  1. May 9, 2022 at 10:16 AM
    Taco-Spike
    Two Trucks
    Is it covered at least? with a blanket? :p
  2. May 9, 2022 at 10:25 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    In the garage.
    Taco-Spike[QUOTED] likes this.
  3. May 9, 2022 at 11:22 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    I like it! What’s your suspension setup?
  4. May 9, 2022 at 1:51 PM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    So with those rear leafs you can jump the truck, baja style with a sherman tank in the bed?
  5. May 9, 2022 at 2:06 PM
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    Drained and filled the transmission fluid. I also ordered a new power steering pump and belt from Toyota. Pretty annoyed that my pump is whining so bad at only 50k. Tried all the tricks to fix it with no success.
  6. May 9, 2022 at 2:09 PM
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Eibach Stage 1, Pro LED headlights, RCI engine skid plate, Retrax MX tonneau, Ranch Hand front bumper.
    Installed these quick release brackets and strap to hold my propane/fuel containers bedside. Purchased from etrailer.com. Install was pretty easy, worst part was removing the rear wheel liner clips. Ended up breaking three.
  7. May 9, 2022 at 2:21 PM
    someguyinhtx
    someguyinhtx 2018 Lifted 4x4 CM
    Lifted 2018 Black 4x4 SR5 Crewmax
    6" Pro comp lift
    Quick weekend projects:
    Red tow hooks activated and retro TRD emblem on.
    Had to fab a backplate for the TRD emblem and still need to work on it. It isn’t as seamless as I want it to be yet.
    DoctorBAH, GAknight, nhw544 and 7 others like this.
  8. May 9, 2022 at 2:54 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Finally decided to install some off brand fender flares. Turned out pretty good.
  9. May 9, 2022 at 2:58 PM
    Did you add PPF behind them?
    1794TX and Jim LE 1301 like this.
  10. May 9, 2022 at 3:09 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Honest question;
    Do you own stock in any PPF companies?
  11. May 9, 2022 at 3:10 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    That's the plan. We've got a Baja trip in Jan with a group but also just trying to keep up with the old mans rig.
  12. May 9, 2022 at 3:31 PM
    No. Just mentioned it because the flares ate through my paint on my 2013.....took a little bit off of my selling price because of the needed paint repair.
    Bama, rocsteady and NewImprovedRon like this.
  13. May 9, 2022 at 3:32 PM
    :thumbsup:
  14. May 9, 2022 at 3:45 PM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    Changed my front brake pads at ~42K miles.
    Taco-Spike and reywcms like this.
  15. May 9, 2022 at 3:59 PM
    SAGE63
    San Diego County
    While at T2S hit 20k miles...
  16. May 9, 2022 at 5:42 PM
    NIOSH
    NIOSH New Member
    2021 1794 CrewMax Army Green
    ELKA, 35", Harrop, lockers w 4.88
    Nice,. Those clips are a PIA so I just break em and replace them makes the job go faster while retaining my sanity.
    Rexka 30pcs Fender Liner Screw Grommet Compatible with Toyota Lexus 90189-06236 Highlander Prius Tundra LC500 RC200t RC300 RC350 https://www.amazon.com/dp/B07H8923D4?_encoding=UTF8
  17. May 9, 2022 at 5:44 PM
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Those are the exact replacement clips I ordered this afternoon. Otherwise I’m loving the setup. Thanks for the idea @NIOSH
  18. May 9, 2022 at 6:01 PM
    Wahayes
    Will
    2017 tundra limited *sold*
    How do you like those swing outs? Im thinking of getting some
    BlueRibbon4x4[QUOTED] likes this.
  19. May 9, 2022 at 6:09 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I really like them. I got them used, so I had to replace a couple rubber bumpers on them. But they make some noise on the trails. Others have said that theirs makes no noise. I may have to adjust a few things to get that result. But they’re super handy. All my recovery gear is in them.
  20. May 9, 2022 at 6:21 PM
    Wahayes
    Will
  21. May 9, 2022 at 6:28 PM
    Wahayes
    Will
    What brand are they?
  22. May 9, 2022 at 6:54 PM
    GandalftheGrey
    GandalftheGrey New Member
    2014 Tundra Platinum CM
    Finally got around to putting on my OEM color matched mirror caps! Way better than chrome.
    Also installed my magnetic phone mount. Super clean, easy install and holds well.
    Steve66, jgullace, GAknight and 5 others like this.
  23. May 9, 2022 at 7:04 PM
    BlueRibbon4x4
    Geno
    They’re the brand name Undercover Swingcases. I scraped off the labels.
  24. May 9, 2022 at 8:10 PM
    Wahayes
    Will
    I sanded and polished the oxidation and (most*) the scratches out of my headlight lenses.
    rebmo, Velocity72, bulldog93 and 10 others like this.
  25. May 9, 2022 at 8:43 PM
    Beach Toy
    Beach Toy New Member
    SE NC
    2017 White SR5 4x4
    Lomax cover, TRD PRO headlight conversion...so far anyway
    What did you use on your headlights?
  26. May 9, 2022 at 8:51 PM
    Taco-Spike
    Two Trucks
    Course motor sports?
    I got one for free for my Tacoma. They reached out to me to do a review. I like it on my Tacoma. I’ve been hoping they reach out to me to a free tundra one….
  27. May 9, 2022 at 9:03 PM
    Wahayes
    Will
    Turtlewax headlight restoration kit. Its only 10 bucks at home depot. Worked good. It just polishing compound and sanding pads 4 differing grits but at that price you cant buy all of it cheaper. My passenger light was pretty bad with bush scratches and oxidation, it polished it out well
    Our headlights are bad enough, i dont need hazy plastic making it worse lol
    bulldog93 likes this.
  28. May 9, 2022 at 9:29 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    No I did not. When this truck looks like shit and is no longer drivable, I'll simply buy a new truck. The benefits of being financially secure and retired!!
  29. May 9, 2022 at 9:35 PM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Man do I need to do that to mine. They're driving me nuts.
  30. May 10, 2022 at 5:24 AM
    Beach Toy
    SE NC
    2017 White SR5 4x4
    Fact!
