Cabin air filter flow direction
Discussion in 'General Tundra Discussion' started by joonbug, Jul 1, 2018.
  1. May 3, 2022 at 3:34 PM
    #91
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  2. May 3, 2022 at 3:43 PM
    #92
    2014 TRD
    2014 TRD Doesnt hire TV personalities.
    Deep in the heat of Texas
    If its supposed to shield yer melon, why does it have an antenna? Eh? Eh?
    :rocket:
    Retired...finally likes this.
  3. May 3, 2022 at 3:51 PM
    #93
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I just went to purchase a new cabin filter as I do every spring. Had my oil changed and tires rotated and they said it was dirty. So I stopped at advance on my way home. $30+ for a new cabin filter?!?! F that - I bit the bullet and paid $40 for the washable k&n filter. It’s crazy how much stuff like this costs nowadays.
  4. May 3, 2022 at 5:05 PM
    #94
    2014 TRD
    Did it have an arrow? :)
    BTW, I ran across this set of vids for folks to replace the filter....this guy says "the air flow arrow should point UP" in video #4. Replace Filter - Insert the filter and put everything back in place. At the 8 second mark he makes the statement...."the air flow arrow should point UP"
    https://www.carcarekiosk.com/video/2015_Toyota_Tundra_Platinum_5.7L_V8/air_filter_cabin/replace
    Author
    Hans Angermeier has produced over 100,000 videos showing drivers how to fix things on their cars. He has broad expertise on basic repair procedures covering the majority of cars on the road.
    shawn474 likes this.
  5. May 3, 2022 at 5:11 PM
    #95
    shawn474
    MoCo, Maryland
    haha I will let you know tomorrow when I pick it up - had to order it
  6. May 3, 2022 at 6:12 PM
    #96
    TILLY
    Massachusetts
    Some filters use an arrow to indicates airflow, which should be pointing down, and others say the word up, which doesn't indicate airflow and just means, well up. :)
  7. May 3, 2022 at 6:59 PM
    #97
    2014 TRD
    But, but, Hans Angermeier says to point the arrow upppppp. Are you doubting the great and mighty Hans?
    Seriously, I'm going to test tomorrow with a piece of paper #1 and #2, Ive got a small wind speed gizmo we used when we flew drones...it will not only say what direction, it will tell me how fast. Hope the batteries are still good. It has been in a box for a couple years....
  8. May 4, 2022 at 3:10 PM
    #98
    2014 TRD
    ok FOLKS, Hans Angermeier was WRONG. There I said it.
    I took a piece of paper, cut in half and stuck it in the running airflow. Several times it was sucked/blown downwards. Myth busted, arrow points down.
    The airlfw I felt on my hand must have been swirly/through my fingers because that paper in no way went upwards.
    Down down down like a burning ring of airflow questions. Thank you Tilly.
    coldcanuk, WFD473 and TILLY like this.
  9. May 4, 2022 at 3:18 PM
    #99
    TILLY
    Massachusetts
    :cheers:
  10. May 4, 2022 at 3:26 PM
    #100
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Cabin air flow direction threads never gets old.
  11. May 4, 2022 at 6:16 PM
    #101
    shawn474
    MoCo, Maryland
    So just to clarify, does the arrow point up as in “this side up” or does the arrow point in the direction of air flow…..inquiring minds want to know
    :monocle::boink::deadhorse:
    toyofan87 likes this.
  12. May 9, 2022 at 6:34 AM
    #102
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I personally use Swiss cheese (baby Swiss for its superior filtering ability).
    Seems to keep the rats from mutinous activities AND provides a lovely fragrance.
    Fringe benefit, there are no fucking arrows.
  13. Apr 24, 2023 at 4:54 PM
    #103
    DeanoBambino64
    DeanoBambino64 New Member
    Dean
    Saskatoon Area
    2008 Tundra Crewmax Limited 4X4 5.7L V8, 20"aluminium oem wheels.
    To even bring more confusion, the wix filter i just installed had the company name and info that faces out right-side-up, and the arrow up and did not specify if it was a directional arrow or a this-side-up arrow. i have looked through a dozen vids and a few forums and nobody seems to know for sure how to determine. Even the Toyota vid on youtube is very unclear. geez....it shouldn't be this hard.
    joonbug[QUOTED][OP] likes this.
  14. Oct 12, 2023 at 2:26 PM
    #104
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I’m upset I spent this much time reading all this lol
  15. Oct 13, 2023 at 4:50 AM
    #105
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Fwiw, these cabin filters are pretty much the same, structurally, on either side. They don't usually have a support structure on one side to support against air flow, or a second large debris filter that would go on the side of the incoming air.
    Also, mice don't have a preference.
    It probably won't be life and death if you fuk it up.
    Also, people found ancient languages that were thousands of years old and made up of symbols and pictures. They figured out what it all meant.
    If you can't figure out a few arrows on a filter,.....
    maybe consider a vasectomy.
    No, seriously. We're trying to explore space and there's going to be 11 billion people on the planet by 2100. We need more humans that can read arrows, not more humans getting their hand stuck in a box, trying to get a banana out of it.
  16. Oct 13, 2023 at 10:12 AM
    #106
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    I never said I was one of the smart ones.
    Sierradevil likes this.
