Customizable features - please help
Discussion in '2.5 Gen Tundras (2014-2021)' started by ankom, May 5, 2022.
  1. May 5, 2022 at 8:10 AM
    ankom
    ankom [OP] New Member
    Truck is a new to me CPO 2021 SR5. There are some things I'd like to change.
    For example - the instrument cluster displays "ACCESSORY" and the truck beeps nonstop when I turn off the ignition and open the door, until I close the door, I'd like to stop this beeping. I'm also finding that the remote / key fob does not unlock all of the doors if I press the unlock button after I turn off the ignition. Out of habit, I'm stepping out of the car, attempting to open a rear door, the door is locked, my remote can't unlock it, and I need to use the lock/unlock button on the inside of my driver's door.
    From what I've read here and in my owner's manual, I should be able to access settings similar to these via the APPS button on the head unit - I should have an icon for "Setup" on the APPS screen which will give me access to these settings. As in attached photo, I have icons for Authorization, Notifications, and Wi-Fi, only. No Setup icon, no way to access Vehicle Customization that I can figure out.
    Please help me.
  2. May 5, 2022 at 8:17 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    The screen you are showing us has a small arrow on each side of the display, about mid-way down in the blue field. Have you tried toggling left and right using those arrows?
    Your fob is the newer style than my fob, so I can’t help. I know on my older fob, one button click locks/unlocks the driver door, and 2+ clicks unlocks all doors. (And tailgate).
  3. May 5, 2022 at 8:40 AM
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    TRD Sway bar, Lomax Tonnueau cover, Bed rug, Havoc HS2 Steps, Tech 12 Volts stereo upgrade, Yakima bed extender, misc trim and bling,
    Some of the features you are describing can be found in the vehicle settings app. It is limited but you can set some of the default behaviors of the vehicle.
  4. May 5, 2022 at 8:41 AM
    ankom
    Thanks - those arrows arrows are greyed out / don't scroll anywhere / don't switch to a different screen.
  5. May 5, 2022 at 8:42 AM
    ankom
    How do I get to the vehicle settings app? My impression was it should be on the screen I included a picture of.
  6. May 5, 2022 at 8:46 AM
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    If I remember correctly you need to get the authorization completed before additional apps are displayed. Also had to do it from inside the vehicle when I did it. Should be in one of the manuals.
  7. May 5, 2022 at 11:39 AM
    ankom
    Thanks, I think this is the right track.
    Problem is I registered my Toyota Owners account before I had the truck and do not have / cannot figure out how to get an Entune authorization code, and the Toyota help I spoke to this morning can't figure it out either. Toyota has told me they'll attempt to delete my Owners account so that I might re-try registering with Entune from scratch.
    Can anyone with a '20-'21 SR5 confirm that you have a "Setup" icon on the "APPS" screen? On the phone, Toyota was questioning if I have "Audio Plus or Premium Audio", and if I therefore should even have the "Setup" icon. Attached screenshot is from the '21 owners manual.
  8. May 5, 2022 at 12:09 PM
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    I don't think it has anything to do with the owners account(had my account before authorization as well), but it has been 2 years. Think I just started the truck, selected authorization, selected the SOS call button, and was given codes to enter. Your Toyota dealer can help you with this as well.
    Premium audio is the JBL system, don't know what Audio Plus is.
  9. May 5, 2022 at 12:42 PM
    pdf256
    pdf256 New Member
    Paul
    2021 Tundra SR5 CrewMax 4x4
    press the "Menu" button on the left side. Then look for the "Setup" icon. Lots of things you can change.
    pdf256
  10. May 5, 2022 at 1:26 PM
    ankom
    Thanks for this.
    Looks like you have a 21 SR5.
    In that menu, "Vehicle" is greyed out for me / inaccessible.
    It is not greyed out for you, right?
  11. May 5, 2022 at 1:27 PM
    ankom
    Here's my Setup screen with greyed out Vehicle.
  12. May 5, 2022 at 2:07 PM
    ankom
    Argh so apparently the engine needs to be running - I am all set.
    Thank you all for entertaining my ignorance.
