  1. May 1, 2022 at 8:08 PM
    Dantdodge
    Dantdodge New Member
    Danny
    Tampa
    2018 tundra sr5 crewmax trd 4x4
    Stock trd off road
    Yikes will those buff out?
    Wallygator likes this.
  2. May 2, 2022 at 12:56 AM
    AZBoatHauler
    So.Arizona
    Some #tundrastosedona pinstripes.
  3. May 2, 2022 at 2:40 AM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    Truckin a truck, like a boss
    I baby mine lol
    Kernal[QUOTED], welshmike and WBW like this.
  4. May 2, 2022 at 5:15 AM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    That's where I put mine.
  5. May 2, 2022 at 5:30 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Are these sitting on the bed and just attached to bed rail, or did you mount them to the bed with bolts?
  6. May 2, 2022 at 6:31 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Perfect, let me know how you mounted them. Did you do both the side and bottom?
  7. May 2, 2022 at 7:16 AM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    That’s good to hear! I’ve seen the videos of the full dash tear down, which was making me not want to do a HU install myself.
    Looking at your pictures, I assume you just popped off the center console, the usb panel, and the hvac control panel?
    TomC843[QUOTED] likes this.
  8. May 2, 2022 at 8:12 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Nice ... be sure to have the painted surround covered with clear protective film, if you don't want it to chip and peel. Ask me how I know ?!:(
  9. May 2, 2022 at 8:23 AM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Love your setup. I’ve got the portable as well - but want something installed. What tweaks did you to to make it permanent?
  10. May 2, 2022 at 9:10 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Wiring wise I removed the battery terminal clamps. Depending on your setup you'll need to add wires from the engine bay. Currently I added a relay that will come on with ignition power. But this will change later once I have a switch pros. I also removed the air tank and changed the routing of the braided line and fittings of that line.
    So rather than an input/output line from the tank, it's one line from the compressor to the quick disconnect. Not needed but I cut off the a portion of the shield just to give it more room and airflow.
    Pic of the airline attached.
  11. May 2, 2022 at 10:34 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    First one I’ve seen in the cab. Nice, clean install. Do you typically have passengers with you? Seems like it would be painfully loud.
    AggiePhil likes this.
  12. May 2, 2022 at 10:40 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    After an absolute train wreck of an experience getting my Retrax cover, I finally have it and the rack and tent mounted up!
    B011A1D0-1BCD-4530-9E17-532E82AC9667.jpg 63347B85-286E-4D06-9A91-34BE73DC8266.jpg
  13. May 2, 2022 at 10:40 AM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Pull out (snap out) the bottom power outlet panel, then same for HVAC controls, then 4 10mm bolts for the head unit. Think the nightmare is trying to replace the upper dash trim parts.
    D4x4TRD and nhw544[QUOTED] like this.
  14. May 2, 2022 at 10:42 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    Just ordered the Eibach Stage 2 coilovers since they came back in stock over the weekend. Looking to add toytech shackles to go with it.
    Currently running 275/55 on stock 20s. Need to figure out what to move to next.
    D4x4TRD likes this.
  15. May 2, 2022 at 10:52 AM
    nhw544
    nhw544 Food fight!
    RVA
    Awesome, thanks!
  16. May 2, 2022 at 10:54 AM
    marc32
    marc32 New Member
    Mario
    Maryland
    2015 Toyota Tundra SR5 4x4
    Would you still recommend getting one? Thinking of perhaps changing out my current bed cover.
  17. May 2, 2022 at 10:56 AM
    Squatting Pigeon
    Holden
    North Texas
    Yeah it wasn’t a quality issue, they just shipped me the wrong cover, and then a damaged one after that :facepalm:
    The cover itself is great! I’d spring for the metal one if you don’t have a bed rack on top of it because the polycarbonate is fairly flimsy. @RobertD has the aluminum one and it’s a fair amount beefier.
    marc32[QUOTED] and RobertD like this.
  18. May 2, 2022 at 10:57 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I need me one of those retrax cover.
  19. May 2, 2022 at 10:58 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    It's not loud at all. Typically while we are airing up everyones out of the truck stretching etc.
    Wallygator and jeffw6236 like this.
  20. May 2, 2022 at 11:05 AM
    “J”
    “J” New Member
    NC
    2021 Tundra SR Barcelona Red
    Dropped it off yesterday for the headlight recall issue. Made the appointment because they said they had the parts. Called today, apparently they don’t have the parts on hand…. They’ll have them tomorrow and it’ll be ready for pickup Wednesday. .
  21. May 2, 2022 at 11:46 AM
    What are they replacing on yours? Or does the inspection still have to be done? One guy on here had a harness replaced. They are not doing an LED upgrade, and the recall points directly at the harness being the issue.
  22. May 2, 2022 at 12:18 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Thats a nice set up!! What rack is that? Do you have any pics from the side? I’d like to see how tall the top of the tent is in relation to the roof of your truck.
  23. May 2, 2022 at 12:28 PM
    d_kinneyjr
    d_kinneyjr New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    While I’m away on a job site, I get to use a Taco for a couple of days. I mean it’s cute and all…..
    But I miss this beast!
  24. May 2, 2022 at 12:31 PM
    “J”
    “J” New Member
    NC
    I was under the assumption of a harness change. But will know for sure when I pick it up on Wednesday.
  25. May 2, 2022 at 12:55 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    dammit - now I need jerry cans too!
    :annoyed:
    Patch999, Outbound, TomC843 and 6 others like this.
  26. May 2, 2022 at 1:18 PM
    Squatting Pigeon
    Holden
    North Texas
    It is the cailiraisedLED mid height rack, and I do just so happen to have a side shot! I took it with the wide angle, so it looks a little wonky though.
  27. May 2, 2022 at 1:52 PM
    FISHN43
    FISHN43 New Member
    Ohio
    Nice !! Thank you!
  28. May 2, 2022 at 2:26 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Got it all wired up and running. Did a test fill on a tire. Dropped it down to 25psi then filled it up to 35. It seems like it took a minute. It was so fast. Compressor was ice cold. Stoked to use it.
  29. May 2, 2022 at 3:48 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Very nice! I have a feeling I will be eventually adding similar setup overtime.
  30. May 2, 2022 at 4:13 PM
    Beer Man
    Beer Man @cement.tundra
    2021 SR5 XP CrewMax Cement
    Has anyone started getting their car trim auto up/down modules in yet? I’m very interested to see if they work as described.
    XLTaco likes this.
