  1. May 12, 2022 at 6:01 PM
    PermaFrostTRD
    Northern NY
    Ok. Let me know if you want some images PMed
    Tundra234[QUOTED] likes this.
  2. May 12, 2022 at 6:16 PM
    KurdishNinjaPilot
    KurdishNinjaPilot New Member
    2016 Tundra SR5 4X4
    @Tundra234, Thanks
    yea I really like the wheels and Tire combo. I added the half inch bumper spacers last weekend, to stop some rubbing at limits when turning. unfortunately I still have some rub in the rear portion. I have tried the the heat gun method to the mud flaps but no, luck :(, everyone i talk to says " yup that's normal, you just have to live with it or replace the tires"
  3. May 12, 2022 at 6:23 PM
    Nice! This is my scooter lol.
  4. May 12, 2022 at 6:33 PM
    Beer Man
    Beer Man @cement.tundra
    2021 SR5 XP CrewMax Cement
    Did you use PPF behind your flares?
  5. May 12, 2022 at 6:34 PM
    Yep. :D
  6. May 12, 2022 at 6:38 PM
    KurdishNinjaPilot
    2016 Tundra SR5 4X4
    Beautiful, Love the bumper and bigger steps on the side.
    Waiting on some Anthracite Hyper dip for the front chrome delete and LED switchbacks. So I figured once I have the grill off I can look at fixing the headlight issue :fingerscrossed:
    Tundra234 likes this.
  7. May 12, 2022 at 6:59 PM
    Taco-Spike
    Two Trucks
    Night shots
    no map / no dome
    red map / red dome
    white map / white dome
  8. May 12, 2022 at 8:08 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    I'll be following this just out of curiosity. It's a bummer I wish I would have seen that sooner to get a set. That side chrome is really the only part I dislike about the stock tails, I don't mind the bright red (I'm so close to doing the hot tails A).
  9. May 12, 2022 at 8:11 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM
    Was gifted a set of bed rails off a used tundra at work. Had to run a thread cleaner through the bolt holes to clean out the spray in bed liner, only took about 30 min from start to finish. I always regretted not getting these when I bought the truck, happy to have them now!
  10. May 12, 2022 at 10:06 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Wash and dry at the self carwash this evening
  11. May 12, 2022 at 10:13 PM
    SAGE63
    San Diego County
    did this today....
  12. May 13, 2022 at 12:18 AM
    Brown747
    Brown747 New Member
    2021 Cement Crew Max LTD
  13. May 13, 2022 at 12:19 AM
    raspy87
    raspy87 New Member
    Andrew
    RI
    ‘19 DC SR5 Cement
    Beat me too it! :D
    Beer Man[QUOTED] and HulkSmurf14 like this.
  14. May 13, 2022 at 8:46 AM
    Explorer
    Explorer New Member
    Battle Ground WA
    2019 Silver Tundra SR5 TRD Offroad
    I have mine. I can scan them in and send you a file on Sunday when I get home from camping.
    RainMan_PNW likes this.
  15. May 13, 2022 at 9:26 AM
    That would be perfect...thanks!
  16. May 13, 2022 at 9:30 AM
    brevard828
    brevard828 New Member
    2021 Limited TRD Off Road
    Dump Post! I haven't posted in a while but I've been busy!
    I threw on a Backrack the other day. I've only ever had backrack brand back racks and I love them. However, they don'tf offer one for 2020 or newer on their website. They do have one for a 2019. I figured theyres no way they can be that different or that the beds changed. I called their customer service department and they said that they are in the process of designing one for 2020 and newer but have not released it yet. Me being me I ordered a 2019 and figured how different can it be. Also, i ordered the tonneau cover adapter for my bakflip.
    Well the only difference was that the "J" bolts were about an inch short. So i drilled a hole an inch higher in my stake pocket and it installed perfectly. I ended up not using the tonneau adapter plate and slid the distribution plate under the tonneau gasket. everything opens and operates very well.
    • I then installed the 5100's I've been waiting on. Middle setting, stock springs, no spacers, perfectly level, no rubbing at all on oem wheels.
    • Nitto Ridge Grapplers E1 275/70/R18.
    • Method MR305 NV Bronze are on order (month out on custom offsets):mad:
    • RSI Smartcap Evo Sport will be the next purchase, at which point I will be selling my tonneau cover and back rack. I would be open to trade for color match TRD sport grill/bumper covers as well.
