  1. May 5, 2022 at 2:18 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    My GP and I have worked out a pretty good mix of meds that keep my asthma and allergies [mostly] in check. One of those is ADVAIR. While not as incredibly expensive as your salve, it's still very pricey for something he expects me to take twice a day. (~$225/month)
    I had a job change several years ago that eliminated my insurance for about 6 months. I couldn't afford that shit during that time so I reached out to my GP and explained that I couldn't afford it and requested a more affordable alternative. He said, "Absolutely not. I'll keep you in samples until your insurance gets sorted." And he did exactly that. Saved my ass for half a year. Certainly worth a phone call.
    Don't forget you can cut the shank on whatever drill/bit you use. Just enough to bottom it out on your drill and maximize your tight squeezing ability.
  2. May 5, 2022 at 2:24 PM
    bfunke
    bfunke Tundra Curmudgeon
    @shifty` - that pic reminds me of my house in Japan. I lived in Aomori Prefecture were we dealt with a lot of snow. Everything was stainless, swaged, and impeccably labeled
    shifty` likes this.
  3. May 5, 2022 at 2:25 PM
    @bmf4069 I won't be buying a new drill to make it happen, I've got a few diff't drills that could potentially work in this case if I'm thoughtful about settings.
    @BubbaW "very tight & awkward", like my only access options to this double-header is basically:
    • Inside a joist between two floors, but the joist has 10" or 12" insulated HVAC return duct running through it (I already cut out the ceiling between joists)
    • There's a staircase with double 2x12 on the other side of the header that prevents me from getting easy access to the backside of the wall for an angle
    • The only access from the back side is a 6" wide gap (the wall hollow) but I'd be reaching up blind into the hole to make a vertical cut, which I don't want
    • Removing drywall from the other side of the header isn't ideal and again limits me to a vertical/perpendicular cut and I'm looking to angle for easier LV pulls
  4. May 5, 2022 at 2:32 PM
    bfunke
    @Jack McCarthy - you created a bit of a dilemma for the dermatologist by scraping it off. Much easier to eval a “virgin” mole or nevus. Suspect pigmented lesions really need a punch biopsy or full thickness excision to properly eval. Melanomas are really bad actors and Clark’s level and depth are important prognostic indicators
  5. May 5, 2022 at 2:33 PM
    daveeasa
    Why do you need such a massive hole for low voltage ?
  6. May 5, 2022 at 3:01 PM
    How could it be a mole if it was scraped off? Moles typically bleed and come back from my experience.
    chrisb likes this.
  7. May 5, 2022 at 3:10 PM
    Full CAT6 and RG6 rewire, to the tune of about 30-40 cables total into a data+AV closet sitting under an awkwardly-shaped under-staircase closet in a basement.
    Cable calculator tells me I could make that happen using smaller conduit like 2" without high difficulty, but for ease of later pulls and additions, future growth, while I'm in there, I might as well just do 2.5" IMO.
    But either way, 1.5", 2", 2.5" there's still the lingering problem: I'd like to go at an angle, the space I'm working with is pretty damn tight (14-18" or less in any direction), the hole ideally should be round for better integrity and pulling, and it'd be easiest using a round bit that self-clears so hole saws are out.
  8. May 5, 2022 at 3:33 PM
    daveeasa
    Yeah I get it but maybe I don’t, if it’s not a convenient location for pulls, why put the patch panel there vs somewhere more accessible? You can run one high bandwidth network cable to that space for comms but usually patch panels are placed in a central location where it’s easy to get wire in / out. Kinda sounds like Thai cave rescue wiring to me.
  9. May 5, 2022 at 3:34 PM
    daveeasa
    A 32 port network switch needs very little power and takes up minimal space. I have a fanless one which doesn’t make a peep.
  10. May 5, 2022 at 3:35 PM
    daveeasa
    Also, RG6, what’s that for? Your vhs machine? Seriously.
    Jack McCarthy and FrenchToasty like this.
  11. May 5, 2022 at 4:06 PM
    Yeah, better to go with RG11. lol
    Sunnier likes this.
  12. May 5, 2022 at 4:24 PM
    Network infra already setup. Trust me, this is my industry. I'm well aware of what's needed.
    Antenna feeds for OTA. May go RG59 instead, but I have a spool of RG6 so I was going to use it.
    Jack McCarthy likes this.
  13. May 5, 2022 at 4:26 PM
    Remember to use an LNA to drive the cable if it’s over 50’. Maybe you already know, but I thought I’d mention it just in case.
    shifty`[QUOTED] likes this.
