Starting Issues
Discussion in '1st Gen Tundras (2000-2006)' started by Dave76, May 1, 2022.
  1. May 1, 2022 at 2:59 PM
    Dave76
    Dave76 [OP] New Member
    2006 Tundra won’t start please help driving me crazy
  2. May 1, 2022 at 3:24 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    Welcome to the forum. Sorry for your problem.
    What diagnosis have you done? Is the battery good? Do the headlights illuminate when turned on with the key in the run position? Any noise when trying to start?
  3. May 1, 2022 at 3:32 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    Yeah I mean is that how you troubleshoot? You really have to give us more info to help you troubleshoot it further.
    Aerindel and FrenchToasty like this.
  4. May 1, 2022 at 3:32 PM
    Dave76
    Headlights work but gauges don’t work at all but radio and everything else does
  5. May 1, 2022 at 4:22 PM
    I’d have someone measure the voltage at the battery with a meter while you crank it. It shouldn’t go below 11 volts. If it was like mine when it died, it might be down to 6v or less. If you think there’s still life, get a jump from AAA or borrow someone else’s battery.
    If that doesn’t work, you may have a fuel delivery problem.
    If it does turn over, measure the voltage with it running. Alternator should drive the voltage up to 13.5-14v for charging.
    BMET likes this.
  6. May 1, 2022 at 4:26 PM
    Dave76
    Put a new battery on it and it still does the same thing I don’t get what it could be
  7. May 1, 2022 at 4:31 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Check all the fuses.
    Mr Badwrench likes this.
  8. May 1, 2022 at 4:32 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  9. May 1, 2022 at 4:47 PM
    Dave76
    Already checked all the fuses
  10. May 1, 2022 at 4:55 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Reminds me of Charades or pulling teeth !
    Aerindel, bmf4069, Tundra2 and 2 others like this.
  11. May 1, 2022 at 5:11 PM
    Can you hear the fuel pump with the ignition on but engine off?
  12. May 1, 2022 at 5:24 PM
    Dave76
    I can hear the fuel pump and can hear the starter
  13. May 1, 2022 at 5:39 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  14. May 1, 2022 at 6:02 PM
    Ok, you checked all the fuses in the dash, AND the fuses in the fuse & relay box under the hood?
    This post has a video that covers diagnosing start issues in our trucks. WATCH IT.
    This thread may be interesting to you for troubleshooting steps. With how very little details you gave, it's hard as hell to give you advice.
    It's not uncommon for cables to get corroded inside the sheath. something to short in the engine fuse/relay box like THIS GUY found. There's at least one other case where a member found the positive battery line going to the under-hood fuse box was shorting and therefore not sending power to the cab. Too bad it's such a pain in the ass to pop the box up and look at the underside. It's not that it's difficult, there's just a trick and an order to it.
    bmf4069 likes this.
  15. May 1, 2022 at 6:31 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    You can hear the starter... Do you hear the solenoid click or does the starter growl when trying to turn?
    Aerindel likes this.
  16. May 1, 2022 at 7:21 PM
    Mr Badwrench
    Mr Badwrench New Member
    Give us some more details. Someone here can probably help you out.
    Engine size/cylinders? 4.7 or 3.4?
    Does it crank?
    Any recent changes or modifications?
    Does it sound like you have compression? (timing belt broken)
    etc...
  17. May 1, 2022 at 7:49 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Hmmmmmmm.
    Aerindel, KNABORES, shifty` and 6 others like this.
