TRD Pro Grille Installed! Do I need this?
Discussion in '3rd Gen Tundras (2022+)' started by ByeF150HelloTundra, May 9, 2022.
  1. May 9, 2022 at 10:15 AM
    ByeF150HelloTundra
    ByeF150HelloTundra [OP] New Member
    DFW
    2022 Tundra SR5
    image.jpg Will share some pictures tonight. Do I need this thing in front of the radiator? Wouldn’t fit with the light bar
  2. May 9, 2022 at 10:17 AM
    Taco-Spike
    Two Trucks
    I'm sure it will run without it?
    EDIT: ?
    =JSG= likes this.
  3. May 9, 2022 at 10:22 AM
    montera.built
    montera.built New Member
    Jordan
    2022 AG Toyota Tundra TRD Offroad
    Not true ^^. You're going to get either a CEL or warning messages on your dash. Those are the grille shutters and are important for heating the engine/turbos on cold starts or cold weather by closing off air flow and trapping heat in the engine bay.
  4. May 9, 2022 at 10:28 AM
    Taco-Spike
    Two Trucks
    I had a 50/50 chance. Just looked like plastic to me.
    But good to know that
    montera.built[QUOTED] likes this.
  5. May 9, 2022 at 10:30 AM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Thanks! Just gotta go pick up some spacers so I can get it installed.
  6. May 9, 2022 at 10:47 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    You need that louver system in there for sure, it will keep the engine warm in the winter. Climate depending I guess….
  7. May 9, 2022 at 11:01 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    This is what I was worried about when seeing the TRD Pro Grille. I assumed there would be fitment issues with the active grill shutters. I'm glad to hear that a simple fix like spacers might solve the issue. :fingerscrossed:
    Definitely take tons of pics. I'm curious how the shutters line up on the front of the grill...especially if you're leaving the light bar area open for now.
  8. May 9, 2022 at 12:54 PM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
  9. May 9, 2022 at 8:26 PM
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
    2022 Tundra Platinum
    did you end up getting the spacers?
  10. May 9, 2022 at 8:33 PM
    biebs96
    PA
    looks incredible
  11. May 9, 2022 at 8:43 PM
    3Gen4x4
    3Gen4x4 New Member
    22 Tundra SR5 TRD OR
    Mind giving the part number and how much did you pay for everything? That is incredible.
    was it pretty much plug and play?
  12. May 9, 2022 at 9:57 PM
    Brums
    Brums New Member
    Bethel, OH
    22 Tundra DC TRD Sport
  13. May 10, 2022 at 12:26 AM
    Swarley
    Swarley New Member
    Looks awesome
  14. May 10, 2022 at 7:04 AM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
  15. May 13, 2022 at 5:41 AM
    sparky412
    sparky412 New Member
    SW Pennsylvania
    22 SR5 OR CM 6.5 MGM
    So my question would be some trims come not equipped with the active shutter so if you remove it I don’t see what the issue would be
  16. May 13, 2022 at 6:43 AM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    I removed mine and got a check engine light, so I put it back.
  17. May 13, 2022 at 6:43 AM
    vosaeroplane
    vosaeroplane New Member
    2022 Tundra SR5
    You must be thinking of the air dam.
    KroppDuster likes this.
  18. May 14, 2022 at 8:48 PM
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    The TRD pro doesn’t have the shutters. I’m hoping my hybrid platinum doesn’t
  19. May 15, 2022 at 6:11 AM
    Chrlsone
    Chrlsone New Member
    Charles
    2022 MGM Platinum Tundra
    Because if it doesn't have something from factory, then there is no sensor telling it is missing. If it has that part from factory and you remove it then you could get a cel to come on for not working properly.
