Lost fill hose in front diff
Discussion in '2.5 Gen Tundras (2014-2021)' started by Terndrerrr, May 6, 2022.
  1. May 6, 2022 at 11:13 AM
    Terndrerrr
    Terndrerrr [OP] 924000 miles to go
    Music City
    6UR-FE
    Title says it all. I was filling my front diff, and the 6” plastic hose popped off the end and into the differential. I can’t reach it with fingers (they won’t fit) or with needle nose pliers.
    It’s 100% my fault; I shifted my arm while squeezing the Amsoil 75W-90 bag, and I truly thought that plastic hose was seated on the bag nozzle. I wiggled it after putting it on, and it seemed stuck on there really well. But apparently not. I should have duct taped it, and now I get to reap the rewards.
    Guess I have to take it apart, huh? :frusty::frusty::frusty::frusty::frusty:
    EDIT: Or maybe I could remove the drain plug and see if I can reach it through that. I can’t get back to it till this evening. We’ll see. Won’t be using 4x4 until it’s out, obviously.
  2. May 6, 2022 at 11:26 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I would definitely give the drain plug route a shot. Maybe you can blow some air from the top to see if you can move it near the drain plug. Good luck.
    Terndrerrr[OP] likes this.
  3. May 6, 2022 at 11:27 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Remove fill and then drain plug, let it drain out and maybe the hose will get close enough to the drain to grab it or draining may make it poke out. Try cutting and bending a wire or clothes hanger to the size and shape you need to push it from the fill hole, pull it from the drain. Other than that, remove front diff cover, get it out and reseal.
    That does suck, 10 minute job turns into a spectacle....been there!
    bulldog93 and Terndrerrr[OP] like this.
  4. May 6, 2022 at 11:28 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Time to go fishin with a coat hanger or baling wire
    snivilous, DZ_ and Terndrerrr[OP] like this.
  5. May 6, 2022 at 11:31 AM
    Terndrerrr
    Music City
    6UR-FE
    Thanks for the replies. I thought about the coat hanger thing, but not blowing air to try to make it fall. I will be trying both for sure.
    Njmike13 likes this.
  6. May 6, 2022 at 11:41 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
  7. May 6, 2022 at 11:45 AM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    4wd or 2wd, the diff turns when the truck moves. So if you drive it without removing the tube, it will probably end up in the gears.
  8. May 6, 2022 at 11:55 AM
    NoRcptn
    NorCal
    2017 Platinum
    Mater, DZ_, badmotofing3r and 2 others like this.
  9. May 6, 2022 at 12:02 PM
  10. May 6, 2022 at 12:11 PM
    1794TX
    Steven
    N.TX
    '20 1794
    Thank you for posting this. Not to pile on, but your hard learned wisdom is now my simple knowledge. Get a hose too long to lose in the diff.
    Hoff, RainMan_PNW, DZ_ and 7 others like this.
  11. May 6, 2022 at 12:26 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    90 degree needle nose pliers or something similar? Pull drain plug would be worth trying too.
  12. May 6, 2022 at 1:06 PM
    Cajun1977
    Cajun1977 New Member
    Shawn
    Northwest Arkansas
    2020 CM TSS
    Level lift Tonneau cover
    Dont feel to bad. Couple months ago I was cutting zip ties under my seat that I used to route a wire. Well in a hurry I cut my yellow wire to the airbag. $1100 learning moment.
  13. May 6, 2022 at 1:11 PM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    The worst! Turning a job into a harder job because something went sideways. I've found it's usually something that you would have trouble doing again even if you were trying to duplicate the issue. All of these could be solved with the life "ten second rewind" button that I'm trying to invent.
    KeithH, WILLINH, Ely010606 and 4 others like this.
  14. May 6, 2022 at 6:59 PM
    Windsor
    Homeless in Oregon
    Some.
    Can you do a 10yr also?
  15. May 6, 2022 at 7:07 PM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    Thanks for posting this. I could see myself doing that in a second and will now be careful in the future. At least you were pumping in the good stuff.
    Hope you can get it fixed without too much trouble.
  16. May 6, 2022 at 7:08 PM
    Terndrerrr
    Music City
    6UR-FE
    Ok, so I looked into that thing, and it appears to be too big. So I found a decent endoscope and flexible grabber off of
    Amazon that will show up in the morning.
    I am VERY skeptical that I will be able to get it. I really don’t want to drop the diff just to open the cover. But it seems like that is what I would have to do.