  14. May 5, 2022 at 5:03 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    @Jack McCarthy
    I'd get it biopsied. Wife's cousin let one go for about 6 months on his leg. It was cancerous and spread through got body, lost his life to it after 18 months.
    Better safe than sorry.
    des2mtn, shifty` and Jack McCarthy like this.
  15. May 5, 2022 at 5:03 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    RG-6 has better specs for OTA uses, I hope you have a good old fashioned YAGI. I have one up 60 feet in the Foothills, it's pointed south, I can get ALL UHF DTV in SoCal! Outdoor mount!
    You can drive RG-6 100ft with 5dB loss, RG-11 has 3dB/100ft loss. For a typical off air signal, you should have enough oompf to make a TV look good without an amp.. Especially if DTV is what you want. . It's either GO/NO GO! 1 "bars" gets you a perfect pic, 5 "Bars" exactly same quality pic, that's digital. Now Analog NTSC, VERY much RF level driven... but no one broadcasts analog TV anymore! So it's a moot point.
    Since ATSC is broadcast in the 470–890Hhz UHF band, if you did need a amp, you would need a broad band amp.
    des2mtn and shifty`[QUOTED] like this.
  16. May 5, 2022 at 5:05 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Oh, you guys must be talking about electrical hoses.
    I was pretty sure roentgenium didnt oxidize to a +6.
    bmf4069 and shifty` like this.
  17. May 5, 2022 at 5:11 PM
    GO/NOGO doesn't work very well if your signal is hovering about the noise floor and it cuts in/out and pixelizes regularly. A UHF filter and LNA can do wonders.
    I will admit using RG6 may not require one though. I typically run RG59.
  18. May 5, 2022 at 5:38 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Well???? Did you get the fleshlight back or not?!
    chrisb, RUSTYNUTS, bmf4069 and 2 others like this.
  19. May 5, 2022 at 6:12 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Maybe I'm just too young but I guess I'm unaware of how serious a small bump or mark could be. Guess it's just not something I've ever given much thought. It'll make me keep an eye out better in the coming years. How do you know which kind of stuff to take seriously.
    P.S. This truck forum is great lol
    chrisb, RUSTYNUTS and FrenchToasty like this.
  20. May 5, 2022 at 6:17 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Completely forgot about this. I literally almost spit my drink out.
    shifty` likes this.
  21. May 5, 2022 at 6:20 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    He doesn’t lie. I met him on April 1 and he already had a tan.
    bmf4069, txagg and Sirfive[QUOTED] like this.
  22. May 5, 2022 at 6:35 PM
    Sunnier
    Sunny
    San Diego, CA
    Pretty much… anything like the weird mark our friend above wants a 2nd opinion about :boink:, you get checked out as soon as you can. Basically, anything that develops that wasn’t there before, that you can’t recall being caused by a specific injury or event (new shoes, new activity with different repetitive movement); anything that sloughs off or can be picked off, and comes back; anything with irregular edges; anything in a very dark colour that doesn’t match any other marks that have always been on your body…. Those are most of the Big Telltales. Basically, if it’s Abby-Normal, it might be a monster.
    NUDRAT[OP], tokolosh, chrisb and 5 others like this.
  23. May 5, 2022 at 6:37 PM
    GODZILLA, alb1k and Sunnier[QUOTED] like this.
  24. May 5, 2022 at 6:43 PM
    18" TRD Off Road Wheels
    Just gonna leave this for the feet people.
    CodyP, chrisb, RUSTYNUTS and 6 others like this.
  25. May 5, 2022 at 6:50 PM
    Sunnier
    Sunny
    San Diego, CA
    Dark and irregular. Good to let us check. ;)
  26. May 5, 2022 at 6:51 PM
    FirstGenVol and Sunnier[QUOTED] like this.
  27. May 5, 2022 at 7:05 PM
    Fleawalker
    Fleawalker New Member
    South FL
    2001 V8 4x4 Access Cab
    None (yet)
    Just joining back in and I'm pages behind. I've replaced the fitting twice and it still leaking so my hope is to be able to seal it from above around the perimeter of the fitting somehow. It.'s a PVC fitting
  28. May 5, 2022 at 7:06 PM
    Fleawalker
    South FL
    None (yet)
    Leeches do amazing things
  29. May 5, 2022 at 7:10 PM
    I’ll have to look that one up.
  30. May 5, 2022 at 7:11 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    wraps and exterior plumbing seals are useless. Have a pic?
    chrisb and Darkness like this.
