2000 toyota tundra trailer wiring fuse cover and factory running board mounts
Discussion in '1st Gen Tundras (2000-2006)' started by caba272, May 2, 2022.
  1. May 2, 2022 at 1:34 PM
    caba272
    caba272 [OP] New Member
    Todd
    2000 toyota tundra sr5 access cab
    stock
    new to tundras but not toyotas. this was my score last weekend, a 2000 tundra 4wd and v8 with 182k miles that had a miss and a broken left lower control arm/cv axle. got it for 1k. anyways I'm looking for two specific things, the first thing is a fuse cover for the factory trailer wiring harness j case fuse. I'm also looking for factory running board mounts because the right side rear mount is broke and held on by a hose clamp. I have a part number but there is no picture of what that part number is. I would also like to find the part number for the left side running board considering the mounts on that side do not look to be in the best condition.
    Part numbers I have found for running board mounts
    left side-PT938-48140-AC
    right side-PT938-48140-AD
    Can anyone confirm if these are the part numbers?
    I haven't found anything for the trailer fuse cover yet. I know junk yards will be best but the closest junk yard with a tundra is 2+ hours away and am willing to buy from a member on here is anybody has anything for the mounts or fuse cover.
    I have tried searching the forum and haven't had any luck so sorry if this has been covered before.
    Mogo Gogo likes this.
  2. May 2, 2022 at 2:55 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Welcome....
    All 3 of the Toyota dealers I normally look at show those as strictly for Highlanders.
    PT93848140AC - Bracket Kit. Running Boards - Genuine toyota Accessory
    Zooming in shows me that if I failed in finding a kit, I'd be taking that bracket to one of our Arc Welders in our area.
    Also, my running board has Toyota part # on bottom. Any chance you can find that on yours in case it helps in finding proper kit.
  3. May 2, 2022 at 3:36 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Sorry cant help with your questions but welcome and nice find for a thousand dollars! :thumbsup:
  4. May 3, 2022 at 9:05 AM
    Welcome aboard, good score! As long as the frame is solid and the "miss" ends up being a coil pack, you made out like a bandit. Even though it's Blurple.
  5. May 3, 2022 at 9:08 AM
    shifty` Ten EV 12's so you know I raise hell
    Was it @txagg who was looking for those pieces recently? I swore I took pics of mine and might've laid out part numbers but my search mojo is running on empty today.
    txagg likes this.
  6. May 3, 2022 at 9:10 AM
  7. May 3, 2022 at 3:58 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    I gave up on it, been using the running boards I bought that you were interested in. Serra parts guy could not find parts numbers, Said he got in touch with corporate about it and I have never heard back.
  8. May 3, 2022 at 5:25 PM
    Yeah, I've gotten the "emailed corporate" before and I can't tell if it's just a "feck off" or legit. Still waiting on one of my splash guards that was branded incorrectly. Still not enough to send me packing, but ...
    txagg[QUOTED] likes this.