    Maybe I’ll just order 5.29s and lockers and drive it as is until I can get a shop booked to do the install. :bananadance::bananadead:
  17. May 6, 2022 at 7:12 PM
    Terndrerrr
    Music City
    6UR-FE
    I should have used a long hose for sure. I didn’t have one, and my wife was gone, so I could go get one. I remembered that the 75W Ravenol bottle that I used for the TC came with a little extendable hose attached to the bottle. Popped that little hose off, smashed it onto the Amsoil nozzle, checked that it was snug, and off I went.
    All it took was a slight shift of my arm as I was lying on my back under my truck to pop that stupid little hose off right down the fill hole. FML
  18. May 6, 2022 at 7:40 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I use a 200cc Mighty-Vac syringe. Suck it out of the jug and squirt it in the front diff. I can’t imagine the look on your face as you watched the little tube slide in there! Hope you get it out man.
    vtl and Terndrerrr[OP] like this.
  19. May 6, 2022 at 7:58 PM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    Man this sucks. I just lost the plastic cap from one of those squeez packs in my front diff. Forgot to pull it off before I put the nozzle in the fill hole and it fell right in. I was able to use an inspection scope, move it toward the drain plug and flush it out. 10 minutes job done in 5 hours. Good luck to you.
    Mater and Terndrerrr[OP] like this.
  20. May 6, 2022 at 8:22 PM
    Wahayes
    Will
    2017 tundra limited
    I use a 12v pump with a few feet of clear hose when doing this stuff. I have nothing to add other than that blows.
  21. May 6, 2022 at 8:23 PM
    Wahayes
    Will
    2017 tundra limited
    Vaccum maybe? Idk if it would work but it cant be too far in the way went in.
  22. May 6, 2022 at 8:31 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Sorry that hapened. I just got 8 of those Amsol bags for the diffs & transfer case. I will learn from your mistake and be extra careful.
    Ely010606 likes this.
  23. May 6, 2022 at 8:41 PM
    Terndrerrr
    Music City
    6UR-FE
    The rear diff is super easy. Lots of space to work in. The front diff fill hole is in a pretty tight spot. My first mistake: not having any extra bags of 75W-90 in case I spilled a bit. I only had exactly the amount that I needed. If I had an extra bag, I might not have been so worried about spilling when trying to work in that much tighter space at the front diff.
    And yeah, if you think about it, use a long enough hose that it won’t disappear into the diff. I didn’t have any, was stuck at home, and I decided to improvise with the Ravenol hose that came with their bottles. It was fine for the first bag of oil, but like I said I shifted just a bit while holding the second bag up, and it popped off.
  24. May 6, 2022 at 8:44 PM
    I have been in your shoes (not necessarily this) and it sucks. Sorry man.
    The grabbing tool with the camera looks like a great solution to solve this problem.
    rockmup and Terndrerrr[OP] like this.
  25. May 6, 2022 at 8:56 PM
    Terndrerrr
    Music City
    6UR-FE
    I’m gettin pumped that this might work. Just gotta watch this montage a few more times before my tools show up
  26. May 6, 2022 at 9:04 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    X2, ^^.
  27. May 6, 2022 at 9:26 PM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    The grabber seems a good idea. I've seen many front diff fluid change problems over the years but this is a new one. Usually it's the facking 10mm Allen plugs won't release (been there). I recommend contact a Lexus dealer and get the Lexus fill/drain plugs that are 24mm external hex rather than the ridiculous 10mm Allens. Direct swap.
    KeithH likes this.
  28. May 7, 2022 at 4:42 AM
    Chrlsone
    Chrlsone New Member
    Charles
    2022 MGM Platinum Tundra
    I'm thinking the same thing. I wouldn't drive it until it's removed.
  29. May 7, 2022 at 4:57 AM
    rocsteady
    Dave
    New Jersey
    I know EXACTLY how you feel; short version, couple decades ago, intake off, small piece of something (can't remember what) snaps off and bounces up off the bottom of hood and disappears. I assume for days it's gone into the engine. Searched a million different ways. Finally gave up looking and put back together. Little anxiety as I started it the first time. Went fine, never found the little thing...
  30. May 7, 2022 at 7:05 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    I don't know what it is with these front diffs, but so many of us have stories of what should be a 30 minute job turns into a day long ordeal. For me I don't know if I got more oil on the ground or in the diff from blowing out tubes or spilling bottles - glad I have lots of kitty litter to clean up the driveway a bit
    coldcanuk likes this.
