  1. Apr 24, 2022 at 8:47 AM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    That and the bump start ignition. It often takes me twice to start my other car because I don’t hold the key in the start position long enough.
    D4x4TRD likes this.
  2. Apr 24, 2022 at 8:53 AM
    Retroboy1989
    Northern Utah
    I did not know our trucks had this feature... I owned a GM that had it and I got very used to only tapping the starter. Now I want to go out to the garage and try it.
  3. Apr 24, 2022 at 8:59 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Awww sheeeit. It's over for you now.
    My wife's car has the push-button, so I short-start our old bimmer a lot.
    joseph_womack likes this.
  4. Apr 24, 2022 at 10:00 AM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    I didn’t know it had one in there until recently and after I had already purchased this. So i guess mine is worn out. This does a great job though so just gonna stick with it
  5. Apr 24, 2022 at 12:49 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Took a turn at using Plastidip on my rims...I also had to tear apart my tailgate latch as it broke while it was closed, and the hard tonoue cover was latched...
  6. Apr 24, 2022 at 3:18 PM
    COTundie
    Trey
    Pretty things
    Been thinking about making some tamper resistant "shields" for my tonneau unlatching system, but never made the step for fear of latch breakage.
    I don't want to destroy my own tonneau cover in the event. If a thief wants into the bed, they're probably just going to break it open anyhow.
  7. Apr 24, 2022 at 5:18 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Prolly. The latches on this one are only plastic. That's why I took the tailgate handle assemblby out to get at the rods that open the tailgate and spare the cover.
  8. Apr 24, 2022 at 7:21 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Here ya go, lemme know if you’d like better pictures
    FredB32, 07DCLimited, WVI and 5 others like this.
  9. Apr 24, 2022 at 7:25 PM
    Taco-Spike
    Two Trucks
    Yeah, even in the last 2/3 years they’ve gone up 30/40+%
  10. Apr 25, 2022 at 12:26 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Removed the plow for the winter. Back in super truck fashion :amen:
  11. Apr 25, 2022 at 6:23 PM
    surffj62
    surffj62 New Member
    2011 DBL RW
    Drained and filled transfer/ rear diff= boring!
    Rear diff breather extend -kinda cool if I can find a river to cross in dry CO..
    Lastly.. don’t do this.. if you have taken your doors apart a bunch like I have. I was fiddling around with the small kids lock tabs and for the life of me they would not unlock. Background, I had a speaker in rear pax door that would give me some static on bumps. Figured it was a wire issue. Yep. Fixed it. Put door back together but I couldn’t get to lock right. Out of time, I’ll get that later. Door unlock got wonky, red truck on dash etc. got back into door and one of the two cables that are in panel was seated wrong. Fixed.
    Back to kids lock - don’t mess with it. I had to take the three hex bolts out, remove the whole thing, watch a YouTube fix it video and jimmy the lock tab back into unlock place, put back together.
    Stroke of genius? Try the other door and have it do the same thing! Doh! Don’t know what it is that is locking it up but don’t mess with it! (Yes it worked in past, tried rapid lock/unlock etc)
  12. Apr 26, 2022 at 3:00 PM
    hotchops777
    hotchops777 New Member
    Matthew
    EAST TEXAS
    2011 5.7 Silver Sky DC
    6" Procomp Stage 2 lift Black Rhino Sierra 20x10 0 offset on 325x65x20 Nitto Ridge Grapplers Smitty Built M1 front grill
    MAN!! im so jelly. What was ur order to receiving time on that?
  13. Apr 27, 2022 at 2:53 PM
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    I finished trimming my bedsides to line up with my high clearance bumper. I have some color-matched spray paint ordered.
    TheBeast, RJVA, WVI and 10 others like this.
  14. Apr 28, 2022 at 4:39 PM
    Hotwire
    Hotwire New Member
    Montana
    Not technically TO the Tundra; but I drew up some adjustable lift shackles in preparation for leveling my truck out with the Bilstein 6112/5160 combo.
    RJVA, WVI, NueveTundra and 7 others like this.
  15. Apr 28, 2022 at 7:18 PM
    Peeeheeuuu
    Peeeheeuuu New Member
    Peter
    Elk Grove, CA
    08 Tundra CM 4x4. 21 Sequoia SR5 4wd
    Thanks, It was ordered January of 2021. It took me about a year and a half to receive.
  16. Apr 29, 2022 at 5:35 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Replaced the leaking exhaust seal between the muffler and tailpipe.
    This is the old one after it came out, and sat for a bit...it looks to be a coil of steel.
