3/0 lift/level?
Discussion in 'Suspension' started by Florida Man 82, May 13, 2022.
  1. May 13, 2022 at 5:39 PM
    Florida Man 82
    Florida Man 82 [OP] New Member
    2021 TRD Off Road 4x4
    Anyone go with 3 inches of lift in the front, no change to rear? I've currently got Bilstein 5100s at top setting, one .25" coachbuilder shim on driver side (for lean). Still a little rake. I'm considering going with a 3/1 lift but leaving out whatever the kit comes with for the rear but I wanted to see how that might look. Thanks.
  2. May 13, 2022 at 5:41 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
  3. May 13, 2022 at 5:48 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I think you’re chasing vanity. Just enjoy the truck
  4. May 13, 2022 at 5:52 PM
    Florida Man 82
    I want it to be level. Call that what you will. Nonetheless, enjoying it in the meantime. But could enjoy it more with some tweaking. We like to tweak around here . . .
  5. May 13, 2022 at 5:55 PM
    r1-superstar
    DB
    UTAH
    3/1.5 will give you rake
  6. May 13, 2022 at 5:57 PM
    Florida Man 82
    Thanks.
  7. May 13, 2022 at 7:04 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Usually 2 inches will look level on a tundra
  8. May 13, 2022 at 7:32 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    We like to twerk too...
  9. May 13, 2022 at 7:34 PM
    Florida Man 82
    I've heard. But as I mentioned in my original post, mine isn't level and I've got Bilstein 5100s on top setting with a shim on the driver side.
  10. May 13, 2022 at 7:35 PM
    Florida Man 82
  11. May 13, 2022 at 7:59 PM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    34699022-4C1D-41A6-8051-73A407D86302.jpg Mine is on 3/1. It’s pretty level.
    Florida Man 82[OP] likes this.
  12. May 13, 2022 at 8:30 PM
    r1-superstar
    DB
    UTAH
    3/1ish, yes. 3/2 = rake
  13. May 14, 2022 at 8:23 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    2 inch lift in front levels the truck.
  14. May 14, 2022 at 10:35 AM
    Florida Man 82
    (1) Perhaps take 15 seconds and read the original post in a thread before chiming in. (2) Every truck is different; 2 inches might level one truck, but not another.
  15. May 14, 2022 at 10:50 AM
    frichco228
    Frank
    Virginia
    Trying to help you and find that response aggressive. 2 inches lift in front levels the truck if stock and no suspension sag or issues. That is a fact, any variance on a good condition stock vehicle will me minor, 1/4 inch or less. If you lift 3 inches in front, then you need an inch lift in rear to level. Don't worry, I won't attempt to assist you again.
    CaptRussia253 likes this.
  16. May 14, 2022 at 10:57 AM
    Florida Man 82
    Please don't. I began my post by saying I've already lifted well over two inches and am not level. You telling me that you believe 2 inches would make me level is therefore completely unhelpful and infers that I am hallucinating or lying about my truck not being level.
  17. May 14, 2022 at 11:51 AM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Not sure what kit you are referencing with 3/1 level and just leaving out the rear
    Based on having your 5100’s at max and 1 shim might try this…
    From Coachbuilders site:
    ** Up To 2 Shims Can Be Used Per Side for 1.00” of lift, Bump stop extension kit is recommended.
    ** Tip: The Tundra Usually sits .50" lower in the front driver side corner, By using (2) shims on the driver side and (1) on the passenger side you're able to level the truck out left to right correcting the uneven stance. This product provides a 1:2 ratio and will measure .250" in actual thickness.
  18. May 17, 2022 at 3:30 PM
    Florida Man 82
    Thanks. I didn't have any particular 3/1 kit in mind, but would probably go with the Readylift.
    Alternatively, I've thought about just adding another shim to each side, but the suspension shop advised against it. I don't think it would be a problem, though.
    I'll probably just do a 3/1 lift and see how it looks, tweak as needed to get it "just right."
  19. May 17, 2022 at 8:13 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Coachbuilder also sells a 1” shim set…would be a solid 1” on the driver side and you could move the other coachbuilder shim you have now to the passenger side. Then sell the extra shim in the set and come out less than a 3/1 kit altogether. Just a thought
  20. May 19, 2022 at 4:34 PM
    Florida Man 82
    Thanks. I was considering this very solution. Might still do it. My only concern is that is that the suspension shop said don't. However, I can't think of why it would be a problem, at least if I put in a bump stop extension. And the alignment place said I could go up another inch each side without running into problems for alignment (even with stock UCA) or joint angles, etc. I'll probably give it a go. . .
