Tail light gaps
Discussion in '3rd Gen Tundras (2022+)' started by Jason Coffin, May 4, 2022.
  1. May 4, 2022 at 11:01 AM
    Jason Coffin
    Jason Coffin [OP] New Member
    22 tundra limited 6.5 white
    Running boards
    D28BBF42-D562-48A1-A7D2-39734FACDC78.jpg So i have. Gap at the top passenger sidetail light. Toyota want to replace the whole bed side !!! To fix the tail light. More recently I noticed the drivers side is starting to gap as well. Before i give them my truck. Was wondering if anyone else has this issue?? Thanks. Jason.
    Troyboy84 and ryanwgregg like this.
  2. May 4, 2022 at 11:23 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Welcome to the site.
    Can you please post a pic of what you are referring to?
    Jason Coffin[OP] likes this.
  3. May 4, 2022 at 3:24 PM
    Jason Coffin
    Running boards
  4. May 4, 2022 at 3:40 PM
    Kagisexton
    Kagisexton New Member
    Christopher
    2022 Tundra Platinum
    Mine looks the same way, are you sure it isn’t this way just by design?
  5. May 4, 2022 at 5:00 PM
    hivetyrant
    hivetyrant New Member
    2022 Limited Tundra
    I have no idea what we're supposed to be looking at
    Leonidas514 likes this.
  6. May 4, 2022 at 6:17 PM
    Chrlsone
    Chrlsone New Member
    Charles
    2022 MGM Platinum Tundra
    The corner of the tail light where it comes to a point. There is a gap between it and the beside.
  7. May 4, 2022 at 6:20 PM
    Breathing Borla
    Northern Illinois
    To me , looks like they light is cut spot on but the seal strip is a touch off.
    Not sure this one is to complain about unless moisture is penetrating the lens.
    that’s just from the pics though , so could be off if it looks different live
  8. May 4, 2022 at 9:08 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Looks fine to me. If you have a Gen 3 and this is the only problem, you hit the lotto my friend.....trust me, I'm getting put through the wringer with this truck!
  9. May 4, 2022 at 9:16 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^ Post of the day..
  10. May 4, 2022 at 9:23 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    The taillight comes to a sharp point that the body can’t make, mine looks the same there’s no problem be happy
  11. May 5, 2022 at 7:10 AM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    Feels like a stretch to complain about that. I agree with the others, if you have to look this hard to find an issue than you got a good one. I wouldn't let the dealer touch it. It can get worse!
    Jason Coffin[OP] and Donas like this.
  12. May 5, 2022 at 7:26 AM
    nodak67
    nodak67 New Member
    JR
    thats a weather seal issue. it looks like the weather seal at the point retracted. might want to look to see if the weather seals was properly latched to the light assembly at the point. there should be a very small notch for the seal to wrap around to keep the seal in place (i am speculating)
  13. May 5, 2022 at 9:58 AM
    Jason Coffin
    Running boards
    653DAE38-566D-4DC9-B6B4-51F5AAD2A433.jpg CC4BC44D-5340-4157-AA09-CAA540EF96C1.jpg 653DAE38-566D-4DC9-B6B4-51F5AAD2A433.jpg I got to see another example yesterday. Looks like a common defect in my opinion. Thanks for your input. Need a couple more pictures to share with the dealer. If someone could take similar pictures I would appreciate. Thank you all.
    I will share the positives of owner this 3 rd gen. Or turd gen. Hahahah
  14. May 5, 2022 at 10:00 AM
    Jason Coffin
    Running boards
    Im going to have to check it out myself. They scratched my truck last time they were messing with fitment
  15. May 5, 2022 at 1:26 PM
    Kagisexton
    Christopher
    maybe you are onto something, my truck has a big gab like yours, looks nothing like the gray one in that pic.
  16. May 5, 2022 at 1:29 PM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    I have window trim gap too
  17. May 5, 2022 at 2:10 PM
    Jason Coffin
    Running boards
    I had my passenger side back door replaced and my front doors replaced. The front doors were fixed but the back gasket is still a problem
  18. May 6, 2022 at 3:50 PM
    Chrlsone
    Chrlsone New Member
    Charles
    Here's mine it looks worse when you take close up picture compared to stay away from it and just looking at it.20220506_173049.jpg
  19. May 6, 2022 at 5:33 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    You’d be a fool to have them replace a bedside over that. Cutting grinding and welding done by the low a man on the totem poll because warranty work doesn’t pay well enough for the top guys to mess with.
  20. May 6, 2022 at 6:02 PM
    Jason Coffin
    Running boards
    Exactly why i put the brakes on the dealer. Its a plastic bedside. Bolt on now. But the mounting point is not even part of the bed.
    Jbehredt[QUOTED] likes this.
