Trailer Brake Error Help
Discussion in '2.5 Gen Tundras (2014-2021)' started by jre5490, Apr 14, 2022.
  1. Apr 14, 2022 at 12:35 PM
    jre5490
    jre5490 [OP] Rane
    Rane
    MS Gulf Coast
    2019 Tundra SR5 TSS
    Just this morning I started getting a Trailer Brake Error message on the instrument panel. The traction control light came on as well. Last night I put new Bilstein 5100 shocks on the rear of the truck. I searched the threads and saw other people with the same issue, but didn’t see anyone mention doing suspension work prior to the message coming on. Do you think I could have bumped something back there while changing the shock out? Should I just pull the negative battery cable and reconnect to see if it goes away? Just interested to see if anyone has had this happen before. Thanks.
  2. Apr 14, 2022 at 1:20 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Id disconnect battery and see if it clears first. If it returns start checking things. Hey, you are about 3 years in on that truck, about the time the factory batteries start going bad. Battery going out will fault a lot of different alerts, so something to consider if it is the original.
    jre5490[OP] likes this.
  3. Apr 14, 2022 at 1:23 PM
    jre5490
    jre5490 [OP] Rane
    Rane
    MS Gulf Coast
    2019 Tundra SR5 TSS
    Thanks! Yeah I’ve been waiting for the battery to start showing signs of going out. Used to be able to get 5 years out of a battery. Last 2 trucks I had the first battery only lasted 3 years.
  4. May 1, 2022 at 4:25 AM
    ChiselnMallet
    ChiselnMallet New Member
    2019 Limited Double Cab
    T-SB-0036-19
    I had this issue with mine. Dealership updated the program and it fixed the issue.
  5. May 1, 2022 at 6:19 AM
    jre5490
    jre5490 [OP] Rane
    Rane
    MS Gulf Coast
    2019 Tundra SR5 TSS
    I’m not really sure what fixed it but it hasn’t been on for almost 3 weeks. I disconnect the negative cable on the battery for 30 minutes and put it back on and it was still there. I had an alignment and new tires put on the next morning and I don’t know if it was something alignment related or if the tire place did something to it, but the lights and error message was gone when I picked the truck up.
  6. May 2, 2022 at 4:20 AM
    ChiselnMallet
    Nice that it's not on! Strange that it just disappeared with out knowing why though. Tow safe!
