RRW wheels group buy---the RRW crew
Discussion in 'Wheels & Tires' started by TheBeast, Apr 15, 2022.
  1. May 11, 2022 at 6:40 PM
    #61
    DK1865
    DK1865 New Member
    Kansas City
    2021 WCP Tundra Limited
    Thought about going 35s but I'm trying to do the bear minimum to clear big enough tires without do a cab mount chop.
    Toe404 and TheBeast[QUOTED][OP] like this.
  2. May 12, 2022 at 7:48 AM
    #62
    VigTundy
    VigTundy New Member
    Josh
    2019 TRDSport 4x4 5.7L
    Anyone run these in the Bronze, Black ring with gold bolts on 35s? Specific i know but thats what I'm wanting to run on my Black TRDSport :cheers:
    Trying to decide if I'm pulling the trigger before ordering today.
  3. May 12, 2022 at 7:51 AM
    #63
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    That's my plan if I keep my order but on 37s and beadlock ring. My current order is for the wheels only but adding rings later
    Toe404 likes this.
  4. May 12, 2022 at 7:56 AM
    #64
    Mrf1987
    Mrf1987 New Member
    2020 Trd sport tundra
    I’m a big fan of these RRW’s. I have the RR7’s ran with the Beadlock rings. Zero issues out of them and they look great!
  5. May 12, 2022 at 7:57 AM
    #65
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Damn that looks good.
    Toe404 likes this.
  6. May 12, 2022 at 8:24 AM
    #66
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM
    looks amazing, cant wait till mine come in!
  7. May 12, 2022 at 9:14 AM
    #67
    TheBeast
    TheBeast [OP] The Beach
    I ordered the protection rings, imo it was a good deal because now you were hitting that 30% discount instead of 25%.
    I think it came up to $130 ish for 4 protection rings when you take into account the extra discount on the rims.
  8. May 12, 2022 at 9:17 AM
    #68
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    same here, im not a fan of the hardware though...if the protection rings had recessed bolt holes like the bead lock rings the hex hardware would look good, but when the hex head it just sitting flush on the surface of the ring it looks unfinished. im going to look for some button head allen bolts to replace them.
    831Tun and TheBeast[QUOTED][OP] like this.
  9. May 12, 2022 at 9:20 AM
    #69
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    So what you doing with your current wheels? Lol
  10. May 12, 2022 at 9:24 AM
    #70
    TheBeast
    winter set for now...;)
    Will mount M/T on those RRW..I think...
    fisherman951[QUOTED] likes this.
  11. May 12, 2022 at 9:25 AM
    #71
    fisherman951
    Tony
    2017 crewmax 4x4
    SoCal gets no winter, what you taking about lol
    TheBeast[QUOTED][OP] likes this.
  12. May 12, 2022 at 9:27 AM
    #72
    Mrf1987
    Mrf1987 New Member
    Just a heads up, The bolts that RRW sends is sub par. The gold parts will turn silver in no time and the bolts will corrode if exposed to harsh winter road chems. I plan on getting some Arp Bolts to replace mine but mine are holding up with weekly washes of the truck. Also remmeber to use anti-seiz on the bolts weather doing protection rings or beadlock rings
  13. May 12, 2022 at 9:28 AM
    #73
    white_pro21
    white_pro21 New Member
    2021 super white TRD PRO
    Super clean. Is it the gunmetal?
  14. May 12, 2022 at 9:28 AM
    #74
    Mrf1987
    Mrf1987 New Member
    Yes this is the gunmetal an thank you
  15. May 12, 2022 at 10:43 AM
    #75
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    this is going to sound stupid but can you use the bead lock rings as normal rings? as long as the bead is inside the lip it shouldnt be an issue right? I like the recessed bolts and machining opposed to the flat protection ring
  16. May 12, 2022 at 10:55 AM
    #76
    Mrf1987
    Mrf1987 New Member
    Yes you can there has been others that have done the same. The issue I have seen with it is there will be a gap between the ring and rim that can trap dirt rocks etc etc. Doing this also sets the ring further outside the tires which will put it closer to making contact with rocks etc if you wheel offroad frequently.
    Toe404[QUOTED] and TheBeast[OP] like this.
  17. May 12, 2022 at 11:02 AM
    #77
    GravityGear
    Aurora, CO
    You can put some OMF rock domes on there. Most protection rings are like that. They are laser cut flat steel to keep replacement costs down. They're not doing anything aside from absorbing damage.
    Toe404[QUOTED] likes this.
  18. May 12, 2022 at 11:03 AM
    #78
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Any idea on the bolt size specs?
    Toe404 likes this.
  19. May 12, 2022 at 11:05 AM
    #79
    Mrf1987
    Mrf1987 New Member
    They are M8x1.25
    Toe404 and reywcms[QUOTED] like this.
  20. May 12, 2022 at 11:08 AM
    #80
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    from looking at the pictures and assuming its metric they look like M8x1.25, but its hard to tell
    reywcms[QUOTED] likes this.
  21. May 12, 2022 at 12:21 PM
    #81
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    do you know what the bolt length is? im looking to get some button heads, I was guessing bolt length is about 20mm
    Mrf1987[QUOTED] and reywcms like this.
  22. May 12, 2022 at 2:36 PM
    #82
    Mrf1987
    Mrf1987 New Member
    This is the best i can give you. This is the bolt for the Beadlock rings not protection rings
    reywcms likes this.
  23. May 12, 2022 at 2:38 PM
    #83
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Hard for me not to say "Thats what he said"
  24. May 12, 2022 at 2:38 PM
    #84
    Mrf1987
    Mrf1987 New Member
    True to size not enlarged for her pleasure!
  25. May 12, 2022 at 4:10 PM
    #85
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    thanks man, I know the bead lock rings are 5/8" thick, and the protection rings are thinner at 1/8th inch thick, so I can get away using 20mm long bolts
  26. May 12, 2022 at 4:34 PM
    #86
    Audiolust
    Audiolust New Member
    2010 Tundra Limited
    Anyone have good recommendations on tpms sensors for these? This is my first Toyota, are they real finicky about the sensors used?
  27. May 12, 2022 at 4:45 PM
    #87
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    why not just transfer over your current ones, they fit OEM sensors according to the website
  28. May 12, 2022 at 5:05 PM
    #88
    Audiolust
    2010 Tundra Limited
    Going to sell my wheels as a package, still have a decent amount of tread on them, can probably recoup a decent Chuck of the cost of the RR7’s
    TheBeast[OP] likes this.
  29. May 12, 2022 at 5:34 PM
    #89
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    ahh ok, well I know at our dealership in the bay area each sensor is $126.00 and $190.88 to program, plus install, which if your doing at the time of tire mount and balance we only charge an extra 20 bucks or so. so thats a little over 720.00 not factoring in tax on parts. selling the wheels as a package might not save you much in the long run, id pull the TPMS out, stuck rubber valve stems in and sell like that.
    Audiolust[QUOTED] likes this.
  30. May 12, 2022 at 6:16 PM
    #90
    TheBeast
    costco charges $70 for 4 new tpms iirc if you buy tires from them and have them install/balance. Aftermarket tpms sensors.
    Toe404 and Audiolust like this.