    Just a quick update here are some pictures.
    Dirty but this is post 5100 level on middle clip.
    Oy3t6COEKIMNNOp9OChI3aH1jx-0G50NX1tk5ZEt_6968d2aa8d911def7ebfcb4c17b1fb4fb14fd632.jpg
    iTWnGdGe7ZmPZaUW4_pATN4Q8oCVqcQfVO_5C8Tc_eecb0efb023472d1048687bb2f2b9b4ce122315b.jpg
    Ran the valves on either side of the tag. I wanted to place them in the gas cap but i didn't like how the air lines would have to bend.
  17. May 13, 2022 at 10:04 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Well done fellow NC Tundra owner!
  18. May 13, 2022 at 10:32 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Installed a FRAC, front rear anytime camera, and it works beautifully. Install wasn't too bad, had some good instruction, a youtube video and excellent customer service got this thing rigged up. Great company to work with, with the premium camera this $200 mod seems just right to me.
    https://www.anytimebackupcamera.com
  19. May 13, 2022 at 12:28 PM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Currency converter= Earned to wasted dollars
    E7628647-F4E6-45AA-B552-4117A6B0FB7F.jpg 5D153D24-F7C6-49B4-B3F9-8EA154A67DD1.jpg 7B1DEE3C-009D-42CF-873A-AFA68A21CAEC.jpg
    Put some custom Alcan springs on and new Aluma shocks all around…. The Boys in the back think I got a rake problem…:eek2:.(they’re afraid to jump down now).. I may have to raise the front up a bit…:rofl: I’ll see if it settles first after I hook up the trailer…. Empty Ride is stiffer… but not bad.. I like it.. way more firm and solid feel.. especially on acceleration the back feels more responsive.
  20. May 13, 2022 at 1:46 PM
    AZTundra
    Paul
    Phoenix, AZ
    What type of suspension are you running in the front?
  21. May 13, 2022 at 2:03 PM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Aluma 2.5 with SPC UCA’s… The front coils are only set at 2.5”s… so there’s room to go up a couple of turns… but, once I get all my crap loaded back in and take the travel trailer for a trip or two.. I think it will settle a bit… so I may not have to adjust too much… Don’t get me wrong.. I like rake on the truck but right now with it empty.. its butt high.. :rofl:
  22. May 13, 2022 at 2:57 PM
    DiamondW
    DiamondW Stockblocker
    Kent
    CenTex
    ‘17 CM
    Got a little delivery today. They will go on the shelf until I figure out the rear setup and UCA’s…. But it’s a start :rofl:
  23. May 13, 2022 at 4:22 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    Took from inspiration from the chalk bag mod and added a molle dump pouch, in addition to the dual drink holders by the passenger floorboard
  24. May 13, 2022 at 4:35 PM
    Paulskie
    Paulskie New Member
    Paul
    2014 Attitude Black 1794
    SABM, TRD sway bar, interior LED swap, Husky's in front and WeatherTech in the back, TRD Pro Grill, Rigid Fod lights, Rigid 40" E-series, Rigid 32" hood light, BLHM with RX350/STI projectors, 4% tint, 50% windshield.
    How did you attached them?
  25. May 13, 2022 at 4:56 PM
    jackienguyener
    Jackie
    2016 Tundra 1794
    The dump pouch had two straps that I just tucked between the trim panels. The dual drink holders are attached to the carpeting via a BuiltRight tech panel
  26. May 13, 2022 at 6:18 PM
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    Installed sway bar! It’s so amazing just like everyone says. I took a round a bout at a much faster speed, almost felt like I was back in my BRZ.
  27. May 13, 2022 at 7:28 PM
    Wahayes
    Will
    2017 tundra limited
    Man i tbought it looked perfect lol
  28. May 13, 2022 at 7:29 PM
    Wahayes
    Will
    2017 tundra limited
    Starting to look like a bumper
  29. May 13, 2022 at 8:50 PM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    Lets not get carried away now.:cool:
  30. May 13, 2022 at 8:50 PM
    Enjoihavok
    Enjoihavok New Member
    Erik
    Chandler,AZ
    How do you help to avoid getting water spots from the Arizona sun/heat? You wash your truck at 7pm when it’s only in the 85-90 degree range.
