Loose bolts...
Discussion in '1st Gen Tundras (2000-2006)' started by Treeclimber, Apr 29, 2022.
  1. Apr 29, 2022 at 12:41 PM
    Treeclimber
    Treeclimber [OP] New Member
    01/03 tundra sr5
    Shop swapped frame..
    Hi there.
    New to the forum, fourth tundra over the course of things.
    Had some work done to the truck, frame swap, tranny work timing belt thermostat rear end replaced. A lot of work.
    Been driving her for a bit and the steering started feeling loose.
    Looked found the bushings gone on the rack.
    Ordered parts
    In the meantime, had to go to work etc. So I kept driving her.
    Felt the steering get real sloppy.
    Peeled back the carpet around steering column, and found three of the four 10mm bolts holding the two u-joints together, out of their respective holes.
    Found the plastic piece inside all banged up from sloppy wear and tear.
    Question is, is that piece, the white plastic insert, available?
    Or do I have to buy a whole column?
    Thanks for reading
    Phil
  2. Apr 29, 2022 at 2:34 PM
    Pics? We like pics to see exactly what you mean.
    bmf4069 likes this.
  3. May 3, 2022 at 3:11 PM
    Treeclimber
    01/03 tundra sr5
    This is what it looks like when tightened.
    3,of the 4 bolts were out, and half way on the 4th
    The nylon bit in between, is all chewed up.
    Never seen,anything,like it...
    Jack McCarthy likes this.
  4. May 3, 2022 at 3:34 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    bmf4069, KNABORES and Jack McCarthy like this.
