  1. Apr 30, 2022 at 5:54 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Haha. That's a good question. Here's the definition as defined by the idiot that screwed up the connector. It's the connector for the knock sensor harness.
    Stippled - when you really screw up by stripping and/or pulling the wire out of a necessary connector in a hard to access place.
    BubbaW[QUOTED] likes this.
  2. Apr 30, 2022 at 6:02 PM
    2nd. Sounds like a wheel bearing that was exacerbated by the lift and tires.
  3. Apr 30, 2022 at 6:54 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    thanks all for the info, very helpful!
    bmf4069[QUOTED] and Mogo Gogo like this.
  4. Apr 30, 2022 at 7:29 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Changed the lower ball joint bolts that I didn't order when doing suspension work last May. No failures, I just read that they should be changed when doing Lebrons.... changed 1 bolt at a time applying red loctite torquing to 61ish ft lbs before moving on to next bolt.
    Does the last picture look like just brake dust?
  5. Apr 30, 2022 at 8:33 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Hey Brother - I only gave this a quick like earlier because I was working. Thank you so much for the pics. Awesome! I really need to hear more about what when on with you boys, but that will come. Way to not die. :yes:
  6. Apr 30, 2022 at 8:34 PM
    alb1k
    Left Coast
    It's good
    It does look like brake dust and time for new rotors.
    chrisb, Jack McCarthy and Festerw like this.
  7. Apr 30, 2022 at 10:51 PM
    Sirfive
    Sirfive Working on pavement
    ‘02 Limited AC TRD
    Bassani cat-back
    Technically touching on a 1/2” rock.
    Voss, 5N0W808, oscardog86 and 6 others like this.
  8. Apr 30, 2022 at 10:53 PM
    Just out mowing the grass I see
  9. Apr 30, 2022 at 10:59 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Got some good trash, didnt wanna unload it. Not gonna do these trails on bichelins, and i dont have any supplies what so ever. I rattle pretty good on the main road. Helps mask the vulgar displays of acceleration that seem to happen in the slippery bits. Mud pics to come tomorrow.
    ive gotta be smooth, ive got a puppy. But he rode some trails. So hes got his sea legs now.
  10. Apr 30, 2022 at 11:01 PM
    Some scum left two pop up skeletons at the site we got, our ford friends threw them in a dumpster, and apparently got video taped in the act hahaha
    Darkness, Mogo Gogo and alb1k like this.
  11. May 1, 2022 at 2:46 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    2nd on both
    Hi06silver and alb1k[QUOTED] like this.
  12. May 1, 2022 at 9:48 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    Yeah I was thinking the same. I've had issues with 1 caliper which had ruined the pads from brake fluid but for the life of me can remember if I'd put new rotors on then too. I should probably find an app to remember this stuff for me. I'll hit the search button for rotor recco's here after a bit.
    alb1k[QUOTED] likes this.
  13. May 1, 2022 at 12:34 PM
    Jebus man, get those rotors turned already! How could you not see that thru your wheels? :rofl:
    Hi06silver[QUOTED] likes this.
  14. May 1, 2022 at 12:40 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Honestly turning rotors on the tundra just leads to warping them if you drive the truck hard. I avoid cutting on the truck. My cars? Yea I get a couple cuts out of a set of rotors
    chrisb, Mogo Gogo and shifty`[QUOTED] like this.
  15. May 1, 2022 at 12:45 PM
    Yeah I’m pretty sure I warped the shit out of my rotors due to rear adjustment on my last trip to the lake, and then they got even worse this last trip because I didn’t have it in low gear going down a long slow trail on the brakes most of the time……
    Next parts sale I might get new rotors and drums, pads and shoes are still less than 5k on them
    Darkness and Mogo Gogo like this.
  16. May 1, 2022 at 1:45 PM
    empty_lord
    05 rollover special
    I’ve got disc brakes waiting. Just need to get axle shafts since I don’t want to destroy my perfectly fine backing plates. And my bearings are still good.. they’ll go in storage assembled for when I need a set
    chrisb and FrenchToasty[QUOTED] like this.
  17. May 1, 2022 at 1:58 PM
    Running non-ceramic brake pads is a good way to ruin the finish on your wheels from the dust. I’ve tried everything to clean mine but maybe not an issue for you since you told me you don’t drive it in the winter time. Also, they’re black so it won’t show as much.
  18. May 1, 2022 at 2:02 PM
    empty_lord
    05 rollover special
    Matt black wheels show everything. I have ceramic coating to get done to the wheels soon. That will help. I run ceramics on the trucks.
  19. May 1, 2022 at 2:05 PM
    Oh sorry. I confused your post with @Hi06silver. My bad. lol
  20. May 1, 2022 at 2:08 PM
    Get some ceramic pads or you’ll kill the finish on your wheels.
    ktundra and Mogo Gogo like this.
  21. May 1, 2022 at 2:16 PM
    empty_lord
    05 rollover special
    Well shit. I just wanted someone to talk to me
    NUDRAT, chrisb, Darkness and 3 others like this.
  22. May 1, 2022 at 2:17 PM
    Haha I’ll bite; why are rear drums more expensive than front rotors?
    Darkness, bmf4069 and CodyP like this.
  23. May 1, 2022 at 2:17 PM
    Truthfully, the way prices are with used vehicles, I’m surprised you haven’t sold off one or two of your tacos by now.
    ktundra likes this.
  24. May 1, 2022 at 2:20 PM
    empty_lord
    05 rollover special
    Cost more to make
  25. May 1, 2022 at 2:21 PM
    empty_lord
    05 rollover special
    Hahah I’m debating the red 2002. But I love these things
    The 95 is staying. The 98 is staying. The 01 will be with me till I’m dead
  26. May 1, 2022 at 2:26 PM
    Do you work on the Mercedes much? That one seems more challenging to restore.
  27. May 1, 2022 at 2:28 PM
    empty_lord
    05 rollover special
    Still trying to find an engine then I’ll get going on that one. I have a guy in Virginia willing to sell me a whole interior for a grand. Red interior Preston’s condition
    chrisb likes this.
  28. May 1, 2022 at 2:31 PM
    Straight 6 or V8? What displacement? I’ll check around in my free time for you as well.
  29. May 1, 2022 at 2:31 PM
    empty_lord
    05 rollover special
    M121 4 cylinder 2.0l
  30. May 1, 2022 at 2:37 PM
    That can’t be much hp, but I’m guessing that’s because it’s made for comfort and to show off for its vintage appeal.
