a while for it. Unfortunately it looks like I won't be getting mine in rime for my trip. We're leaving on Saturday, so we'll have to take the wife's Highlander.
  29. May 17, 2022 at 4:38 AM
    #4229
    Is there not enough room for a bolt and nut? I would think that you would be able to use the same setup such as the RCI.
  30. May 17, 2022 at 7:05 AM
    #4230
    PapaT
    PapaT New Member
    2018 Tundra
    12 weeks and counting for me. It looks like more for some of the people on here.
    JerryH[QUOTED] likes this.
Thread Status:
