Steering wheel shake occasionally highway speed
Discussion in '1st Gen Tundras (2000-2006)' started by Dean62, Apr 28, 2022.
  1. Apr 28, 2022 at 1:27 PM
    Dean62
    Dean62 [OP] New Member
    Jacob
    2003 SR5 Sequoia 2WD
    I have a 2003 Sequoia 2wd with 3inch lift (installed by previous owner) 227k miles that at highway speed will sometimes shake the steering wheel not enough to be really bad but enough to notice maybe like 1/8thor 1/16th inch back and forth. Lower ball joints were replaced right before I got it last year and I just replaced the steering rack bushing with the ones from Energy suspension. At low speed there does not seem to be any play. I've jacked it up and checked at both 3 n 9 and 12 n 6 for play and I don't feel any at all. It doesn't get hard to steer or make any noises while turning so I feel like its no the rack but not totally sure. If it wasn't expensive I'd just replace it for piece of mind. the sometimes part also throws me for a loop but either way does anyone have any idea what it could be.
    We are wanting to take this on a 2000 mile round trip instead of our ford focus because this has so much more room and just trying to make sure we get anything that might cause problems taken care of before we leave in June
  2. Apr 28, 2022 at 1:40 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Sure sounds like alignment or wheel balance
    KNABORES likes this.
  3. Apr 28, 2022 at 1:42 PM
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    Wheel balance
  4. Apr 28, 2022 at 1:42 PM
    shifty` Ten EV 12's so you know I raise hell
    Sounds like wheel balance to me, but it's also what another member had when he had cupping issues with his tires. That was after chasing down other things, IIRC.
    I'd never heard of cupping causing vibration prior, but I searched around online after and found a bunch of people with same. Chalk it up to issues I've never had but apparently others have...
    Anyway, not unheard of to have a balance weight get knocked off during a procedure, especially the ones mounted to the rim lip. But could be cupping too.
  5. Apr 28, 2022 at 1:53 PM
    Dean62
    Jacob
    wouldn't wheel balance be an all the time at highway speed? ill try and swap my stock trd sport Tacoma wheels and tires on there and check since I know those don't shake
    currently I still have what the guy I bought it from had them on and in the picture above its on my current trd off-road Tacoma wheels
    My current Tacoma and the wheels above
    how the sequoia sits currently
  6. Apr 28, 2022 at 2:11 PM
    I've experienced intermittent vibrations when wheel balance was at fault. In a case like this, where multiple issues could be guilty, anything you can exclude is bonus, so your proposed solution to swap over the Taco wheels is great.
    Not sure about 1st gens pecifically, but in other trucks I've owned, a lift/drop of 3" or more did require adjustments to driveline to avoid vibrations (shims or otherwise). Doubt that's the issue here ... but ...
  7. Apr 28, 2022 at 2:16 PM
    gascap
    gascap New Member
    2002 Tundra
    Like that new bling red color.
  8. Apr 28, 2022 at 2:26 PM
    dlowry81
    dlowry81 New Member
    Doug
    My previous tundra had a Bilstein lift, aftermarket wheels, and larger tires and rebalancing always fixed the steering wheel shake. And no it didn't shake at every speed. It was always at a certain speed range.
    alb1k likes this.
  9. Apr 28, 2022 at 2:31 PM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    I had weights come off the rear tire. Wasn't an issue until I rotated, then it would shake at 60+ mph. Got it rebalanced and it was good again.
  10. Apr 28, 2022 at 2:41 PM
    Yup, you can have an out-of-balance wheel out back and notice nothing. Move that wheel to the front, it'll drive you f'n nuts. I've never been able to get anyone to tell me why it's the case - I guess the weight of the engine exacerbates things?
    Army_of_One[QUOTED] likes this.
  11. Apr 28, 2022 at 3:25 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    As a refresher, what are you checking with moving the wheel at 3 and 9? Is that tie rod ends? I know 12 and 6 is ball joints.
    ... I may have just diagnosed a driver-side TRE that needs replacement.
  12. Apr 28, 2022 at 3:41 PM
    alb1k
    Left Coast
    It's good
  13. May 2, 2022 at 6:02 AM
    Dean62
    Jacob
    Well yall were totally right got a new set of 33s on this weekend and it rides perfectly now. No shaking once so ever.
  14. May 2, 2022 at 6:13 AM
    Thanks for following up! Good thing you didn't throw any unnecessary money at it!
  15. May 2, 2022 at 6:15 AM
    Dean62
    Jacob
    yeah me too i was thinking i was going to have to replace the steering rack which would of been a pretty good $$$
    Mogo Gogo likes this.
