Rear ac
Discussion in '1st Gen Tundras (2000-2006)' started by zgurrola21, May 12, 2022.
  1. May 12, 2022 at 7:05 PM
    zgurrola21
    zgurrola21 [OP] New Member
    Zyan
    2001 Toyota Tundra SR5 TRD OFF-ROAD
    Hello, so on my 2006 tundra double cab, I have vents to the rear, i don’t feel any ac going to the back through those vents, am I suppose to do something specific to make the air go towards the back or is something wrong with the vents? Thanks
  2. May 12, 2022 at 7:17 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Try floor setting?
    Jack McCarthy and zgurrola21[OP] like this.
  3. May 12, 2022 at 8:00 PM
    zgurrola21
    Zyan
    I’ve tried that, didn’t seem to work, I also closed the 2 vents near the doors
  4. May 13, 2022 at 5:44 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    This may or may not help but the below pic shows the Vent layout from 1st Gen New Features for a 2004 DC which should be same for 05/06. It also shows the volume to each vent according to what position the mode is in.
    Do you feel the air mode knob is indeed functioning properly ?
    Have you had your center console out for any reason and accidently altered the plastic ducts going to rear footwells.
    The below is a thread where air controls were not working properly and controls binding was the problem.
    Vent Control Binding - Solved | Toyota Tundra Forum (tundras.com)
  5. May 13, 2022 at 7:41 AM
    zgurrola21
    Zyan
    oh this is awesome Thank you so much, I’ve never taken the center console off before but then again I did just purchase the truck about 2 months ago so maybe the previous owner did because the carpet looks like it was taken off before and I checked and all the controls work fine
    Mogo Gogo likes this.
  6. May 13, 2022 at 9:17 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Hmmm….as you can see from chart above concerning Foot only setting and on a scale of 1-5 volume of air wise….side, lower and rear face registers are a 1….defrost a 3 and footwell a 5. What do the other volumes feel like when in Foot position. It’s a tad time consuming but not difficult to take center console out in order to check the footwell plumbing but it would be my last resort. Just now checking mine, I can say without a doubt in Foot position, footwell has a 5 volume compared to the others 1/3 Volume
    zgurrola21[OP] likes this.
  7. May 13, 2022 at 10:08 AM
    zgurrola21
    Zyan
    I’ll try to footsetting, if not then I’ll most likely take off the center console to figure out what’s wrong
  8. May 13, 2022 at 11:21 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    If you decide to remove center console, you would know if what they did caused the issue. The below pic with the X is approx 2x4 rectangle plastic tube and the red arrows is simply where it heads to the footwell outlets.
    Holler if you need pointers in taking center console out.
  9. May 13, 2022 at 1:36 PM
    zgurrola21
    Zyan
    alright thanks man, yeah I’ll most likely take off the center console and check it out
    Mogo Gogo and BubbaW[QUOTED] like this.
  10. May 15, 2022 at 9:51 AM
    zgurrola21
    Zyan
    So I took off the seat and some other stuff and noticed their wasn’t the footwell ducts which goes under the seat, either the previous owner took them off or they never came with them but most likely the previous owner took them off or something so where could I purchase some ducts, i can’t seem to find them online and for the door panel vents to the back seats
  11. May 15, 2022 at 9:52 AM
    zgurrola21
    Zyan
    Where does the ac connect to get to the rear seats vents
  12. May 15, 2022 at 10:24 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Pretty sure someone has done some whacking on your Air Ducts.
    shifty` and des2mtn like this.
  13. May 15, 2022 at 12:15 PM
    zgurrola21
    Zyan
    Wow this is what I’m looking for thank you so much @BubbaW
    BubbaW likes this.
