Ist Gen 4WD issue. Indicator blinks, will NOT engage 4WD
Discussion in '1st Gen Tundras (2000-2006)' started by MansfieldTx, May 5, 2022.
  1. May 5, 2022 at 12:21 PM
    MansfieldTx
    MansfieldTx [OP] New Member
    Moose
    2002 Tundra
    Appreciate any help! Thanks!
  2. May 5, 2022 at 12:59 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Any clicks? Maybe try rocking the trucks back and forth while its blinking? Or try spinning the front driveshaft back and forth while its blinking.
  3. May 5, 2022 at 1:05 PM
    @MansfieldTx most important question first: Was is ever working in the past? Also, is this for 4LO or 4HI?
  4. May 5, 2022 at 1:06 PM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    pull fuse and try again. Mine did this before. IIRC the fix was simple. But it was a long time ago. Only happened once.
  5. May 5, 2022 at 1:06 PM
    For a 2016, or a 2002 like the OP has?
    bmf4069 likes this.
  6. May 5, 2022 at 1:08 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Welcome....when was the last time you used it ?
    As @Sirfive alluded to, can you hear an actuator make noise under truck.
    Along with rocking, slowly go either forward or reverse while pressing 4HI
    Once you get it going, need to remember to at least actuate 4WD on occasion. Personally it's hard for me to remember but I do try !
  7. May 5, 2022 at 1:15 PM
    What he said ^^
    OEM recommendation per the owner's manual is to make sure you engage 4HI for at least 10 miles per month. And OP's truck may differ from my '06, on mine there is a fuse for 4WD, but I've just never seen a 1st gen owner post about theirs blowing.
    Double DC likes this.
  8. May 5, 2022 at 1:19 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    J/K :)
    Jack McCarthy, N84434 and bmf4069 like this.
  9. May 5, 2022 at 1:21 PM
    Kinda sorta, but not really. :rofl:
    (I'm guilty sometimes also)
  10. May 5, 2022 at 6:30 PM
    Tundradrenalin
    Virginia Beach, VA
    It was an 06.
    may she Rest In Peace :(
  11. May 10, 2022 at 4:18 AM
    Guess we'll never hear back on this one...
    bmf4069 likes this.
  12. May 10, 2022 at 4:26 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Common problem. Probably an actuator. More likely the one on the front axle. But could be a number of contributors. Switch, actuator etc. you need a second person to listen and feel as you try to engage and see what happens to try and narrow down the problems.
  13. May 10, 2022 at 5:13 AM
    Tundradrenalin
    Virginia Beach, VA
    Pull the whole axle and differential, easier to diagnose on a bench.
    bmf4069 likes this.
  14. May 10, 2022 at 7:05 AM
    Jack up truck on 4 jack stands and observe if front driveshaft spins when placed in 4wd high.
    If it does, suspect front diff 4wd actuator. People have banged on it with hammer to get working (supposedly). Not sure if easily opens up to clean.
    If not, open transfer case 4wd actuator and clean out crap and corrosion for lack of use.
  15. May 10, 2022 at 7:11 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    The crackhead thread has some good pics of the actuator. I dont remember if that was the tcase or add, but it’ll give you an idea of what its trying to do.
