Wheel offset question, I need explaining
Discussion in 'Wheels & Tires' started by Jmccracken1214, May 8, 2022.
  1. May 8, 2022 at 3:11 PM
    Jmccracken1214
    Jmccracken1214 [OP] New Member
    2015 Tundra CM
    Running a 3.5” lift, I have 285/75/18 tires on fn wheels 12mm offset.
    I was thinking of replacing the tires with 35x12.5, and after looking at the clearance I have from the body mount, about .75”-1”, I’m wondering if the wider tire will hit with my current offset.
    Am I understanding this correctly, if I go to a wheel with a 25mm offset, would that give me a little more clearance at the body mount than a wheel that sticks out more?
  2. May 8, 2022 at 6:07 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    It may give you some more room to play, but it's hard to tell. I'm guessing you haven't done a BMC?
  3. May 8, 2022 at 6:08 PM
    Jmccracken1214
    2015 Tundra CM
    I have not. It doesn’t need it currently and I’ve seen guys running the same lift clear 35’s with certain wheels
  4. May 8, 2022 at 6:17 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
  5. May 8, 2022 at 6:20 PM
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
