The Tundra drinks gas because....
Discussion in '2.5 Gen Tundras (2014-2021)' started by WXman, Apr 27, 2022.
  1. Apr 30, 2022 at 9:01 AM
    #61
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    Not much worse than the 3.7 in the ladies liberty... But can the liberty haul half a ton? Is it this fast? Tow 10k? I mean cmon yall...
    Thats how the government does it. Buy/sell/trade carbon credits. My truck is allowed to make a black cloud because my wife drives a hybrid. "It offsets blah blah blah" :thumbsup:
  2. Apr 30, 2022 at 9:19 AM
    #62
    drdriller
    drdriller New Member
    I’d love to know why it sucks gas
  3. Apr 30, 2022 at 6:56 PM
    #63
    soobaroo
    soobaroo New Member
    Gene
    2019 Tundra SR5
    I get real good fuel economy with my Tundra. If you only drive it 5000 miles a year you will too
    1UP and bstringrandy like this.
  4. May 1, 2022 at 1:02 PM
    #64
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    It drinks gas because it obviously wasn't the primary consideration at literally every point of the design process.
    -Large engine built with enough airflow capacity to make good power over 5k rpm, but only cam phasers to mitigate the shortcomings. No intake valve disabling like a Honda D15B or L15A1, no port/injector disabling like an LT5, no variable valve lift like Toyota's VVTi-L 2ZZGE engine, no cylinder deactivation, nothing that increases intake manifold pressure or port air velocity at cruising speed.
    -6 speed automatic transmission made with tall ratios but containing as many planetary gearsets as a 10 speed. More parts, more friction, and a hydraulic pump holding over 200 psi. This is why the old Civic VX with its 50+ mpg had a 4 speed stick.
    -Also the programming. It doesn't even allow converter lock in drive until 5th gear. Drive a Toyota car with an automatic before they got CVTs. They're locking converters by 25 mph in cases and forcing high engine loads under 2k rpm. Tundra upshifts at 65% load... but it feels sportier. Otherwise people parrot off like Chevy truck drivers--- "it feels like it's lugging all the time"
    -Truck body as wide as legally allowed, with a 6'4" factory height. Big cross section. Aero? Well there's those little diffuser tabs on the taillights I guess. No air dam underneath. No smooth panels on underbody. No automatic grille shutters. No auto lowering suspension.
    -Everybody blames the 4.30 gears but the transmission is so tall it's like a Ford with 3.73s. Still, huge gear, big bearings, drag.
    -Accessories and fan drag the serp belt just like they did when Reagan was President.
    But it runs and runs just as long as you feed it
  5. May 1, 2022 at 2:15 PM
    #65
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Lol, I was gonna post the exact same thing. I went from about 80 miles a day to sub 10
    bstringrandy likes this.
  6. May 2, 2022 at 4:41 AM
    #66
    ChiselnMallet
    ChiselnMallet New Member
    2019 Limited Double Cab
    I'm new to truck ownership. I bought an old airstream first.. then needed a truck to tow it. Tundra was my choice because it was engineered to do work, and has the reputation for longevity (if cared for). Happy to fill the tank knowing it's going do what I need it to do, when I need it to do it. It's not a commuter. It's not a grocery getter. That being said... I drive it like a great-grampa... super slow of the line, and I can get 15-16 around town and got nearly 20 on a 1300 mile highway trip.
  7. May 2, 2022 at 8:40 AM
    #67
    YankeeRon
    YankeeRon New Member
    Ron
    East Windsor, CT
    2021 SR Long Bed
    Cat Security shield, rear headliner molding, BlackVue dash cam, DS grab handle, rear under seat storage, door edge molding, cal trend seat covers, sway bars, hard bed cover, rubber bed mat, intermittent wipers
    It's all good - we all love our Tundra's but it doesn't mean they don't have weak points. I just towed my camper this weekend and experimented with towing in just S4 (with T/H on). I haven't done this yet because I was concerned about what it would do to gas mileage, but I wanted the lower trans temps others have reported when towing in S4 w/ converter lock-up. I was really pleased to see the dash computer report about a 13mpg average (however accurate that is). I expected much lower.
    Ron
  8. May 2, 2022 at 10:42 AM
    #68
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Yep. S4 is where it’s at for towing. 5 and 6 are overdrive gears. If you want higher transmission temps, worse fuel economy, and worse engine braking, tow in S5 or D. My favorite thing is reading about people complaining that the Tundra hunts for gears when towing in D at 75mph. :facepalm:
  9. May 2, 2022 at 10:57 AM
    #69
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    I get 11 MPGs with 37s and love every minute of it. I didn't buy my tundra to save gas.
  10. May 2, 2022 at 1:26 PM
    #70
    2017_Tundra_AZ
    2017_Tundra_AZ New Member
    I always thank Telsa drivers for making up for my horrible MPG.
  11. May 4, 2022 at 7:41 AM
    #71
    hANNAbONE
    hANNAbONE T U N D R A M A
    Des Moines / Dull Moan, Iowa
    still lookin' for my first one
    430 rear end...
  12. May 4, 2022 at 4:33 PM
    #72
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    Why does my tundra drink gas?
    :burnrubber:
    Saltyhero13 likes this.
  13. May 4, 2022 at 4:45 PM
    #73
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Yeah, but that's what makes the '07-21 tundra the most reliable half ton pickup ever built.