  17. May 1, 2022 at 4:22 PM
    dtd608
    dtd608 New Member
    Daniel
    2010 Toyota Tundra
    This is what i did to mine today. Damn yard sweeper canopy caught just enough wind to blow out and swing back into my tailgate, leaving two dents and f’n up the paint. Idk how much this costs to repair. I wouldn’t worry about a dent if it didn’t look absolutely stupid with two on either side…
  18. May 1, 2022 at 4:38 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    Find a paintless dent repair shop and see what it will cost to remove the dents. Then, you can pick up some touchup paint and fix the paint damage yourself.
    dtd608[QUOTED] likes this.
  19. May 1, 2022 at 5:10 PM
    Randy Morton
    Randy
    dtd608 likes this.
  20. May 1, 2022 at 9:58 PM
    Underdogg
    Underdogg New Member
    07 Crewmax 5.7L
    Front end conversion from 07>14 and Morimoto XDs.
    Before:
    After:
    Anyone in need of black 07 hood/fenders and brackets? haha
    RJVA, D4x4TRD, Peeeheeuuu and 17 others like this.
  21. May 1, 2022 at 11:19 PM
    joseph_womack
    Joe
    Louisiana
    You can get to where those dents are by removing the back panel of the tailgate- you might want to do that and see if you can hammer or pop them back out yourself
  22. May 2, 2022 at 4:52 AM
    guyfromky
    guyfromky New Member
    Made the switch from a Tacoma to a Tundra and brought it home this weekend! I've been a member of Tacoma World for a while, so looking forward to joining this forum.
  23. May 2, 2022 at 6:55 AM
    Beachcomber
    Beachcomber New Member
    2011 Silver Sky CrewMax
    BDS 4.5" w/fox CO Lift Sequoia Grill & Headlights Prinsu Roof Rack Bullet Lined Roof Fuel Wheels/NItto Grappler Tires
    "Installed" one of my favorite upgrades for the truck. This years pass for the Cape Cod National Seashore oversand areas.20220502_095636.jpg
  24. May 2, 2022 at 7:29 AM
    ftmyerstundra
    ftmyerstundra New Member
    Gary
    2007 Tundra Crew Limited
    absolutely none
    Started the dechrome process. Swapped rear bumper, sidesteps to black. Front went with a $60 rockauto grill and painted it and cleared. Fogs are laminex. Just gotta swap out the door handles and mirror caps and the transformation will be complete.
    Before (when I bought it)
    Current
    ACDC2ZZTop, is348cm, D4x4TRD and 9 others like this.
  25. May 2, 2022 at 11:21 AM
    RJVA
    RJVA Former Lurker
    Richard
    Idaho
    2008 Tundra Silver DC 4.7 4x4
    OEM 18" wheels off a 2.5 gen 275/70/18 Falken Rubitrek A/T FabFour Redsteel front bumper with HF winch. Dobinsons IMS with 2.25" coils (610) JBA UCA's Iron Man +300lb rear leaf packs with Dobinsons IMS shocks ECGS bushing in front diff Black Oak Led Flood Pods. 40watt (x2) Black Oak 20" light bar. 100 watt OEM style rear bumper, black powder coat, added aux reverse leds. Stubby AM/FM antenna Century Camper Shell with Roof rack and bed mat
    Coworker offered a deal on a camper shell too good to pass up. Added a roof rack to the new camper shell. Added additional tie down points to said roof rack.
  26. May 3, 2022 at 12:40 AM
    Wrath
    Wrath New Member
    2nd Gen Tundra
    Mods that make me happy.
    Hey all. I just got some new 37s, 5.29 gears and front/rear lockers. Time to hit the trails!
    wv00097, RJVA, NueveTundra and 6 others like this.
  27. May 3, 2022 at 8:48 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Pics or it didn’t happen :worthless:
  28. May 3, 2022 at 9:37 AM
    Wrath
    Wrath New Member
    2nd Gen Tundra
    wv00097, D4x4TRD, truckguy84 and 15 others like this.
  29. May 3, 2022 at 11:32 AM
    chrisf111
    chrisf111 New Member
    Added a 5gal freshwater hosedown setup. Just a cheap little 12V pressure activated pump from Amazon ($30), a milk crate and 5gallon gug, and a little bit of wiring. Gets plenty of pressure to wash truck, or dirty feet/paws after the beach. Takes up minimal space in the bed and only adds 40lbs when full.
    20220503_122024.jpg 20220503_122049.jpg 20220503_122136.jpg 20220503_122532.jpg
  30. May 3, 2022 at 1:08 PM
    dtd608
    dtd608 New Member
    Daniel
    2010 Toyota Tundra
    That’s a good idea. I may look at doing that.
    joseph_womack[QUOTED] likes this.
