Toyomafia - The Clubhouse. Balls and Burgers Summer 2025
  1. May 10, 2022 at 6:51 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I have it on good authority that it's this:
    GODZILLA, gosolo, Outbound and 4 others like this.
  2. May 10, 2022 at 6:57 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    oh....so just a room where a young man is shirtless doing work for my own enjoyment? i've never called it a furnace room
    GODZILLA, Leo's first, gosolo and 3 others like this.
  3. May 10, 2022 at 7:03 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I guess so. Missing a disco ball, eyeliner glitter, and feather boa, but otherwise fits.
    Does everyone up North have those? Does the house come with the shirtless man, or do you have to purchase that separately? What happens if one escapes? I have more questions.
  4. May 10, 2022 at 7:36 AM
    Outbound
    Aaron
    Northern Alberta
    Like a mini greenhouse thing? Not a bad idea. I'll have to look into it.
    I have an unfinished basement. No doors. My furnace/utility room has other important stuff in it too. Like a standup freezer with not nearly enough meat. I don't know if I want to finish out the basement either. I can get a 10 yard shot corner to corner, it's perfect for practicing my grouse shots with my compound bow. :D
    Accurate.
  5. May 10, 2022 at 7:42 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I keep mine stashed with the fur lined cuffs and the whips, under the bed
  6. May 10, 2022 at 7:46 AM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Yup! Something like this. I think I am going to make mine taller and A frame with hinges on both sides but you get the idea.
  7. May 10, 2022 at 7:51 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    We have multiple areas and various options.
    Our raised beds are incredibly productive. The most versatile I’ve found is having frame of arched plastic pipe with several parallel pipes that allow different types of materials to be spread and attached, like agrabond, plastic, and screen. I will take a few pictures in a bit.
  8. May 10, 2022 at 7:51 AM
    Outbound
    Aaron
    Northern Alberta
    That's a good idea. Something like that might let me get some stuff planted in April and protect it from the May snow.
  9. May 10, 2022 at 7:54 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I tried those and caution that if you fail to vent them open quickly when they get hit by the sun, the contents can wilt and fry pretty quick. They definitely will work, just have to pay attention.
  10. May 10, 2022 at 8:27 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My dad built vertical ones for his raised beds, which are against the house and garage.
  11. May 10, 2022 at 8:47 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I want verticals, but I'd have to buy something artsy, and probably cast iron to get it past the wife. the garage wall captured in the back yard gets tons of sun, and I have drip irrigation convenient to that spot too. it'd be a win, but i've been shot down on the idea too many times.
  12. May 10, 2022 at 10:56 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    The framework can stay all seasons. You can clip material all the way over and to the bottom, just on the top, or either side. Clips come in every size. Screen, plastic or shade cloth. Pex & pvc pipe
  13. May 10, 2022 at 10:57 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    :bowdown:
  14. May 10, 2022 at 12:00 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Not the best, for sure. But for someone who can use a screw gun and a hacksaw it’s effective and economical
  15. May 10, 2022 at 12:11 PM
    20GR8 Super
    Corey
    PNW Outskirts
    A welder that said an engineer had a good idea. :D
  16. May 10, 2022 at 12:21 PM
    Outbound
    Aaron
    Northern Alberta
    I take it back! I take it back! It's a horrible, no good, very bad idea and it will never work.
  17. May 10, 2022 at 12:38 PM
    20GR8 Super
    Corey
    PNW Outskirts
    It’s on the internet. It’s already been documented and has to be true.
  18. May 10, 2022 at 12:49 PM
    Outbound
    Aaron
    Northern Alberta
    In my defense, you didn't follow true engineer form and inform me that you were an engineer while presenting your idea.
  19. May 10, 2022 at 1:22 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Plus, we should add, maybe he’s not really an engineer, there was no folder of supporting calculations included…
  20. May 10, 2022 at 1:26 PM
    Outbound
    Aaron
    Northern Alberta
    This is a valid point. I haven't seen any spreadsheets either. He also doesn't end his posts with "Sincerely @20GR8 Super , P.Eng <---- see? I'm an engineer!"
    I don't see how my mistake of calling a bad idea a good idea can be held against me.
    landphil, GODZILLA, Hightide and 5 others like this.
  21. May 10, 2022 at 1:38 PM
    20GR8 Super
    Corey
    PNW Outskirts
    I’m not your typical engineer. I also have social skills.
  22. May 10, 2022 at 1:41 PM
    20GR8 Super
    Corey
    PNW Outskirts
    I just said it was an idea floating in my head at this point. :p You better believe that when it’s time to go to Home Depot that there is a drawing and cutlist that was made in a spreadsheet.
  23. May 10, 2022 at 1:42 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    And yet here you are in this thread. :rofl:
  24. May 10, 2022 at 1:42 PM
    Outbound
    Aaron
    Northern Alberta
    Too much contradiction in this post. "Typical engineer" and "social skills" go together like oil and water. :D
    I mean, us welders are a cantankerous bunch and not the ones to judge but still...
    landphil, GODZILLA, 1794TX and 5 others like this.
  25. May 10, 2022 at 1:43 PM
    Outbound
    Aaron
    Northern Alberta
    I guess Freud was right.
    GODZILLA, 1794TX, Hightide and 3 others like this.
  26. May 10, 2022 at 1:43 PM
    20GR8 Super
    Corey
    PNW Outskirts
    I will admit that I am not a P.E. Didn’t need it for what I do today.
    RainMan_PNW, GODZILLA, 1794TX and 4 others like this.
  27. May 10, 2022 at 1:44 PM
    Outbound
    Aaron
    Northern Alberta
    Oh, so you're partially human. We cool.
  28. May 10, 2022 at 1:44 PM
    20GR8 Super
    Corey
    PNW Outskirts
    Damn fat fingers and these tiny phone keyboards.
  29. May 10, 2022 at 1:45 PM
    20GR8 Super
    Corey
    PNW Outskirts
    I don’t need to burn any bridges. You never know when one might need a welding favor. :D
  30. May 10, 2022 at 1:45 PM
    Outbound
    Aaron
    Northern Alberta
    Agreed. I am looking for someone to design my deck for me. :D
    landphil, GODZILLA, 1794TX and 4 others like this.
