1/0 or 2/0 for Big 3 upgrade?
Discussion in '2nd Gen Tundras (2007-2013)' started by tbone75, Apr 30, 2022.
  1. Apr 30, 2022 at 1:35 PM
    tbone75
    tbone75 [OP] New Member
    2007 White Tundra TRD
    I ordered everything from "The big 3/4" upgrade post (nicely done), but I have an additional question, actually two. I ordered all 1/0 wiring and now I'm thinking I should send it back and get 2/0 in it's place (only 15.00 more), thoughts? I wonder if it's over kill or worth while since I'm doing it all and the price is not much different. Also, for those who have tackled this project how long did it take? My Tundy is my only vehicle and I need to factor that in when planning.
    I was looking at an LActrical 300amp alternator on Amazon (https://www.amazon.com/dp/B07Z5FS6WV?_encoding=UTF8)
    I know it's no 600.00 DC Alternator but maybe it's better than stock? Any opinions would be much appreciated -Thanks!
    One more thing, I was thinking of doing the diode upgrade, since I'm dropping in an ODYSSEY 31 AGM Battery (1150cca), too.
    NueveTundra and nopsFU like this.
  2. Apr 30, 2022 at 1:54 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    NueveTundra, tbone75[OP] and 831Tun like this.
  3. Apr 30, 2022 at 4:03 PM
    tbone75
    @Cruzer I just read your write up and I must say that makes things sooooo much clearer on what I need to do. Feeling much confidence now. So, I'm sending back the 1/0 and getting the 2/0 for the LAlectrical 300amp alt. The kit I ordered is 10ft black 10ft red, I'm thinking that should be enough with some to spare. Can you recall how long this whole process takes? Are you running the GM diode upgrade after this? Thanks again man...
    NueveTundra and Cruzer like this.
  4. Apr 30, 2022 at 5:22 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Yeah I have the GM diode on and it hits the right 14.5 volts. I think it took about an hour to upgrade the cables. 2 hours for the alternator swap.
    NueveTundra likes this.
  5. May 7, 2022 at 7:53 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    I'm still running 1/0 with mine. :)
    Cruzer likes this.
