Winch Disconnect Questions
Discussion in 'Recovery & Gear' started by 300BLK, May 10, 2022.
  1. May 10, 2022 at 2:46 AM
    300BLK
    300BLK [OP] New Member
    2014 Tundra SR5 - Black
    Recently purchased an Engo 10k synthetic winch. I wanted to have a battery disconnect switch as well for safety purposes. I'm fine with a switch under the hood. Anyone have suggestions or examples of their setups?
    Per the specs max amperage is 370.
    I was looking at the Blue Sea Systems HD Switch. Its rated to 600A continuous. But is this overkill? Most other switches seem to have high intermittent amp ratings but lower continuous amp ratings and I dont want to risk melting the unit. For instance the Fastronix Solutions 2 post switch is rated at 180A Continuous or 1000A Intermittent and i've seen a number of people use them for their winches of all sizes.
    I DIY everything but electrics are my weak spot, so any advice would be appreciated. Thanks!
  2. May 10, 2022 at 5:18 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    I found one on Jegs that I really liked. Can't find it now as I search their website of course. It is rated at 300amp continuous, and up too 1000 amp spikes.
    When I get home this evening, I will see if I can find the part number.
    Not fully wired in yet...
    300BLK[OP] likes this.
  3. May 10, 2022 at 6:11 AM
    300BLK
    That would be great if you could find the part number. Thanks for the info
  4. May 10, 2022 at 6:20 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I have found with electrical over the years, that overkill in the camp of safety is NEVER a bad thing.
  5. May 15, 2022 at 3:02 PM
    badmotofing3r
    badmotofing3r To be so civilized, one must tell civil lies
    Zach
    Wyoming
    Hot Tamale
    Toytec lift and the works
    I went with a BlueSeas switch. Can’t remember the model number. Mounted next to my winch pack on a custom plate my friend made for me.
    clarkritchie and 300BLK[OP] like this.
