2006 Double Cab Exterior Window Trim Piece, part # where to buy
Discussion in '1st Gen Tundras (2000-2006)' started by flatirons81, May 3, 2022.
  1. May 3, 2022 at 1:28 PM
    flatirons81
    flatirons81 [OP] New Member
    2006 Burgundy Tundra TRD
    My 2006 double cab on the cab windows there is a small curved exterior trim piece, trying to get a part# and where to locate it. Is it easy to replace? I have included a couple photos to help.
    Thanks.
  2. May 3, 2022 at 1:53 PM
    A quick search brought me to this post. Follow the chain for more info and reply to the posters involved as needed. I get the feeling @Hi06silver may be able to answer.
  3. May 3, 2022 at 2:08 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    That piece is part of the bottom piece.
    Door Window Belt Weatherstrip (Left, Rear) - Toyota (75740-0C022)...fits 04 and 06
    The bottom piece is held in with 4 clips. The below pic is more than you need but all I have from when I did mine. Item 1 is driver side rear(top and side) and item 2 is the part you need.
    I chose to use a wide plastic putty knife and pushed up with slight force.
  4. May 3, 2022 at 3:04 PM
    Wonder if @Roman can provide help?
  5. May 3, 2022 at 3:51 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    I have also been looking for that piece for years with no luck. So it comes as a separate piece that you push in once you install the molding? It doesn't show that little piece as part of the molding in the parts diagram:
    https://www.sparksparts.com/oem-par...xJmw9NCZuPVJlY29tbWVuZGVkIFByb2R1Y3RzJms9MQ==
  6. May 3, 2022 at 4:13 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    It does not come as a separate piece, it comes as part of the part # I posted above. Keep in mind, as I mentioned above, that part # is for 04 AND 06. It does not mention it's for your 05 DC whether I look at McGeorge, Cool Springs or any other Toyota parts house.
    2004-2006 Toyota Tundra Belt Weather-Strip (Double cab models only) 75740-0C022 | Toyota of Cool Springs vParts
    for the 04 and 06, perhaps this is better pic showing it's one piece which appears to some to be an extra piece which is broke off on OP's.
    seth419[QUOTED] likes this.
  7. May 3, 2022 at 4:18 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    That picture clears it up and I can see that piece now. It covers the gap between the two trim pieces and is the same for the 05. When it is gone it appears to be a separate piece that would push into the gap of the two trim pieces. Thanks!!
    BubbaW[QUOTED] likes this.
  8. May 3, 2022 at 5:31 PM
    Can't recommend to y'all enough: Get it now while you still can. Seems like Toyota is moonlighting a lot of parts for our trucks, and this door trim seems to be one of a couple dozen that'll be going the way of the dodo soon.
    Weagle, BubbaW and FrenchToasty like this.
  9. May 3, 2022 at 7:49 PM
    flatirons81
  10. May 3, 2022 at 11:16 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Everything on first gens costs a lot. OEM parts anyway.
  11. May 4, 2022 at 3:30 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Negative....that is the piece that I showed above as item # 1 and covers the top and side.
    The item # 2 I mentioned above is the part you need...75740-0C022
    75740-0C022 - Door Window Belt Weatherstrip (Left, Rear) - 2004-2006 Toyota Tundra | Sparks Parts
    However, as @shifty` mentioned, our parts are becoming more and more NLA(no longer available). If your plans are to hang onto this 06, suggest you consider take an inventory of most needed items and get them while you still have a chance. When Toyota cuts us off com[letely, you'll probably pay more later.
  12. May 4, 2022 at 11:47 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
  13. Mar 19, 2024 at 11:42 AM
    Wilk95
    Wilk95 New Member
    2004 Limited DC 4x4
    Quick question regarding these trim pieces. I'm not sure which parts I need. It seems a lot of you were correct and the door reveal molding (top and side molding piece) has in fact been discontinued. I did find an online dealership with it still listed, but after I purchased it they informed it was discontinued and refunded me my money. I guess my question is do I need a both trim pieces? Or do I only need the lower trim piece, as it will hold the side molding down?
  14. Mar 19, 2024 at 9:49 PM
    Pnwtundy
    Pnwtundy New Member
    04 DC SR5 TRD, V8/4WD + LSD/Tow
  15. Mar 19, 2024 at 9:58 PM
    artsr2002
    'Yonder
    @Pnwtundy Thanks for the reminder on those. I should really order a set to have on hand. :D
    Pnwtundy likes this.
