Dobinsons greaseable shackles
Discussion in 'Suspension' started by Sumo91, May 14, 2022.
  1. May 14, 2022 at 10:47 AM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I installed the dobinsons greaseable shackles today, shoutout to @crikeymike from Exitoffroad for mentioning they were available, otherwise I might not have known. Got my shackles here in just a couple days.
    They're beefier than the stock shackles, and the pins are huge! I already had the dobinsons greaseable bushings installed, I had to knock out the sleeves I initially installed to fit the shackles. I'm pretty stoked I can finally grease the top bolt of the shackle, the grease pins they had available at the time when I installed their leaf springs weren't long enough for the top bolt, and the bottom bolt was only able to accept half of a nut, so I'm happy they have a complete shackle kit available.
    My only gripe is the grease zerks that are included. They're snub nose grease zerks, and no matter how hard and straight I hold my grease gun, it 90% of the grease would end up outside of the zerk. I have a brand new Lincoln grease gun, so that wasn't my issue. I ran to the hardware store and picked up some new zerks and they take grease very well.
    20220513_200905.jpg 20220513_200910.jpg 20220513_201347.jpg 20220514_111217.jpg
    Krewcial and crikeymike like this.
  2. May 16, 2022 at 6:24 AM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    Nice!! Glad you like them.
    That's weird about the zerks. All of the Dobinsons shackles use the same kind, and I haven't had anyone else report any issues. All of the Land Cruiser guys would be freaking if they couldn't grease their old 40's and 60's properly.
    Sumo91[OP] likes this.
  3. May 16, 2022 at 7:31 AM
    Sumo91
    TN
    I'm not sure if it's my grease or what. I have 2 grease guns (both the same, one of them brand new) and both of them had the same issue. I even mounted the shackle in my bench vise to really test it out. But zerks are cheap so it's not a big deal to me. It may just be the tip that comes with my grease gun
    Lincoln 1134 Extra Heavy Duty Pistol Grip Grease Gun, 6 Inch Rigid Extension, Dual Lip Follower, Variable Stroke Mechanism, 18" Whip Hose with Coupler https://www.amazon.com/dp/B0002NYDZ8
    Krewcial likes this.
  4. Aug 11, 2022 at 2:01 PM
    biggsy
    biggsy New Member
    Warren
    2010 Tundra DC Rock Warrior
    This is the route I’m going. Thanks for your feedback. So do the pins replace the metal sleeve due to its size? Also these shackles provide no lift right? I am looking for no(OEM) lift shackles. Thanks!
    Krewcial and Sumo91[QUOTED][OP] like this.
  5. Aug 11, 2022 at 2:06 PM
    Sumo91
    TN
    Yes. The pins replace the metal sleeves. And they provide no lift (the dobinsons leaf springs provide the lift, if you're installing them)
    Try greasing the pins before installation to make sure they take grease, it's easier to replace the zerks before install.
  6. Aug 11, 2022 at 2:07 PM
    AggiePhil
    College Station, TX
    Very interesting! Look into the Ironman greaseable shackles as well. That's what I went with.
  7. Jun 13, 2023 at 3:21 AM
    Krewcial
    Krewcial So good with my rod, I make fish come!
    Don
    2010 DC (3UR-FE) & 2000 AC (2UZ-FE)
    -Kings 2.5’s shocks -JBA UCA -Wheelers front bumpstops -Torque air bags with Daystar air bag cradles -Alcans leaf’s +700 lbs 1” lift -Dobinson grease-able shackles -TRD front and rear sway bars -RCI Engine, Transmission/Transfer Case skid plate -RCI Catalytic Guard -RCI sliders -Magnum ICI RT series bumpers -Auxbeam 72W Amber 4" round spot off road lights -Morimoto XB LED headlights -Level 8 MK6 +12 offset 18" rims wrapped with 285/75/18R Falken AT3’s with TRD centercaps -TRD dual exhaust with black chrome tips -AFE Power Magnum FLOW Pro DRY S Air Filter -TRD air accelerator -WeatherTech floor mats -Aftermarket Sequoia Grill -MAX Modular bed rack with tonneau brackets -Diamondback HD tonneau -James Baroud Grand Raid XXL -OVS 270 awning -11” Alpine iLX-F511 media receiver
    I agree the zerks are a PITA. I initially thought it was my new grease gun but after changing the zerks, they’re much better now. Glad I choose these shackles though to replace my CB +2. It allowed enough space for my full size 35” spare.
