Possible To Delete Cats On The 2002 Tundra 4.7?
Discussion in '1st Gen Tundras (2000-2006)' started by 02tundradude, May 10, 2022.
  1. May 10, 2022 at 2:56 PM
    02tundradude
    02tundradude [OP] New Member
    2002 toyota tundra sr5 v8, auto, 4x4
    None
    Is There A Way To Delete Cats On The 2002 Tundra V8 Auto, 4x4 sr5?
  2. May 10, 2022 at 3:06 PM
    Yes. Anything is possible if you believe in yourself and try hard.
    and are willing to live with the consequences. Both mechanical and legal.
    You’ll have to fool the O2 sensors. You’ll have to not care that it’s illegal on your year model car equipped with Cats from the factory to operate it legally on the roadway without them. Most states you will not be able to pass inspection or smog.
  3. May 10, 2022 at 3:28 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  4. May 10, 2022 at 5:42 PM
  5. May 10, 2022 at 6:30 PM
    aelarson
    aelarson New Member
    AZ
    2021 1794 Tundra (Silver Sky Metallic)
    Just leave it parked on the street over the weekend in any large city and it will be done for free by Monday morning!
    DJenerated, Joro43, N84434 and 5 others like this.
  6. May 10, 2022 at 7:41 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    If theives wont steal early 1st gen cats, thats discrimination, and a hate crime. I was in houston for a month, and couldnt get anyone to steal em. and i know for a fact they couldnt see me hiding in the bushes with a ball peen hammer and sheet metal shears.
    I dont know if anyone ever got the electric simulators to work, but ive seen a couple get the spacers to work. I’ve been using doubled spacers on my titans rear o2’s for a few years now, no hassles.
    Crickle, Joro43, Darkness and 2 others like this.
  7. May 11, 2022 at 2:34 AM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    If one were to ignore smog, for example in my state of WA there is no emissions testing required, and ignore the P0420 check engine code, there is nothing mechanically wrong with simply cutting out the cats and welding in a straight pipe correct?
    To my understanding rear O2 sensors don't affect how our 1st-gen Tundras run. If so, the truck should run fine if you're OK with dumping even-badder exhaust fumes and with a constant Check Engine light.
  8. May 11, 2022 at 4:40 AM
    You throwing hammers at crackheads without me?
  9. May 11, 2022 at 5:19 AM
    See, ever since them Geto Boys left, H-town is beat.
  10. May 11, 2022 at 5:24 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    This thread gets my vote for "Thread of the Week":woot:
    02tundradude[OP] and bmf4069 like this.
  11. May 11, 2022 at 6:05 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Why do you want to do that? What do you think that you will gain, what's the benefit to you?
  12. May 11, 2022 at 11:46 AM
    02tundradude
    None
    @frichco228 My cats are currently on their last leg. My friend who's a tech at Toyota had plugged in the computer and watched my O2 sensors wavelengths after reving and going back to idle multiple times and he says the sensors after the cat are making it run rich and that the ecu is too stupid to throw a code. The cats werent doing there job and i'd eventually need new ones and i dont have the money to spend on New Oem Cats that you cant even get right now. I'm also open to the option of high flow cats. I'm in CA so god help me
    5N0W808 and Mogo Gogo like this.
  13. May 11, 2022 at 11:56 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Go get a pair of jy cats and weld em in. Bolt em in with flex pipe. Your call. Gut the factory cat housings and put spacers on the rear. Fine tune with drillbits. Rear o2’s wanna be cooler than the fronts. But not too much cooler. Older on/off cats could be done with a resistor, newer efi needs more, i think, but am not sure of. My titans gutted cats are using 2 spacers on each side and the first spacers got drilled too big. 2nds are drilled too, but further from the heat. I have long hill climbs to tune. Keep the light off under high heat and load. Dont let a thief cut it off, those shitstains cut the sensor wires sometimes.
    5N0W808 likes this.
  14. May 11, 2022 at 12:29 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    I'm unsure if you need to find a more qualified tech or if you possibly mis-understood. The rears do not play a part in adjusting air/fuel ratio. Their only function is to observe the efficiency of the CAT. That is one reason some have deleted/bypassed the rear sensor, it won't affect fuel trims.
    Air Fuel Ratio / O2 Sensor: how it works, problems, testing (samarins.com)
    DarkMint and Aerindel like this.
